Comware
  • 1.  Help with GRE tunnel in comware7
    Posted Feb 25, 2016 07:01 AM
    HI,
    I've trying to setup a gre tunnel between an Comware7 switch and a ubuntu server
    Ubuntu server looks ok, I can see GRE packets leaving the network however the comware tun is Down Down
    Comware7
    [HP-5900-Stack]int tun 0
    [HP-5900-Stack-Tunnel0]dis thi
    interface Tunnel0 mode gre
     ip address 192.168.70.1 255.255.255.0
     source Vlan-interface40
     destination 192.168.10.117
    return
    [HP-5900-Stack]dis int tu b
    Brief information on interface(s) under route mode:
    Link: ADM - administratively down; Stby - standby
    Protocol: (s) - spoofing
    Interface Link Protocol Main IP Description
    Tun0 DOWN DOWN 192.168.70.1
    [HP-5900-Stack]dis int vl 40 b
    Vlan40 UP UP 192.168.10.20
    [HP-5900-Stack]ping 192.168.10.117
    Ping 192.168.10.117 (192.168.10.117): 56 data bytes, press CTRL_C to break
    56 bytes from 192.168.10.117: icmp_seq=0 ttl=64 time=2.973 ms
    56 bytes from 192.168.10.117: icmp_seq=1 ttl=64 time=1.080 ms
    --- Ping statistics for 192.168.10.117 ---
    5 packet(s) transmitted, 5 packet(s) received, 0.0% packet loss
    round-trip min/avg/max/std-dev = 1.011/1.419/2.973/0.777 ms
    [HP-5900-Stack]
    Ubuntu
    auto gre1
    iface gre1 inet tunnel
      mode gre
      netmask 255.255.255.0
      address 192.168.70.2
      dstaddr 192.168.70.1
      endpoint 192.168.10.20
      local 192.168.10.117
      ttl 255
    root@erspan:~#
    root@erspan:~# tcpdump -npi eth0 proto GRE
    tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
    listening on eth0, link-type EN10MB (Ethernet), capture size 65535 bytes
    12:32:51.901317 IP 192.168.10.117 > 192.168.10.20: GREv0, length 60: IP6 fe80::5efe:c0a8:a75 > ff02::2: ICMP6, router solicitation, length 16
    12:32:55.909422 IP 192.168.10.117 > 192.168.10.20: GREv0, length 60: IP6 fe80::5efe:c0a8:a75 > ff02::2: ICMP6, router solicitation, length 16
    12:32:59.917338 IP 192.168.10.117 > 192.168.10.20: GREv0, length 60: IP6 fe80::5efe:c0a8:a75 > ff02::2: ICMP6, router solicitation, length 16
    I"m not sure what I"m doing wrong, I did see some comware5 howto's that show you need a service loop back but I couldn't see how to do this on comware7 ?
    Any help would be great
    Regards, Daniel
    #tunnel
    #GRE
  • 2.  RE: Help with GRE tunnel in comware7
    Posted Feb 26, 2016 07:18 AM
    OK I've got this working now.
    In order for the gre tunnel to become active you need to bind a tunnel service loopback to a physical interface. The interface can be just a free port wihtout any cabled connected to it
    Add service loop-back
    [HP-5900-Stack-Ten-GigabitEthernet1/0/20]dis this
    interface Ten-GigabitEthernet1/0/20
     port link-mode bridge
     shutdown
    return
    [HP-5900-Stack-Ten-GigabitEthernet1/0/20]port service-loopback group 1
    All configurations on the interface will be lost. Continue?[Y/N]:y
    return
    Now my GRE tunnel is up
    [HP-5900-Stack]dis int Tunnel 0
    Tunnel0
    Current state: UP
    Line protocol state: UP
    Description: Tunnel0 Interface
    Bandwidth: 64kbps
    Maximum Transmit Unit: 1476
    Internet Address is 192.168.70.1/24 Primary
    Tunnel source 192.168.10.20, destination 192.168.10.117
    Tunnel keepalive disabled
    Tunnel TTL 255
    Tunnel protocol/transport GRE/IP
        GRE key disabled
        Checksumming of GRE packets disabled
    Last clearing of counters: Never
    Last 300 seconds input rate: 0 bytes/sec, 0 bits/sec, 0 packets/sec
    Last 300 seconds output rate: 0 bytes/sec, 0 bits/sec, 0 packets/sec
    Input: 0 packets, 0 bytes, 0 drops
    Output: 0 packets, 0 bytes, 0 drops
    [HP-5900-Stack]ping 192.168.70.2
    Ping 192.168.70.2 (192.168.70.2): 56 data bytes, press CTRL_C to break
    56 bytes from 192.168.70.2: icmp_seq=0 ttl=64 time=3.631 ms
    56 bytes from 192.168.70.2: icmp_seq=1 ttl=64 time=1.211 ms
    56 bytes from 192.168.70.2: icmp_seq=2 ttl=64 time=0.987 ms
    56 bytes from 192.168.70.2: icmp_seq=3 ttl=64 time=1.003 ms
    56 bytes from 192.168.70.2: icmp_seq=4 ttl=64 time=0.980 ms
    --- Ping statistics for 192.168.70.2 ---
    round-trip min/avg/max/std-dev = 0.980/1.562/3.631/1.038 ms
    [HP-5900-Stack]
    Below is a diagram I put together to document this setup
  • 3.  RE: Help with GRE tunnel in comware7
    Posted Mar 08, 2016 12:55 PM
    And any ideas how to get OSPF peering across a GRE tunnel on Comware 7?  We are trying to peer OSPF but the multicast hellos are received on the physical interface but not passed up to the Tunnel interface.   We've tried "service-loopback group 1 type tunnel" and "service-loopback group 1 type tunnel multicast-tunnel", and we've reserved global VLANs for the service loopbacks, but no dice.  We can see the hellos on the wire with GRE encapsulation, and the physical interfaces supporting the tunnels click up received frames, but the Tunnel interfaces never see any multicast frames received.
    I can "fix" the issue by defining the Tunnel as OSPF network type NBMA and explicitly defining the peer address, but I'd rather get the problem fixed properly.  However, this uses unicast hellos and these are received on the tunnel interface, obviously,
    If we do the same with IS-IS, there's no problem, and adjacencies form straight off.  Again, not an IP multicast, and the incoming multicast counters on the Tunnel interface increment.
    I've done this on 7910 switches running 2137, and my colleague on 5900 switches just as a sanity check, with the same result.  What do we need to add for OSPF peering across a GRE tunnel?
  • 4.  RE: Help with GRE tunnel in comware7
    Posted May 10, 2016 12:06 PM
    I have be trying to get GRE tunnel UP on comware 7 - 5900 model. Tried with service-loopback binded to physical interface but still tunnel is showing down down. Can someonce help please.
