Help me figure out to classify requests to these services with different EAP-TLS Methods?
  • 1.  Help me figure out to classify requests to these services with different EAP-TLS Methods?
    Posted May 28, 2020 11:09 PM
    I want to have 2 services that I'm having trouble figuring out how to classify the incoming requests to a service.
    The called-station SSID is the same, the NAD IP and SSID etc are the same, so I am finding it difficult to classify the service.
    The only difference between the services (why I need 2) will be that one uses the standard EAP-TLS method and the other uses a custom EAP-TLS method with "Authorization Required" unticked. This custom one is used to authenticate clients against Microsoft InTune as shown by Mitchell in this YouTube video. I tried adding both EAP-TLS methods to the same Service but got an error.
    So in total I will have 3 types of devices connecting to this same SSID on same NAD:
    Service #1
    1. AD-managed device with username authentication against EAP-MSCHAPv2 and Active Directory as source
    2. AD-managed device with certificate authentication against normal EAP-TLS and Active Directory as source
    Service #2
    3. InTune managed device with Intune Extension authentication against special EAP-TLS with "Authorization Required" unticked.
    The way I have things set up currently I don't think I will ever see the request just 'fail-through' and match the next service in the list, because it is matching the first service despite the wrong Authentication Method.
    Any ideas are welcome.
  • 2.  RE: Help me figure out to classify requests to these services with different EAP-TLS Methods?
    Posted May 28, 2020 11:55 PM
    Use a single service with PEAPv0/EAP-MSCHAPv2 and EAP-TLS with authorization disabled and handle any authorization logic in your enforcement policy.
  • 3.  RE: Help me figure out to classify requests to these services with different EAP-TLS Methods?
    Posted Jun 02, 2020 12:43 AM
    Thanks I will try this and report back here.
