Network Management
Heads up - Airwave 8.2.8.2 does not support IAP 8.5.0.0 firmware
  • 1.  Heads up - Airwave 8.2.8.2 does not support IAP 8.5.0.0 firmware
    Posted May 18, 2019 10:56 AM
    Hi All,
    Just a heads up that Airwave (current version 8.2.8.2) does not yet support Instant 8.5.0.0 firmware.
    We just found out the hard way after upgrading IAP from 8.4.0.1 to 8.5.0.0. The firmware upgrade completed just fine, and our IAP environment is up and running on 8.5.0.0, but Airwave showed the upgrade never completing, and eventually failed because it could not communicate with the newly updated IAP 8.5.0.0 virtual controller/APs.
    Opened a ticket, and word from HPE support is that 8.5.0.0 is not yet supported, and no committment on when it might be.  We could downgrade, but I'm hoping/planning to wait it out for next Airwave release for a bit first.
    Lesson learned - don't assume, and always verify that Airwave will support the new firmware release version before proceeding with an upgrade.
  • 2.  RE: Heads up - Airwave 8.2.8.2 does not support IAP 8.5.0.0 firmware
    Posted May 29, 2019 01:02 PM
    Support for AOS 8.5 will be in AW v8.2.9. The release ETA is 1st week of June.
  • 3.  RE: Heads up - Airwave 8.2.8.2 does not support IAP 8.5.0.0 firmware
    Posted May 29, 2019 05:37 PM
    Thanks for the update - we look forward to applying the Airwave update when it is released.
  • 4.  RE: Heads up - Airwave 8.2.8.2 does not support IAP 8.5.0.0 firmware
    Posted Jun 20, 2019 10:54 AM
    I am finding that Airwave 8.2.9 still does not support 8.5.0 on the IAPs.  I upgraded to Airwave 8.2.9 first and then issued the 8.5.0 IAP firmware upgrade via Airwave.  The IAPs all updated and came back up (according to the VC's web page), but Airwave still shows them all as down and the firmware upgrade failed.
  • 5.  RE: Heads up - Airwave 8.2.8.2 does not support IAP 8.5.0.0 firmware
    Posted Jun 20, 2019 12:39 PM
    I concur - this is still an issue currently.  I have an open ticket on it as well.  I did the same - installed Airwave 8.2.9 as suggested and tried again with the 8.5.0.0 firmware with the same result:  Upgrade succeeds, cluster is up and I can talk to the VC GUI, but upgrade job times out after 1 hour in Airwave and shows failed and never sees the upgraded APs.
    I should add, that I recovered by disconnecting airwave (Basic, Aruba Instant, Enable Instant GUI Config: no), downgrading to 8.4.0.2 and then reconnecting airwave (Basic, Aruba Instant, Enable Instant GUI Config: yes).
    I have also subsequently used Airwave to upgrade the cluster to 8.4.0.3 with no problem.
    So the issue is definitely with the 8.5.0.0 firmware compatibility with Airwave.
  • 6.  RE: Heads up - Airwave 8.2.8.2 does not support IAP 8.5.0.0 firmware
    Posted Jun 20, 2019 12:47 PM
    Could you share the TAC case#. I will look into it.
  • 7.  RE: Heads up - Airwave 8.2.8.2 does not support IAP 8.5.0.0 firmware
    Posted Jun 20, 2019 01:06 PM
    Current HPE Support Case 5339387120
    Previous HPE Support Case 5338673050
    Thank you for offering to work on it!  At present, I don't need specific features in 8.5.0.0, so i am content living on 8.4.0.3 and having Airwave working.  I look forward to it being fixed to accomodate 8.5.0.x, but I'm OK with waiting, since recreating the failure and then recovering is time consuming.
  • 8.  RE: Heads up - Airwave 8.2.8.2 does not support IAP 8.5.0.0 firmware
    Posted Jun 20, 2019 02:08 PM
    Got it. I will check on it with the customer who are on 8.5.0 and update here latter on the fix.
  • 9.  RE: Heads up - Airwave 8.2.8.2 does not support IAP 8.5.0.0 firmware
    Posted Jun 20, 2019 02:11 PM
    Thanks for the tip.  I was able to downgrade to 8.4.0.3 using the steps you provided and things are back to normal.
  • 10.  RE: Heads up - Airwave 8.2.8.2 does not support IAP 8.5.0.0 firmware
    Posted Jul 03, 2019 10:27 AM
    If you are running 8.5.0 on APs and Airwave 8.2.9, contact TAC.
    They will remote in and from root, run a patch on your Airwave server.
  • 11.  RE: Heads up - Airwave 8.2.8.2 does not support IAP 8.5.0.0 firmware
    Posted Jul 26, 2019 11:38 AM
    I am pleased to report that Airwave 8.2.9.1 was able to successfully perform a firmware update for our group to IAP 8.5.0.1 with no problem.
  • 12.  RE: Heads up - Airwave 8.2.8.2 does not support IAP 8.5.0.0 firmware
    Posted Aug 08, 2019 03:08 PM
    Guess I should have looked here first.
    I upgraded an iAP in the lab to test RAP connectivity and lost management from Airwave (I'm on 8.2.8.2)
    It's OK as it's just a lab AP, but I was startled.
  • 13.  RE: Heads up - Airwave 8.2.8.2 does not support IAP 8.5.0.0 firmware
    Posted Jun 20, 2019 12:46 PM
    I would suggest to open a TAC case to track this. You can also drop me an email with the details i can work with you on this.
  • 14.  RE: Heads up - Airwave 8.2.8.2 does not support IAP 8.5.0.0 firmware
    Posted Jun 20, 2019 02:09 PM
    Also, please include the IAP running config when we open the case.
