have any one did a mesh between 2 MSRs with ANT-2x2-5314 for 3 Km distance?
  • 1.  have any one did a mesh between 2 MSRs with ANT-2x2-5314 for 3 Km distance?
    Posted Jun 25, 2014 11:24 AM
    Dears, Hvae any one tried to mesh on such a distance before and what is the expected data rates on 40 MHZ with clear LoS
  • 2.  RE: have any one did a mesh between 2 MSRs with ANT-2x2-5314 for 3 Km distance?
    Posted Jun 25, 2014 12:19 PM
    Are you looking to just do a bridge? If so you might want to look into the MST200.
  • 3.  RE: have any one did a mesh between 2 MSRs with ANT-2x2-5314 for 3 Km distance?
    Posted Jun 25, 2014 05:00 PM
    I will give it a shoot and see what will happen but have you tried it before I have tried 1.5 km worked well like 117mb data rate but 3 km will be chalange
  • 4.  RE: have any one did a mesh between 2 MSRs with ANT-2x2-5314 for 3 Km distance?
    Posted Jun 25, 2014 05:50 PM
    MST200 at HT40 should give you the attached plots (with clear LoS, no fresnel zone issues, etc). Follow the red line for HT40. If you need HT20, drop those rates by approx 50% (roughly). At 3km you should be around 70-80Mbps HT40, or around 35-40Mbps HT20.HT40 rate v range
  • 5.  RE: have any one did a mesh between 2 MSRs with ANT-2x2-5314 for 3 Km distance?
    Posted Jun 25, 2014 06:00 PM
    Thanks Man really add value I will check once I got the equipment and feed you back
  • 6.  RE: have any one did a mesh between 2 MSRs with ANT-2x2-5314 for 3 Km distance?
    Posted Jun 25, 2014 06:03 PM
    One more thing now ANT 5614 is 60 degreee I belive 5314 will be more focused which may give better link quality
  • 7.  RE: have any one did a mesh between 2 MSRs with ANT-2x2-5314 for 3 Km distance?
    Posted Jun 25, 2014 08:36 PM
    They are effectively the same (MST200 is 14dBi with 55deg horizontal and 13deg vertical; 5614 is 14dBi 60deg horizontal with 14deg vertical).
  • 8.  RE: have any one did a mesh between 2 MSRs with ANT-2x2-5314 for 3 Km distance?
    Posted Jun 26, 2014 04:34 AM
    is 5614 is the same as 5314!!
  • 9.  RE: have any one did a mesh between 2 MSRs with ANT-2x2-5314 for 3 Km distance?
    Posted Jun 26, 2014 08:51 AM
    The 5314 is also a 14dBi antenna, but is 30deg x 30deg, the 4614 is a 14dBi antenna and is 60deg x 15deg.
  • 10.  RE: have any one did a mesh between 2 MSRs with ANT-2x2-5314 for 3 Km distance?
    Posted Jun 26, 2014 11:23 AM
    thats what I mean 30 Degree is more focused
  • 11.  RE: have any one did a mesh between 2 MSRs with ANT-2x2-5314 for 3 Km distance?
    Posted Jun 26, 2014 09:37 PM
    yup, the pros for a PtP with the ANT-2x2-5314, it has uniform Vertical and Horizontal spread so easier to aim. Also the 5314 has a much more flexible and robust antenna mounting kit.
