I have built a home lab to test out clustering and have a mixture of physical and virtual appliances, I have an AP 325 which was working when used just with the 7002 in standalone, but now I am unable to get past the provisioning stage. I am trying to troubleshoot and can figure out why its not working.
LAB Environment
VMCr - 8.9
Managed Network
Domain
UBT:
7005 - 192.168.1.225 Version 8.7.1.1
WLAN-Cluster:
VMC 1 - 192.168.1.221 Version 8.8.0.1
VMC 2 - 192.168.1.221 Version 8.8.0.1
AP is a AP-325 (pervious working in standalone)
Console on the AP has
Running ADP...Done. Master is 192.168.1.225
[ 60.574258] Initializing Pktlogs for 11ac
[ 60.574289] Initializing Pktlogs for 11ac
AP rebooted Wed Dec 31 16:01:49 PST 1969; SAPD: Reboot after image upgrade failed: 65280
shutting down watchdog process (nanny will restart it)...
<<<<< Welcome to the Access Point >>>>>
~ # [ 66.106747] Kernel watchdog refresh ended on core 1.
[ 66.113027] Kernel watchdog refresh ended on core 0.
The system is going down NOW !!
Sending SIGTERM to all processes.
Please stand by while rebooting the system.
[ 118.937706] Restarting system.
[ 118.961699] Going down for restart now
VMCr
(VMM-01-LAB) [mynode] #show switches
All Switches
IP Address IPv6 Address Name Location Type Model Version Status Configuration State Config Sync Time (sec) Config ID
192.168.1.221 None VMM-01-LAB Building1.floor1 conductor ArubaMM-VA 8.9.0.0_81161 up UPDATE SUCCESSFUL 0 46
192.168.1.222 None VMC-01-LAB Building1.floor1 MD ArubaMC-VA 8.8.0.1_80393 up UPDATE SUCCESSFUL 0 46
192.168.1.223 None VMC-02-LAB Building1.floor1 MD ArubaMC-VA 8.8.0.1_80393 up UPDATE SUCCESSFUL 0 46
192.168.1.225 None WLC-01-LAB Building1.floor1 MD Aruba7005 8.7.1.1_78245 up UPDATE SUCCESSFUL 0 46
VMM-01-LAB) [mynode] #show ap database long
AP Database
Name Group AP Type IP Address Status Flags Switch IP Standby IP Wired MAC Address Serial # Port FQLN Outer IP User
f0:5c:19:cb:53:64 default 325 192.168.1.30 Down 192.168.1.225 0.0.0.0 f0:5c:19:cb:53:64 CNBJHN70BF N/A N/A
I have checked power (it was working with this switch before) - drawing 7w as expected
AP is getting a DHCP IP address
The firmware was on 8.9 but I have reverted to the original firmware to troubleshoot.
I have also factory reset the AP, but it make no difference.
I've tried factory reset the AP.
What can i do to find out what the issue is.
Andrew Partridge
