Help with IAP-VPN setup
  • 1.  Help with IAP-VPN setup
    Posted Jul 27, 2013 06:16 PM
    I'm trying to configure a RAP3 in an IAP-VPN configuration but I'm having trouble getting my client to get an ip address once the VPN is up.
    I have setup the VPN which establishes fine.
    I have created a route of 0.0.0.0 0.0.0.0  gateway = public IP of my controller
    I have created a DHCP scope as centralized L3 with VLAN = 100
    My WLAN is authentication = Open, IP address assigned from network, vlan = 100.  No access restrictions.
    When my client tries to connect to the SSID being broadcasted, it is unable to obtain an IP address.
    NoteL I have a number of RAPs (running in RAP mode) terminating on the same controller, they land on the same VLAN (100) and they work fine.
    Any help would be appreciated
  • 2.  RE: Help with IAP-VPN setup
    Posted Jul 29, 2013 09:51 AM
    Can you please post your config in a reply?  If you are on the controller, issue the show iap table command.
  • 3.  RE: Help with IAP-VPN setup
    Posted Jul 29, 2013 04:07 PM
    Please find the RAP and controller configs attached. Also, see below output form show iap table, I've highlighted my RAP
    (uktcnwc3) #show iap table
    Branch Key                                             Index     Status     Inner IP        MAC Address             Subnet
    5522637801d5a0352a5f9aa56fdce2d66c3ee361316ad2884c     10        UP         2.2.2.157       d8:c7:c8:c7:46:3b
    9b528851018450611e02bcccba3eca514876d233200a301666     7         DOWN       0.0.0.0         00:0b:86:83:0b:64
    7bf4d682015921198f9fb2c2d9694f66c85acd9405733b2557     4         UP         2.2.2.93        6c:f3:7f:ce:3c:e8
    298ea6dd01054e3fbc8c93eeac0e88ebbf934e3c15745d3e36     6         DOWN       0.0.0.0         24:de:c6:c3:44:21
    5fdb1d480136333d703517e078adafaa62ac8d86c330466688     1         DOWN       0.0.0.0         00:0b:86:83:0f:06
    a7496c14010ead593f6c26fa6b48206f58bf83e92b2252d9bf     8         UP         2.2.2.100       6c:f3:7f:ce:3c:78
    b5e7b8b30119cc2be065c727598e52e705c40f2d656a291be7     0         UP         2.2.2.178       00:0b:86:82:89:80
    ae5fd86e019a12628350283089fcfdbde6b337a626dc9ec94d     3         UP         2.2.2.91        6c:f3:7f:ce:39:fa
    eeeaf6e501837241da77e757b4dc38a76b261418b48e0963e0     5         DOWN       0.0.0.0         6c:f3:7f:ce:3c:14
    87c37e2b014a75b349d27a5f68f54b98e62efcec6a0823fb4c     2         DOWN       0.0.0.0         d8:c7:c8:ce:73:92
    Attachment(s)
    txt
    rap3cfg.txt   2 KB 1 version
  • 4.  RE: Help with IAP-VPN setup
    Posted Jul 29, 2013 04:23 PM
    Doesn't seem to want to attach my controller config, so pasting it in here,
    (xxxxnwc3) #show run
    Building Configuration...
