help configuring AP 125 for first time
  • 1.  help configuring AP 125 for first time
    Posted Jun 11, 2013 01:09 PM
    hi,
    I have unpacked wireless access point AP125.  In the command prompt, it does print "BOOTP broadcast 5 Retry count exceeded; starting again".  Looks like we need to load OS in that.  Is that correct?
    Please clarify few things:
    1. Do we need Mobility Controller to configure anything on the AP after loading OS.  Or with standalone AP I can configure it.
    2. I have 3600 mobility controller. Is that OK?
    thanks
    uv.
    #3600
  • 2.  RE: help configuring AP 125 for first time
    Posted Jun 11, 2013 01:17 PM
    That message means that the access point is not getting DHCP.
  • 3.  RE: help configuring AP 125 for first time
    Hello what you need to do  is a way of that AP 125 to find that Wireless controller
    1-On your DNS server create a new record A with the name aruba-master  and give it the IP address of the Wireless controller
    2-On the vlan you are connecting the AP125 give it IP with DHCP and of course onthe dhcp server tell it that his primary dhcp server is your DNS server which you put the record A of aruba-master
    3-At this point the AP should be able to communicate with the Controller
    Be sure that the Vlan of the AP 125 can reach the IP of the wireless controller!
    On the controller under configuration  on the tab that it says control plane security before doing all that check if the CPsec is on or off
    If its off then you have to do nothing... if it on be sure you have autocert enrollment so the AP can get his Cert automcatically... after you done provisioning the AP then click off the autcert enrollement
    i hopte this helps you
    Cheers
    Carlos
  • 4.  RE: help configuring AP 125 for first time
    Removing my answer, cjoseph and nightshade answered it already
  • 5.  RE: help configuring AP 125 for first time
    Posted Jun 13, 2013 01:11 PM
    Thanks a lot for your reply.  PLease clarify my following doubts:
    1. I got into console of AP 125, and whatever I type, it says 'Permission Denied'.  Is it possible for me to configure SSID in the AP without using mobility controller.
    2. which file in the AP 125 have the start-up configuration stored.
    thanks
    uv.
  • 6.  RE: help configuring AP 125 for first time
    Posted Jul 02, 2013 05:01 AM
    1. No, you can't use an AP 125 stand alone
    2. unsure, but you shouldn't have to mess with it.
  • 7.  RE: help configuring AP 125 for first time
    Posted Nov 05, 2018 03:38 AM
    I have 2 AP-125. Can you please tell me which controller model does support them? Or can I use a virtual controller?
  • 8.  RE: help configuring AP 125 for first time
    Posted Nov 05, 2018 07:17 AM
    The AP-125 has been discontinued.  There is no Instant version of that access point.  https://www.arubanetworks.com/support-services/end-of-life/
    The last version of ArubaOS supported by that access point is ArubaOS 6.4.  Any controller that runs ArubaOS 6.4 should be able to run that access point.
  • 9.  RE: help configuring AP 125 for first time
    Posted Nov 05, 2018 08:24 AM
    Thanks a lot cjoseph for the great info. Do you know any controller models?
  • 10.  RE: help configuring AP 125 for first time
    Posted Nov 05, 2018 08:56 AM
    From the datasheet here:  https://www.arubanetworks.com/assets/ds/DS_7200Series.pdf
    All of the 600-series controllers support 6.4.x
  • 11.  RE: help configuring AP 125 for first time
    Posted Nov 05, 2018 04:17 PM
    Im eyeing on 2400 controller with OS 5.0. You think that is cool enough? Or get a higher model?
  • 12.  RE: help configuring AP 125 for first time
    Posted Nov 05, 2018 05:07 PM
    What kind of network are you planning to deploy?  There are newer instant APs that do not require a controller...
  • 13.  RE: help configuring AP 125 for first time
    Posted Nov 06, 2018 10:49 AM
    I have a simple network to build. 10 users. 2 AP-125. One 24 port main switch. I have found on ebay:
    • 3200XM 4 Port
    • 2400 Controller 24 FE Ports 2 GE Ports
    Which one do you recommend to go for?
  • 14.  RE: help configuring AP 125 for first time
    Posted Nov 06, 2018 10:51 AM
    The 2400 has POE to power your AP-125s, so if those were your two choices, I would prefer the 2400.  Again, all of these devices are end of life (especially the 2400), so please do your research !  I am just providing limited advice based on your circumstances.
  • 15.  RE: help configuring AP 125 for first time
    Posted Nov 06, 2018 11:35 AM
    Thanks a lot cjoseph. I know you are extensing help for me. I really appreciate it. Im kiving you kudos as well for yiur answers. I will check newer versions.
  • 16.  RE: help configuring AP 125 for first time
    Posted Nov 06, 2018 11:45 AM
    If you only have two access points, I would consider the IAP-305 or the IAP-315.  Both do not require a controller and they are currently supported.
  • 17.  RE: help configuring AP 125 for first time
    Posted Nov 06, 2018 11:48 AM
    I have already purchased the 2 x AP-125. So I better look for a controller. I think S3500-24P controller is a good option. Right?
  • 18.  RE: help configuring AP 125 for first time
    Posted Nov 06, 2018 11:59 AM
    S3500 cannot terminate APs.  It is only a switch.  It is also discontinued.
  • 19.  RE: help configuring AP 125 for first time
    Posted Nov 27, 2019 08:45 AM
    soy nuevo en aruba necesito saber si los controles permiten que en un puerto funcionen varios ap
