We have 6 controllers in 3 sites. 2 controllers per site and only using 1 clearpass. There is a certificate error everytime after clearpass captive portal guest. Where should we place the certificate? Can we only use 1 public certificate? Thank you!
You need a certificate for the controllers and a certificate for ClearPass.
Please take a look at the link below and/or reach out to your Aruba ClearPass partner.
http://community.arubanetworks.com/t5/Controller-Based-WLANs/ArubaOS-Default-Certificate-Revocation-FAQ-Controllers/ta-p/275809
