HA Group - Change Controller IP
  • 1.  HA Group - Change Controller IP
    Posted Nov 09, 2016 04:28 PM
    Has anyone changed the controller IP of a HA fast-failover group member before?
    Would it simply involve:
    - Use ap-move to swing all APs to other controller
    - On master, issue 'no controller <Old IP> role dual'
    - On local, change controller IP address, reboot
    - On master, issue 'controller <NewP> role dual
    - Update LMS IP in ap system profile, reboot APs
  • 2.  RE: HA Group - Change Controller IP
    Posted Nov 10, 2016 04:29 AM
    You don't need to use "ap-move" just unplug the controller from the network that you're going to change IP on and assuming HA is configured correctly the APs will failover.
  • 3.  RE: HA Group - Change Controller IP
    Posted Nov 17, 2016 10:08 PM
    Ended up doing the following:
    1) Removing local controller from HA group on local
    2) Removing old controller IP from HA group on Master
    3) Changing controller IP
    4) Adding new controller IP to HA group on Master
    5) Adding local controller to HA group on local
    6) Updating LMS profile on master
    Throughout this whole process not a single AP had to reboot (we did the same for 2 local controllers).
  • 4.  RE: HA Group - Change Controller IP
    Posted Dec 22, 2016 08:09 AM
    So because the controllers are in an HA group, changing the LMS/BKUP-LMS ip doesn't cause a reboot?
  • 5.  RE: HA Group - Change Controller IP
    Posted Dec 22, 2016 09:00 AM
    Do you currently have HA configured ?
  • 6.  RE: HA Group - Change Controller IP
    Posted Dec 22, 2016 09:03 AM
    Yes, I have both locals assigned to an HA group and also have them listed in the ap system profile as LMS/BKUP LMS
