Hi, I'am trying to setup Aruba Virtual Controller and ClearPass Guest for my new Guest-Wifi, but i cant get to work, does Aruba have som documentation setting up IAP with GuestSSID and external CaptivePortal?
Best regards
Niklas
Great thanks, I've got that part :)
Do you know if there is any documentation on the Clearpass?
http://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=12979
http://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=13387