    version 6.2
    enable secret "******"
    enable bypass
    telnet cli
    hostname "xxxxnwc3"
    clock summer-time CDT recurring last sunday march 02:00 last sunday october 02:00 -5
    clock timezone CST -6
    location "Building1.floor1"
    controller config 8
    ip NAT pool dynamic-srcnat 0.0.0.0 0.0.0.0
    ip access-list eth validuserethacl
      permit any
    netservice svc-pcoip2-tcp tcp 4172
    netservice svc-netbios-dgm udp 138
    netservice svc-snmp-trap udp 162
    netservice svc-https tcp 443
    netservice svc-dhcp udp 67 68 alg dhcp
    netservice svc-citrix tcp 2598
    netservice svc-syslog udp 514
    netservice svc-l2tp udp 1701
    netservice svc-ike udp 500
    netservice svc-smb-tcp tcp 445
    netservice svc-ica tcp 1494
    netservice svc-pptp tcp 1723
    netservice svc-sccp tcp 2000 alg sccp
    netservice svc-telnet tcp 23
    netservice svc-lpd tcp 515
    netservice svc-netbios-ssn tcp 139
    netservice svc-sip-tcp tcp 5060
    netservice svc-kerberos udp 88
    netservice svc-tftp udp 69 alg tftp
    netservice svc-pcoip-udp udp 50002
    netservice svc-pcoip-tcp tcp 50002
    netservice svc-http-proxy3 tcp 8888
    netservice svc-noe udp 32512 alg noe
    netservice svc-cfgm-tcp tcp 8211
    netservice svc-adp udp 8200
    netservice svc-pop3 tcp 110
    netservice svc-dns udp 53 alg dns
    netservice svc-rtsp tcp 554 alg rtsp
    netservice svc-msrpc-tcp tcp 135 139
    netservice svc-http tcp 80
    netservice vnc tcp 5900 5905
    netservice svc-h323-udp udp 1718 1719
    netservice svc-h323-tcp tcp 1720
    netservice svc-vocera udp 5002 alg vocera
    netservice svc-http-proxy2 tcp 8080
    netservice svc-sip-udp udp 5060
    netservice svc-nterm tcp 1026 1028
    netservice svc-noe-oxo udp 5000 alg noe
    netservice svc-natt udp 4500
    netservice svc-ftp tcp 21 alg ftp
    netservice svc-microsoft-ds tcp 445
    netservice svc-svp 119 alg svp
    netservice svc-smtp tcp 25
    netservice svc-gre 47
    netservice web tcp list "80 443"
    netservice svc-netbios-ns udp 137
    netservice svc-sips tcp 5061 alg sips
    netservice svc-smb-udp udp 445
    netservice svc-ipp-tcp tcp 631
    netservice svc-esp 50
    netservice svc-pcoip2-udp udp 4172
    netservice svc-v6-dhcp udp 546 547
    netservice svc-snmp udp 161
    netservice svc-bootp udp 67 69
    netservice svc-msrpc-udp udp 135 139
    netservice svc-ntp udp 123
    netservice svc-icmp 1
    netservice svc-ipp-udp udp 631
    netservice svc-ssh tcp 22
    netservice svc-v6-icmp 58
    netservice svc-http-proxy1 tcp 3128
    netservice svc-vmware-rdp tcp 3389
    netdestination HOME192_168
      network 192.168.0.0 255.255.0.0
    netdestination CORP-NETS
      network 10.0.0.0 255.0.0.0
      network 10.1.0.0 255.255.0.0
      network 205.203.64.0 255.255.224.0
      network 172.16.0.0 255.240.0.0
    ip access-list session icmp-acl
      any any svc-icmp  permit
    ip access-list session allowall
      any any any  permit
      ipv6  any any any  permit
    ip access-list session w19733-split-tunnel
      any any svc-dhcp  permit
      any any svc-dns  permit
      any   alias CORP-NETS any  permit
      any   alias HOME192_168 any  route src-nat
    ip access-list session iaprole
      any host 172.18.96.226 any  src-nat
    ip access-list session v6-http-acl
      ipv6  any any svc-http  permit
    ip access-list session http-acl
    ip access-list session dhcp-acl
    ip access-list session ap-uplink-acl
      any any udp 68  permit
      any host 224.0.0.251 udp 5353  permit
    ip access-list session ap-acl
      any any svc-gre  permit
      any any svc-syslog  permit
      any user svc-snmp  permit
