Having issues bringing up RAP
  • 1.  Having issues bringing up RAP
    Posted Sep 22, 2015 05:40 PM
    Hello Guys,
    I am having issues brining up a RAP. I have done the following things on the controller:
    1- Created the RAP AP profile
    2- Created the AP Group
    3- Assigned the SSID
    4- configure the NAT rule on the FW and allowed port UDP 4500 and TFTP 69
    I think is caused because IAP to RAP conversion does not go through properly but I might be worng.When I convert the IAP to RAP..I dont get any sort of confirmation that its convereted to RAP. See the picture attached for detail. Once I get this error, I am not able to access the RAP through GUI and I am not sure whether the conversion was successful or not. I have tried connecitng my home router connection to the port 0 and then port 1 to my laptop but my laptop is getting APIPA address.
    Any help will be apprecited. Thanks
  • 2.  RE: Having issues bringing up RAP
    Posted Sep 22, 2015 05:41 PM
    Have you added the RAP to the controller RAP whitelist?
  • 3.  RE: Having issues bringing up RAP
    Posted Sep 22, 2015 05:43 PM
    Hi Cappalli,
    Thanks for prompt reply. Yes, I have added the RAP in the whitelist as well on the controller but no joy.
  • 4.  RE: Having issues bringing up RAP
    Posted Sep 22, 2015 05:46 PM
    What is the RAP model and what is the controller AOS version?
  • 5.  RE: Having issues bringing up RAP
    Posted Sep 22, 2015 05:54 PM
    RAP model number is RAP-109 and controller model is 7010 running AOS 6.4.1.0
  • 6.  RE: Having issues bringing up RAP
    Posted Sep 22, 2015 06:25 PM
    Supermo121,
    Do this:
    on the controller:
    config t
    config tlogging level debugging security subcat ike
    logging level debugging security process aaa
    logging level debugging security process authmgr
    logging level debugging security subcat l2tp
    logging level debugging security subcat vpn
    Try to convert the RAP.  When it fails, type "show log security 50" and paste in that log here as a response.
  • 7.  RE: Having issues bringing up RAP
    Posted Sep 22, 2015 06:28 PM
    Hi Colin,
    Thanks for your reply. I dont have access to the controller now but will action this tomorrow morning and the upload the output.
  • 8.  RE: Having issues bringing up RAP
    Posted Sep 23, 2015 04:55 AM
    Have you defined a NAT pool for the raps?
    ip local pool <name> <start ip> <end ip>
  • 9.  RE: Having issues bringing up RAP
    Posted Sep 23, 2015 05:17 AM
    Hi Michael,
    Thanks for your reply. I think you are talking about the VPN pool tell me if I am wrong. Yes, I have created the VPN pool for the RAP.
    Kind Regards
