Hello
We already have one Gateway configured and its working fine
Now we would like to add anther Gateway for HA
I was wondering how hard is to do that with Aruba OS 10?
I was reading some but i don t know if i got the correct steps to do so, or if im missing something
Some data:
Gateway A = Gateway that is working right now
Gateway B = Gateway with no configuration ( this is the new one that we will add for the HA)
Gateway A =192.168.10.5/24
Gateway B = 192.168.10.6/24
Interface Vlan 50 = 192.168.10.1/24
VRRP IP= 192.168.168.10.7/24
1-Add the gateway to the aruba central(the gateway will have no configuration)
2-Upgrade it to the same firmware that the gateway that is already working
3-Configure the ip of the Gateway B as you can see on my table up which is on the same network of the gateway A
4- set HA in automatic and autogroup
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/46337bbef4714e829e6d1e3a95061835.png)
5-Go to redundancy:
a)Put anything on the description
b)select ipv4
c)put an authentication password
d)put in the VRRP IP address
e)What should i put on the priority???
f)put admin state up
g)select the vlan that the gateway are right now which is 50.
h)Aside that im not sure what to configure in the tracking part
i)Move the gateway B to the group where the gateway A is
Im not sure if my configuration like that iits on the right path or im going on the wrong path?
Has anyone configured this before with Aruba OS 10 with aruba central for WLAN?
Help is appreciated!
