[HELP] AMP report
  • 1.  [HELP] AMP report
    Posted Sep 29, 2016 02:36 AM
    Airwave version AMP™ 8.0.9.1
    I have some question to use AMP report function
    1, How to generate report data per AP
    2, if it possible to generata the data every 5 minunte and send them to a FTP server?
    Thank you very much in advanced!
    Best regards
  • 2.  RE: [HELP] AMP report
    Posted Sep 29, 2016 05:27 AM
    What kind of report do you need?  That will determine what you would do.
  • 3.  RE: [HELP] AMP report
    Posted Sep 29, 2016 08:35 AM
    Current report I got from AMP is a summary report including all the APs in a cluster, I would like to have a report ONLY for a specific AP.  Please guide.
    Thanks.
  • 4.  RE: [HELP] AMP report
    Posted Oct 04, 2016 10:48 AM
    Hi Selric,
    There are two ways you could run reports for a specific AP,
    1. Go to AP/devices --> Click on Edit option for the devices list --> Select the AP for which you need to run the report, from device action select the option "run report for selected device"
    2. Go to reports --> Definitions --> Add new definition --> select the topic, under report restrictions --> device search filter, provide the specific AP MAC or Name.
    Vishnu
