Hello, I have a problem to connect RAP5WN to Aruba 650, Ver. 6.3.1.2.
  • 1.  Hello, I have a problem to connect RAP5WN to Aruba 650, Ver. 6.3.1.2.
    Posted Mar 07, 2014 07:31 AM
    I have a problem to connect RAP5WN to Aruba 650, Ver. 6.3.1.2 as RAP. I can see isakmp and ipsec SAs, I can see RAP "up" in "ap database", but there is flag Rc2ID and there is no connectivity. Does anybody have an idea what to do?
  • 2.  RE: Hello, I have a problem to connect RAP5WN to Aruba 650, Ver. 6.3.1.2.
    Posted Mar 07, 2014 07:59 AM
    Type "show log system 50" and see if you can see any errors.
  • 3.  RE: Hello, I have a problem to connect RAP5WN to Aruba 650, Ver. 6.3.1.2.
    Posted Mar 07, 2014 08:04 AM
    I can see just this
    Mar 3 16:47:04 :305056:  <WARN> |stm|  AP 00:0b:86:66:3a:d0 No response from AP for LOG_CONFIG request for 3614 sec; deleting AP.
    Mar 7 11:02:28 :325048:  <ERRS> |authmgr|  GSM delete failed for mac-user 00:00:00:00:00:00 with error 'ERROR_HTBL_KEY_NOT_FOUND'
    Mar 7 11:22:39 :325048:  <ERRS> |authmgr|  GSM delete failed for mac-user 00:00:00:00:00:00 with error 'ERROR_HTBL_KEY_NOT_FOUND'
    Mar 7 11:32:07 :303022:  <WARN> |AP 00:0b:86:66:3a:d0@10.1.1.35 nanny|  Reboot Reason: No reboot message found.
    Mar 7 11:32:39 :325048:  <ERRS> |authmgr|  GSM delete failed for mac-user 00:00:00:00:00:00 with error 'ERROR_HTBL_KEY_NOT_FOUND'
    Mar 7 12:32:30 :305056:  <WARN> |stm|  AP 00:0b:86:66:3a:d0 No response from AP for LOG_CONFIG request for 3614 sec; deleting AP.
    Mar 7 12:58:57 :303022:  <WARN> |AP 00:0b:86:66:3a:d0@10.1.1.39 nanny|  Reboot Reason: No reboot message found.
    Mar 7 12:59:09 :325048:  <ERRS> |authmgr|  GSM delete failed for mac-user 00:00:00:00:00:00 with error 'ERROR_HTBL_KEY_NOT_FOUND'
    Mar 7 13:59:13 :305056:  <WARN> |stm|  AP 00:0b:86:66:3a:d0 No response from AP for LOG_CONFIG request for 3614 sec; deleti
  • 4.  RE: Hello, I have a problem to connect RAP5WN to Aruba 650, Ver. 6.3.1.2.
    Posted Mar 07, 2014 08:06 AM
    In the AP-Group that the RAP5WN is in, is there a Virtual AP, or WLAN?
  • 5.  RE: Hello, I have a problem to connect RAP5WN to Aruba 650, Ver. 6.3.1.2.
    Posted Mar 07, 2014 08:15 AM
    RAP is in ap group rap
    There is:
    wlan virtual-ap "Demro-vap_prof"
       aaa-profile "Demro-aaa_prof"
       ssid-profile "Demro-ssid_prof"
       vlan 1
    wlan virtual-ap "home-1"
       vlan 20
       forward-mode split-tunnel
       rap-operation always
    wlan virtual-ap "rap-ap"
       vlan 20
    ap provisioning-profile "default"
    ap provisioning-profile "rap"
       remote-ap
       master set "demro.dyndns.org"
    rf arm-rf-domain-profile
       arm-rf-domain-key "50e56550be5d0d23b64733c33a81e7e8"
    ap-group "default"
    ap-group "rap"
       virtual-ap "rap-ap"
       enet1-port-profile "NoAuthWiredPort"
       enet2-port-profile "NoAuthWiredPort"
       enet3-port-profile "NoAuthWiredPort"
       enet4-port-profile "NoAuthWiredPort"
       ap-system-profile "rap"
  • 6.  RE: Hello, I have a problem to connect RAP5WN to Aruba 650, Ver. 6.3.1.2.
