Hi Justin,
Many thanks for that quick reply, i am starting to wonder if we are perhaps missing something on our HP5500(EI's and HI's) that are COMWARE5, the setup you linked to below is pretty much what i followed for our 5510 side of things on COMWARE7 but our 5500's do not appear to have any IKE commands at all.
Was there perhaps a different firmware that could be downloaded onto 5500's which was not default which brings in more advanced commands?
I have my 5510 setup as per the attached advice, it is really the 5500HI or EI side i am just failing badly on.
Kind Regards
Barry
