Network Management
Heat Maps on VisualRF in Airwave not showing
  • 1.  Heat Maps on VisualRF in Airwave not showing
    Posted Aug 22, 2013 11:31 AM
    This just started, the heat maps and signal strength are not showing up.  We are running 7.5.7, we cannot upgrade due to the hardware requirements. I have check the CPU usage, memory usage and disk usage. All of which are fine. Is there anything else I should look at or do to get the heat maps to display? Thanks in advanced.
  • 2.  RE: Heat Maps on VisualRF in Airwave not showing
    Posted Aug 22, 2013 01:37 PM
    Did you try disabling Visual RF then re-enabling it?
  • 3.  RE: Heat Maps on VisualRF in Airwave not showing
    Posted Aug 22, 2013 03:13 PM
    I tried the disable/enable VisualRF. I had to reboot the server. Now it works. Thanks for the help.
  • 4.  RE: Heat Maps on VisualRF in Airwave not showing
    Posted Aug 22, 2013 05:40 PM
    In the future, you'll probably want to know why it was in that state.  To diagnose the issue, have GUI open side by side with CLI.
    In CLI -> tail the visualrf log
    # tail -f /var/log/visualrf/visualrf.log
    In the GUI
    navigate to vrf
    go to the floor plan
    toggle on / off the heatmap
    Do you see any error crashes in the log?
    Restarting VRF may resolve the issue temporarily, but doing the above can get the data that's needed for troubleshooting.
