last person joined: 7 hours ago
have a HP2930 series switch, how many WAP connections can it take guys?
  • 1.  have a HP2930 series switch, how many WAP connections can it take guys?
    Posted Aug 12, 2022 11:36 AM
  • 2.  RE: have a HP2930 series switch, how many WAP connections can it take guys?
    Posted Aug 15, 2022 12:13 PM
    What is the exact type of the switch? There should be a type number like JL258A on it.
    What is the type of APs that you want to connect?
    If you want to connect and power APs, it depends in the number of ports (you need one port per AP and probably an uplink as well), and the PoE power budget. You will need to know the amount of power each AP requires as well, multiply that by the number APs and it should be less than the power budget.
