Help me!!
  • 1.  Help me!!
    Posted Dec 28, 2012 12:08 AM
    Help me, i want to download AOS 6.1.4.0
    from where?
  • 2.  RE: Help me!!
    Posted Dec 28, 2012 12:28 AM
    Open a TAC case requesting access to 6.1.4.0
  • 3.  RE: Help me!!
    Posted Dec 28, 2012 01:16 AM
    i don't know , how to do TAC requesting
      tell me plz
  • 4.  RE: Help me!!
    MVP EXPERT
    Posted Dec 28, 2012 02:41 AM
    If you follow the link below you can open a case via email or phone
    http://www.arubanetworks.com/support-services/
  • 5.  RE: Help me!!
    Posted Dec 28, 2012 05:29 AM
    Why you want that?
    As far i know 6.1.4.0 is not for production network...
    Instead of that you could download the .6.2.0 versoin... just check the release note before upgrading.
  • 6.  RE: Help me!!
    Posted Dec 28, 2012 06:35 AM
    I think that the RAP3s are only supported on the 6.1.4 code
  • 7.  RE: Help me!!
    Posted Dec 28, 2012 08:15 AM
    Thats the minimum  release supported to deoploy it as remote AP
    If you read the release notes of the 6.2 you will see this
    RAP-3WN and RAP-3WNP Remote Access Points
    This release of ArubaOS introduces support for RAP-3WN and RAP-3WNP access points (APs). The Aruba
    RAP-3WN and RAP-3WNP are single-radio, single-band wireless APs that support the IEEE 802.11n
    standard for high-performance WLAN.
    Do you have Rap3 that you need to deploy as Remote AP?
    Remember to read the release note and the readme file before upgrading to this version... its really important!
  • 8.  RE: Help me!!
    Posted Jan 01, 2013 09:49 PM
    thx you , for Anwser !!
