Hi Team,
I am trying to calculate the maximum heat dissipation of a system which is the assembly of :
Now from the Iris tool I have the value 327.57BTU/Hr when I have the above configuration BUT i believe this is only for the switch as :
- When i put only one PSU the total weight doesn't change
- When I put different PSU the total BTU/HR doesn't change
I looked almost everywhere to get the chart of power consumption to heat dissipation of the PSU in general but to no avail online, which is why I am asking.
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/8f8e1ca57d164d0f9e3c0a1080366325.png)
My reasoning, is the following :
- The PSU are platinum rated, which means at 100% capacity they are 90% efficient (10% will be dissipated to heat)
- The Maximum PoE power draw for the switch with the 2 PSU in redundancy mode is 740w, which will bring for me a Heat dissipation at 74w (256BTU/hr)
So the total heat dissipation of the switch + 2 PSU in redundant mode, worst case scenario is around 580btu/hour (or 170Wh)
Does that seems logic ? Is there any datasheet or tool providing the heat dissipation of the PSU or the total assembly ?
Thanks in advance