      user any svc-snmp-trap  permit
      user any svc-ntp  permit
      user any svc-ftp  permit
    ip access-list session v6-ap-acl
      ipv6  any any svc-gre  permit
      ipv6  any any svc-syslog  permit
      ipv6  any user svc-snmp  permit
      ipv6  user any svc-snmp-trap  permit
      ipv6  user any svc-ntp  permit
      ipv6  user any svc-ftp  permit
    ip access-list session v6-logon-control
      ipv6  user any udp 68  deny
      ipv6  any any svc-v6-icmp  permit
      ipv6  any any svc-v6-dhcp  permit
      ipv6  any any svc-dns  permit
    ip access-list session h323-acl
      any any svc-h323-tcp  permit queue high
      any any svc-h323-udp  permit queue high
    aaa derivation-rules user test
    vpn-dialer default-dialer
      ike authentication PRE-SHARE ******
    user-role ap-role
     access-list session control
     access-list session v6-control
    user-role denyall
    user-role default-vpn-role
     access-list session v6-allowall
    user-role default-via-role
    user-role iaprole
    user-role stateful-dot1x
    user-role authenticated
    user-role logon
     access-list session logon-control
     access-list session captiveportal
     access-list session vpnlogon
     access-list session captiveportal6
    controller-ip vlan 96
    interface mgmt
            shutdown
    vlan 6 "Enterprise_VPN"
    vlan 96 "Enterprise_MGMT"
    vlan 100 "RAP_User_VLAN"
    vlan 500
    vlan 999
    vlan 1200
    vlan 1201
    vlan 1202
    no spanning-tree
    interface gigabitethernet 1/0
            description "GE1/0"
            trusted
            trusted vlan 1-4094
            switchport mode trunk
            switchport trunk native vlan 999
            switchport trunk allowed vlan 96,100,500,999,1200-1202
    interface gigabitethernet 1/1
            description "GE1/1"
            shutdown
            trusted vlan 1-4094
    interface gigabitethernet 1/2
            description "GE1/2"
            trusted
            trusted vlan 1-4094
            switchport trunk allowed vlan 6,999
    interface gigabitethernet 1/3
            description "GE1/3"
            shutdown
            trusted vlan 1-4094
            switchport access vlan 1203
    interface vlan 96
            ip address 172.18.96.106 255.255.252.0
    interface vlan 1
            shutdown
    interface vlan 6
            ip address 213.62.87.102 255.255.255.224
    interface vlan 100
            ip address 172.18.100.240 255.255.254.0
            ip helper-address 172.18.96.226
    master-redundancy
      master-vrrp 96
      peer-ip-address 172.18.96.107 ipsec 95f55f5a6f3f4c952fe4aef4b07746a7d8928663746e2935
    vrrp 66
      priority 120
      ip address 213.62.87.104
      vlan 6
      preempt delay 1
      no shutdown
    vrrp 96
      priority 120
      ip address 172.18.96.108
      vlan 96
      no shutdown
    ip default-gateway 213.62.87.97
    ip route 205.203.64.0 255.255.224.0 172.18.96.254
    ip route 10.1.0.0 255.255.0.0 172.18.96.254
    ip route 10.0.0.0 255.0.0.0 172.18.96.254
    ip route 172.16.0.0 255.240.0.0 172.18.96.254
    uplink disable
    crypto ipsec transform-set default-boc-bm-transform esp-3des esp-sha-hmac
    crypto ipsec transform-set default-rap-transform esp-aes256 esp-sha-hmac
    crypto ipsec transform-set default-aes esp-aes256 esp-sha-hmac
    crypto dynamic-map default-dynamicmap 10000
      set transform-set "default-transform" "default-aes"
    crypto isakmp eap-passthrough eap-tls
    crypto isakmp eap-passthrough eap-peap
    crypto isakmp eap-passthrough eap-mschapv2
    ip local pool "RAP-Inner-IP-Pool" 1.1.1.1 1.1.1.254
    ip local pool "iap-vpn-pool" 2.2.2.1 2.2.2.254
