Hi to all,
first of all, i'm a newbie.
I have this problem and i'm not sure which is the best solution: i have a 5130 EI switch in my HQ with STP enabled, and i have a remote office connected via Wireless link and an 2930F aruba switch with STP enabled.
We have choosed MSTP config.
So, I have only ONE port that link my HQ site to remote site, and is automatically set by 5130 as stp root port.
i realized that, when the wireless link fail, my entire HQ network flap and temporary go down because the 5130 observe a topology change.
Our actual present topology has no redundant links for this remote site and wireless link go down one or two times at month.
I'm not sure if i can disable stp on a single port (and i think not) so.. how i can prevent the 5130 to calcolate stp topology on that port (and fail the entire network)?
I hope I have been clear enough...
Thanks in advance to all.
#STP