    Posted Mar 07, 2014 08:19 AM
    Does VLAN 20 exist on the controller?  Type "show profile-errors"
  • 7.  RE: Hello, I have a problem to connect RAP5WN to Aruba 650, Ver. 6.3.1.2.
    Posted Mar 07, 2014 08:24 AM
    Invalid Profiles ---------------- Profile                   Error -------                   ----- wlan virtual-ap "home-1"  Error: Remote-AP "always" virtual-ap must have bridge forwarding mode
    (aruba-master) #
    VLAN 20 is there:
    interface vlan 20
            ip address 192.168.20.1 255.255.255.224
            operstate up
    (without operstate up it was down)
    ip dhcp pool RemClients
     default-router 192.168.20.1
     network 192.168.20.0 255.255.255.224
     authoritative
  • 8.  RE: Hello, I have a problem to connect RAP5WN to Aruba 650, Ver. 6.3.1.2.
    Posted Mar 07, 2014 08:34 AM
    Is there an LMS-IP in the AP system profile RAP?  If so, please remove it.
  • 9.  RE: Hello, I have a problem to connect RAP5WN to Aruba 650, Ver. 6.3.1.2.
    Posted Mar 07, 2014 09:15 AM
    I have removed it. But it is the same. After reset of RAP I can see "upgrading", then "rebooting", after reboot it ends up with "up", flag "Rc2ID".
    AP Database
    Name               Group    AP Type  IP Address    Status              Flags  Switch IP    Standby IP
    00:0b:86:66:3a:d0  rap      RAP-5WN  10.1.1.44     Up 6m:34s           Rc2ID  192.168.1.2  0.0.0.0
    00:1a:1e:10:15:37  default  93H      192.168.1.95  Up 22d:20h:38m:19s         192.168.1.2  0.0.0.0
    00:24:6c:cb:55:a9  default  105      192.168.1.94  Up 22d:20h:37m:56s         192.168.1.2  0.0.0.0
    00:24:6c:cc:5b:92  default  93       192.168.1.97  Up 22d:20h:38m:5s          192.168.1.2  0.0.0.0
    Maybe I have some bad configuration. Can I find some functional configuration example?
  • 10.  RE: Hello, I have a problem to connect RAP5WN to Aruba 650, Ver. 6.3.1.2.
    Posted Mar 07, 2014 09:17 AM
    Type "show ap image version" to see what image the RAP has.  This will only work when the RAP is connected to the controller.
    Try also changing it to the default ap group and see if it comes up.
  • 11.  RE: Hello, I have a problem to connect RAP5WN to Aruba 650, Ver. 6.3.1.2.
    Posted Mar 07, 2014 09:24 AM
    I can see it now. Is it "offline" information, which is not true after reboot of AP?
    When RAP was in local network it worked without any problem. But so far I can not get it working as RAP.
    (aruba-master) #show ap image version
    AP Image Versions On Controller ------------------------------- 6.3.1.2(p4build@corsica.arubanetworks.com)#41362 Wed Dec 18 15:41:23 PST 2013 6.3.1.2(p4build@corsica.arubanetworks.com)#41362 Wed Dec 18 16:16:17 PST 2013
    Access Points Image Version --------------------------- AP            Running Image Version String                                                   Flash (Production) Image Version String                                        Flash (Provisioning/Backup) Image Version String           Matches  Num Matches  Num Mismatches  Bad Checksums  Bad Provisioning Checksums  Image Load Status --            ----------------------------                                                   ---------------------------------------                                        ------------------------------------------------           -------  -----------  --------------  -------------  --------------------------  ----------------- 10.1.1.44     6.3.1.2(p4build@corsica.arubanetworks.com)#41362 Wed Dec 18 15:41:23 PST 2013  6.3.1.2(p4build@corsica.arubanetworks.com)#41362 Wed Dec 18 15:41:23 PST 2013  5.0.4.15(p4build@stan)#41905 Thu Jan 23 15:49:09 PST 2014  Yes      1            0               0              0                           Done 192.168.1.95  6.3.1.2(p4build@corsica.arubanetworks.com)#41362 Wed Dec 18 16:16:17 PST 2013  6.3.1.2(p4build@corsica.arubanetworks.com)#41362 Wed Dec 18 16:16:17 PST 2013