    vpdn group l2tp
    mgmt-user admin root 8853a8fb01c9c550921b62f464f6ca84e3e92234ef667aeb0a
    ip domain lookup
    ip domain-name xxx.com
    ip name-server 172.18.96.226
    country GB
    aaa authentication mac "default"
    aaa authentication dot1x "default"
       no validate-pmkid
    aaa authentication dot1x "global-802.1x auth profile"
    aaa authentication-server radius "xxxxndc0"
       host "172.18.96.226"
       key be5605ea8ab56270c06269c07517db341b2f8a0de2b5fdbd
    aaa authentication-server radius "ustwndc3"
       host "10.1.32.205"
       key 166e2a04393ae689e86bf1e95958fb3b1e52de76c4b25b28
    aaa authentication-server tacacs "ustccsec2"
       host "10.1.96.150"
       key f7949e746c34b577885d0dd3ee9b4e969a88c2733c593a49
    aaa authentication-server tacacs "ustwa010"
       host "10.1.32.146"
       key feb2b0030329a715ff744ddec0294f0ea4d04c13de703c1f
    aaa server-group "default"
     auth-server Internal
     set role condition role value-of
    aaa profile "default"
    aaa authentication vpn "default"
       no cert-cn-lookup
    aaa authentication vpn "default-iap"
       no cert-cn-lookup
    aaa authentication vpn "default-rap"
    aaa authentication mgmt
       server-group "xxx-tacacs-server-group"
       enable
    aaa password-policy mgmt
    control-plane-security
    ap system-profile "default"
    ap system-profile "emea-rap-ap-sys-profile"
       lms-ip 213.62.87.104
       bkup-lms-ip 217.33.23.200
       number_ipsec_retries 20
    ap regulatory-domain-profile "default"
       country-code GB
       valid-11g-channel 1
       valid-11g-channel 6
       valid-11g-channel 11
       valid-11a-channel 36
       valid-11a-channel 40
       valid-11a-channel 44
       valid-11a-channel 48
       valid-11a-channel 52
       valid-11a-channel 56
       valid-11a-channel 60
       valid-11a-channel 64
       valid-11a-channel 100
       valid-11a-channel 104
       valid-11a-channel 108
       valid-11a-channel 112
       valid-11a-channel 116
       valid-11a-channel 120
       valid-11a-channel 124
       valid-11a-channel 128
       valid-11a-channel 132
       valid-11a-channel 136
       valid-11a-channel 140
       valid-11g-40mhz-channel-pair 1-5
       valid-11g-40mhz-channel-pair 7-11
       valid-11a-40mhz-channel-pair 36-40
       valid-11a-40mhz-channel-pair 44-48
       valid-11a-40mhz-channel-pair 52-56
       valid-11a-40mhz-channel-pair 60-64
       valid-11a-40mhz-channel-pair 100-104
       valid-11a-40mhz-channel-pair 108-112
       valid-11a-40mhz-channel-pair 116-120
       valid-11a-40mhz-channel-pair 124-128
       valid-11a-40mhz-channel-pair 132-136
    ap wired-ap-profile "default"
    ap enet-link-profile "default"
    ap mesh-ht-ssid-profile "default"
    ap lldp med-network-policy-profile "default"
    ap mesh-cluster-profile "default"
    ap lldp profile "default"
    ap mesh-radio-profile "default"
    ap wired-port-profile "default"
    ids general-profile "default"
    ids rate-thresholds-profile "default"
    ids signature-profile "default"
    ids impersonation-profile "default"
    ids unauthorized-device-profile "default"
    ids signature-matching-profile "default"
       signature "Deauth-Broadcast"
       signature "Disassoc-Broadcast"
    ids dos-profile "default"
    ids profile "default"
    rf arm-profile "arm-maintain"
       assignment maintain
       no scanning
    rf arm-profile "arm-scan"
    rf arm-profile "default"
       no scanning
    rf optimization-profile "default"
    rf event-thresholds-profile "default"
    rf am-scan-profile "default"
    rf dot11a-radio-profile "802.11a-xxx-radio-profile"
       tx-power 127
       slb-mode radio
    rf dot11a-radio-profile "default"
    rf dot11a-radio-profile "rp-maintain-a"
    rf dot11a-radio-profile "rp-monitor-a"
       mode am-mode
    rf dot11a-radio-profile "rp-scan-a"
    rf dot11g-radio-profile "default"
    rf dot11g-radio-profile "rp-maintain-g"
    rf dot11g-radio-profile "rp-monitor-g"
       mode am-mode
    rf dot11g-radio-profile "rp-scan-g"
    wlan handover-trigger-profile "default"
    wlan rrm-ie-profile "default"
    wlan bcn-rpt-req-profile "default"
    wlan tsm-req-profile "default"
    wlan voip-cac-profile "default"
    wlan ht-ssid-profile "default"
    wlan ht-ssid-profile "guest-htssid_prof"
    wlan edca-parameters-profile station "default"
    wlan edca-parameters-profile ap "default"
    wlan dot11k-profile "default"
    wlan ssid-profile "default"
    wlan virtual-ap "default"
    ap provisioning-profile "default"
    rf arm-rf-domain-profile
       arm-rf-domain-key "c90d9172fa3158ef0f0618f6b8b5a8cc"
    ap spectrum local-override
    process monitor log
    end
  • 5.  RE: Help with IAP-VPN setup
    Posted Jul 29, 2013 04:38 PM
    In your session access list "iaprole", you have a source NAT policy but no permit ip any any.
  • 6.  RE: Help with IAP-VPN setup
    Posted Jul 29, 2013 05:09 PM
    I've added the permit rule now but still not working.
    A couple of things to mention
    If I issue a "show user-table" on the controller, I see this:
    (uktcnwc3) #show user-table
    Users
        IP               MAC            Name              Role              Age(d:h:m)  Auth    VPN link      AP name      Roaming   Essid/Bssid/Phy                         Profile                            Forward mode  Type
    2.2.2.191       00:00:00:00:00:00  00:0b:86:82:89:80  default-vpn-role  00:00:02    VPN     81.129.3.192  N/A        tunnel
    Also, when following the configuration guide, it says to add the following:
    host) (VPN Authentication Profile "default-iap") #server-group default
    (host) (VPN Authentication Profile "default-iap") #default-role iaprole
    On my controller, I don't have the option for "defualt-role iaprole".  These are my options
    (uktcnwc3) (VPN Authentication Profile "default-iap") #?
    cert-cn-lookup          Check certificate common name against AAA server.
                            Default is enabled.
    clone                   Copy data from another VPN Authentication Profile
    max-authentication-fa.. Maximum auth failures before user is blacklisted.
                            Range: 1-10. Default: 0.
    no                      Delete Command
    server-group            Name of server group
    I'm running 6.1.3.8, but I thought that version of code supported this type of functionality.
    Thanks for your help.
  • 7.  RE: Help with IAP-VPN setup
    Posted Jul 29, 2013 05:12 PM
    You need the PEF-V license to change that role.
    Can you try replacing the0.0.0.0 route with one for the corporate network?
    Sent from my iPhone
  • 8.  RE: Help with IAP-VPN setup
    Posted Jul 29, 2013 05:32 PM
    No luck,
    I removed the 0.0.0.0 and replaced with
    172.16.0.0 255.240.0.0 213.62.87.104
    My DHCP server is 172.18.96.226
    still not getting an IP address.
  • 9.  RE: Help with IAP-VPN setup
    Posted Jul 29, 2013 06:32 PM
    Can you configure a static IP on the client and test?  It must be something I'm missing here...if that doesn't work, please consider opening a support case.
  • 10.  RE: Help with IAP-VPN setup
    Posted Jul 29, 2013 06:38 PM
    Thanks for the taking the time to help me, I did try the static IP but that didn't help either.  Looks like I'll go down the TAC route.
    Thanks again.
