Network Management
Help logging into Airwave GUI
  • 1.  Help logging into Airwave GUI
    Posted Mar 05, 2018 12:10 AM
    New to AirWave and Linux, but I think I have Airwave installed correctly in VirtualBox. See image below.
    Not sure what to do next because I can't log into https://172.16.0.99 which is the IP address I gave AMP during the setup.
    I can ping the VirtualBox machine, but not this address. Am I supposed to be able to ping this address?
    Any other ideas?  Thanks
  • 2.  RE: Help logging into Airwave GUI
    Posted Mar 05, 2018 12:30 AM
    hi,
    have you configured ethernet bridging correctly on virtualbox?
  • 3.  RE: Help logging into Airwave GUI
    Posted Mar 05, 2018 03:27 AM
    I understand you have intalled Airwave on virtual box, may i know the host resource details?
     Have you installed virtual box on any PC and installed airwave?
    We need to allocated atleast 8GB RAM and 4 cores intel xenon processor for Airwave to up and running and also make sure you have configured correct interface.
  • 4.  RE: Help logging into Airwave GUI
    Posted Mar 05, 2018 07:28 AM
    The 'Killed' messages in your screenshot do suggest that the system ran out of memory. Please check Pavan's suggestion and double-check your assigned resources (specific memory and disk).
