Wired Intelligent Edge
HELP - (NEWER ARUBA USER) - DOING FAILOVER with 2 switchs ARUBA 2930f
  • 1.  HELP - (NEWER ARUBA USER) - DOING FAILOVER with 2 switchs ARUBA 2930f
    Posted Jul 16, 2018 09:36 AM
    I have a particular tipology, the 2 aruba will receive each 1 uplink from the "MAIN" provider and 1 uplink for the "backup line" from another provider.
    i configure VSF for the redudancy but now the 2 switch are configured like 1 single switch and when i connect the 2 uplinks, i create a loop :s so i search a little bit and i founded a topic who spoke about MADVLAN but i tryed it and i didn't have more result.
    Have you an idea to do that?
    Here are the running config.
    Running configuration:
    ; hpStack_WC Configuration Editor; Created on release #WC.16.06.0006
    ; Ver #13:4f.f8.1c.9b.3f.bf.bb.ef.7c.59.fc.6b.fb.9f.fc.ff.ff.37.ef:05
    hostname "MSW001"
    vsf
       enable domain 1
       member 1
          type "JL258A" mac-address 94f128-8cf060
          priority 160
          link 1 1/7-1/8
          link 1 name "I-Link1_1"
          link 2 name "I-Link1_2"
          exit
       member 2
          type "JL258A" mac-address 94f128-8cf010
          priority 150
          link 1 2/7-2/8
          link 1 name "I-Link2_1"
          link 2 name "I-Link2_2"
          exit
       port-speed 1g
       exit
    ip default-gateway 192.168.8.1
    interface 1/1
       no power-over-ethernet
       exit
    interface 1/2
       exit
    interface 1/3
       exit
    interface 1/4
       exit
    interface 1/5
       exit
    interface 1/6
       exit
    interface 1/7
       exit
    interface 1/8
       exit
    interface 2/1
       exit
    interface 2/2
       exit
    interface 2/3
       exit
    interface 2/4
       exit
    interface 2/6
       exit
    interface 2/7
       exit
    interface 2/8
       exit
    snmp-server community "aruba"
    vlan 1
       name "Stack_MSW001"
       untagged 1/1-1/6,1/9-1/10,2/1-2/6,2/9-2/10
       ip address 192.168.8.5 255.255.255.0
       exit
  • 2.  RE: HELP - (NEWER ARUBA USER) - DOING FAILOVER with 2 switchs ARUBA 2930f
    Posted Jul 16, 2018 04:21 PM
    Hi
    More info on the link below. Setup a separate vlan between the two units not over link to the isp
    http://community.arubanetworks.com/t5/Campus-Switching-and-Routing/VLAN-MAD-in-2930F/m-p/300856
  • 3.  RE: HELP - (NEWER ARUBA USER) - DOING FAILOVER with 2 switchs ARUBA 2930f
    Posted Jul 17, 2018 02:55 AM
    Ok thanks, but i can't use vlan. the provider the main line and the backup line must be on the same lan, they ney need to see each other for the failover.
    the switch receive the main line (uplink), backup line (uplink), 2 connections firewall.
    and all of them need to see each other.
    thanks for your answer
  • 4.  RE: HELP - (NEWER ARUBA USER) - DOING FAILOVER with 2 switchs ARUBA 2930f
    Posted Jul 17, 2018 03:00 AM
    You don’t need mad vlan on all links. Just use a separate one
  • 5.  RE: HELP - (NEWER ARUBA USER) - DOING FAILOVER with 2 switchs ARUBA 2930f
    Posted Jul 17, 2018 03:01 AM
    Maybe you can use lacp to the uplinks
  • 6.  RE: HELP - (NEWER ARUBA USER) - DOING FAILOVER with 2 switchs ARUBA 2930f
    Posted Jul 17, 2018 11:31 AM
    Okay, so i have to do?
    VLAN 1
    untagged 1/3,1/4,1/5,1/6,2/3,2/4,2/5,2/6
    Uplink on port 1
    SWITCH 1:
    trunk 1/1,2/1 trk1 lacp
    vlan 11
    tagged trk1
    trunk 1/2,2/2 trk2 lacp
    vlan12
    tagged trk2
    trk1
    mode trunk
    allowed vlan 1,11,12
    no shut
    trk2
    mode trunk
    allowed vlan1,11,12
    no shut
    SWITCH2:
    same configuration
  • 7.  RE: HELP - (NEWER ARUBA USER) - DOING FAILOVER with 2 switchs ARUBA 2930f
    Posted Jul 17, 2018 12:55 PM
    Hi Eonix,
    That looks correct, in your config, if trk1 completely fails across both stack members, trk2 can take over.
    Justin
    JUSTIN NOONAN
    TECHNICAL MARKETING ENGINEER – ARUBA WIRED INTELLIGENT EDGE
    O: +1 916 540 1748   |   justin.noonan@hpe.com
    8000 FOOTHILLS BLVD  |  ROSEVILLE, CA 95747 USA
    GARTNER AGREES: VISIONARY LEADER IN CAMPUS NETWORKING
  • 8.  RE: HELP - (NEWER ARUBA USER) - DOING FAILOVER with 2 switchs ARUBA 2930f
    Posted Jul 18, 2018 03:25 AM
    but i have a question :
    From when a trunk link is down for the failover?
    Because i will made a trunk with 2 ports. In the trk1 , if 1 of them is down, the 2nd port take all bandwith or the switch, switch with the other trunk trk2?
  • 9.  RE: HELP - (NEWER ARUBA USER) - DOING FAILOVER with 2 switchs ARUBA 2930f
    Posted Jul 18, 2018 04:15 AM
    Hi
    When one port in a two port trunk goes down the trunk works on that one port.
  • 10.  RE: HELP - (NEWER ARUBA USER) - DOING FAILOVER with 2 switchs ARUBA 2930f
    Posted Jul 18, 2018 06:30 AM
    The configuration work well. Thanks you very much
  • 11.  RE: HELP - (NEWER ARUBA USER) - DOING FAILOVER with 2 switchs ARUBA 2930f
    Posted Jul 18, 2018 08:21 AM
    Thanks for the update.
