Has anyone ever successfully implemented a timed model for ClearPass Guest?
  • 1.  Has anyone ever successfully implemented a timed model for ClearPass Guest?
    Posted Jun 02, 2015 04:06 PM
    Has anyone ever successfully implemented a timed model for ClearPass Guest where self-registration is only available after hours? To clarify, the goal is to redirect users to a web page, during business hours, to contact a guest admin, but use self-registration pages available after business hours when no guest admins are present?
    Randy
  • 2.  RE: Has anyone ever successfully implemented a timed model for ClearPass Guest?
    Posted Jun 02, 2015 04:22 PM
    Please take a look at the article here:  (requires Aruba Support Login) https://arubapedia.arubanetworks.com/arubapedia/index.php/How-To:_Restrict_Guest_Login_Page_to_Business_Hours
  • 3.  RE: Has anyone ever successfully implemented a timed model for ClearPass Guest?
    Posted Jun 03, 2015 08:54 AM
    Thanks Colin. I tried the solution in my lab on the self-registration page without success. I will play with it some more to see if I can get it to work. Thank you for the reference
    Regards...
    Randy B.
  • 4.  RE: Has anyone ever successfully implemented a timed model for ClearPass Guest?
    Posted Jun 03, 2015 09:27 AM
    Randy,
    Are you doing the use case like in the article, or is what you are doing different? Did you get the specific example in the article to work?
  • 5.  RE: Has anyone ever successfully implemented a timed model for ClearPass Guest?
    Posted Jun 04, 2015 10:11 AM
    Colin...
    I tried to relpicate the use case in the article to see if I can get some ideas to get to the end destication.  unfortunatly I am getting an error when I add the HTML to the headers and footer as mention in the how to...
    Error in template: [in __template__55705bad5be934.94472563.html line 1]: syntax error: (secure mode) 'date' not allowed in if statement (Smarty_Compiler.class.php, line 291)
    Do you know if there are any working examples of this on clearpass.arubademo.net?
    Randy
  • 6.  RE: Has anyone ever successfully implemented a timed model for ClearPass Guest?
    Posted Jun 04, 2015 10:32 AM
    RLB,
    Please try this:
    Above what you have add:
    {assign var=Hi value='Hi'|date}
    The every place you see date("Hi") replace it with $Hi.
    Let us know if that works.
  • 7.  RE: Has anyone ever successfully implemented a timed model for ClearPass Guest?
    Posted Jun 04, 2015 03:42 PM
    RLB,
    I did this to test this:
    Header
    {nwa_cookiecheck}
    {if $Hi < "1600"}
       <h3>Service Unavailable</h3>
        <h4>Guest Network Access unavailable before 4pm</h4>
        <div style="display:none;">
       {elseif $Hi >= "1700"}
        <h4>Guest Network Access unavailable after 5pm</h4>
       {/if}
    {if $errmsg}{nwa_icontext type=error}{$errmsg|escape}{/nwa_icontext}{/if}
    {nwa_text id=7980}<p>
        Please login to the network using your
        username and password.
    </p>{/nwa_text}
    Footer
    {if $Hi < "1600" || $Hi >= "1700"}
       </div>
       {/if}
    {nwa_text id=7979}<p>
    Contact a staff member if you are experiencing
    difficulty logging in.
    </p>{/nwa_text}
    I purposely changed to between 1600 and 1700 so that I would be outside of that range to test.  You can change it to any 24-hour range to suit your needs.
  • 8.  RE: Has anyone ever successfully implemented a timed model for ClearPass Guest?
    Posted Jun 04, 2015 06:27 PM
    Colin...
    The added HTML as scripted in my lab and it worked on my self registration pages.  I am going to tweak it so that between the hours of 8:00am and 4:00pm users are directed to contact a staff member to create an account.  between the hours of 4:00pm and 8:00am the self registration page should appear...Thank You VM for getting me most of the way there, appreciate your dedication to the site and prompt replies..Highest Regards
  • 9.  RE: Has anyone ever successfully implemented a timed model for ClearPass Guest?
    Posted Jun 04, 2015 07:23 PM
    RLB,
    It has been brought to my attention that there is already a time restriction built into the guest registration page:
  • 10.  RE: Has anyone ever successfully implemented a timed model for ClearPass Guest?
    Posted Jun 04, 2015 07:26 PM
    Oh? Do tell...
    Randy
  • 11.  RE: Has anyone ever successfully implemented a timed model for ClearPass Guest?
    Posted Jun 04, 2015 07:29 PM
    It is in the screenshot in the previous post.
    Pages> Guest Self-Registration> Edit Self-Registration Page> Advanced Editor:
