(Help) How to add more than 32 devices on aruba central
  • 1.  (Help) How to add more than 32 devices on aruba central
    Posted May 01, 2017 11:20 PM
    how to add more than 32 devices on aruba central?
  • 2.  RE: (Help) How to add more than 32 devices on aruba central
    Posted May 02, 2017 04:18 AM
    It should be the same procedure provided you have license/subscription to support new devicecs:
    http://community.arubanetworks.com/t5/Video/VIDEO-Adding-an-Aruba-Instant-Access-Point-to-Aruba-Central-and/ta-p/157682
  • 3.  RE: (Help) How to add more than 32 devices on aruba central
    Posted May 04, 2017 10:56 AM
    Hi Wilfredo,
    The best option to get the devices on Central is by adding the master IAP from the cluster using the cloud activation key & it will populate the list of the slave IAP's on Central as well.
    In case you would like to use the option of adding the device using mac-address/serial number, we can only add up to 32 devices by default.
    You will have to contact TAC in order to get the device quota increased on your Central Account to more than 32 devices.
