Help needed on unknown error message, Aruba 3400
  • 1.  Help needed on unknown error message, Aruba 3400
    Posted Nov 13, 2012 07:24 AM
    after a reboot (at least I suppose this did not show up before), a customers Aruba 3400 Controller is showing the following error messages in the error log:
    Nov 13 07:49:43 |fpapps| |configuration| Configuration error: Only Physical Interface 24662 in sampling_eth_stats, snmp_switch.c:7036000.
    This message is repeated every 1-2 minutes or so. Where does this message want me to investigate in?
    Thanks for every hint!
    Cheers!
    #3400
  • 2.  RE: Help needed on unknown error message, Aruba 3400
    Posted Nov 13, 2012 07:39 AM
    What version of ArubaOS?
    On the commandline type "show logging level verbose".  Do you have anything on debug?
    EDIT:  For now it looks like it is cosmetic and got added accidentally.  Stay tuned.
  • 3.  RE: Help needed on unknown error message, Aruba 3400
    Posted Nov 13, 2012 07:45 AM
    Aruba OS Version = 5.0.4.5
    Output of "show logging level verbose" =
    (Aruba3400) #show logging level verbose
    LOGGING LEVELS
    Facility Level Sub Category Process
    network debugging N/A N/A
    network debugging all N/A
    network debugging dhcp N/A
    network debugging mobility N/A
    network debugging packet-dump N/A
    security debugging N/A N/A
    security debugging aaa N/A
    security debugging all N/A
    security debugging cpsec N/A
    security debugging db N/A
    security debugging dot1x N/A
    security debugging firewall N/A
    security debugging ike N/A
    security debugging kerberos N/A
    security debugging mobility N/A
    security debugging ntlm N/A
    security debugging packet-trace N/A
    security debugging vpn N/A
    security debugging webserver N/A
    system debugging N/A N/A
    system debugging all N/A
    system debugging configuration N/A
    system debugging messages N/A
    system debugging snmp N/A
    system debugging webserver N/A
    user debugging N/A N/A
    user debugging all N/A
    user debugging captive-portal N/A
    user debugging dot1x N/A
    user debugging radius N/A
    user debugging vpn N/A
    wireless debugging N/A N/A
    wireless debugging all N/A
    I had some AP debugging active some while ago, but not longer active right now.
    Thanks!
  • 4.  RE: Help needed on unknown error message, Aruba 3400
    Posted Nov 13, 2012 07:48 AM
    Please turn off all that debugging.  It does enact a penalty.  Everything should be on warning....
  • 5.  RE: Help needed on unknown error message, Aruba 3400
    Posted Nov 13, 2012 08:01 AM
    Debugging now turned to warning:
    (Aruba3400) # show logging level verbose
    LOGGING LEVELS
    network warnings N/A N/A
    network warnings all N/A
    network warnings dhcp N/A
    network warnings mobility N/A
    network warnings packet-dump N/A
    security warnings N/A N/A
    security warnings aaa N/A
    security warnings all N/A
    security warnings cpsec N/A
    security warnings db N/A
    security warnings dot1x N/A
    security warnings firewall N/A
    security warnings ike N/A
    security warnings kerberos N/A
    security warnings mobility N/A
    security warnings ntlm N/A
    security warnings packet-trace N/A
    security warnings vpn N/A
    security warnings webserver N/A
    system warnings N/A N/A
    system warnings all N/A
    system warnings configuration N/A
    system warnings messages N/A
    system warnings snmp N/A
    system warnings webserver N/A
    user warnings N/A N/A
    user warnings all N/A
    user warnings captive-portal N/A
    user warnings dot1x N/A
    user warnings radius N/A
    user warnings vpn N/A
    wireless warnings N/A N/A
    wireless warnings all N/A
    However, logging errors still seen, repeated every minute:
    Nov 13 13:58:12 <fpapps 399807> <ERRS> |fpapps| |configuration| Configuration error: Only Physical Interface 24700 in sampling_eth_stats, snmp_switch.c:7036000.
    Nov 13 13:58:12 <fpapps 399807> <ERRS> |fpapps| |configuration| Configuration error: Only Physical Interface 24701 in sampling_eth_stats, snmp_switch.c:7036000.
    Nov 13 13:58:12 <fpapps 399807> <ERRS> |fpapps| |configuration| Configuration error: Only Physical Interface 24702 in sampling_eth_stats, snmp_switch.c:7036000.
    Nov 13 13:58:12 <fpapps 399807> <ERRS> |fpapps| |configuration| Configuration error: Only Physical Interface 24703 in sampling_eth_stats, snmp_switch.c:7036000.
  • 6.  RE: Help needed on unknown error message, Aruba 3400
    Posted Nov 13, 2012 08:05 AM
    That message is cosmetic and can be ignored.  It should be removed in a future version of code.
    You should only have:
    (host) (config) #show logging level verbose
    LOGGING LEVELS
     Turn the others off:
    no logging warnings network subcat packet-dump
    ..etc
  • 7.  RE: Help needed on unknown error message, Aruba 3400
    Posted Nov 13, 2012 12:17 PM
    OK, thanks for the info!
    Cheers!
