Help with LDAP AD account to login into the 3400 Controller
  • 1.  Help with LDAP AD account to login into the 3400 Controller
    Posted Apr 13, 2020 08:41 AM
    so i have LDAP already setup and working. The issue is when i set a server rule so that only certain users from a AD group are allowed to log in, it doesnt work. In my drop down selection i do not have memberOf selection. If i use Group-Name and change the allow local logon to no access it doesnt work either. can someone let me know what i should be using please.
    as you can see memberOf is not validated, but Group-Name is.
  • 2.  RE: Help with LDAP AD account to login into the 3400 Controller
    Posted Apr 13, 2020 08:57 AM
    Two suggestions:
    1.  Use the aaa query command to validate what LDAP attributes are returned for users:  https://www.arubanetworks.com/techdocs/ArubaOS_6_5_4_X_Web_Help/Web_Help_Index.htm#ArubaFrameStyles/1CommandList/aaa_query_user.htm?Highlight=query
    2.  If the attribute does not appear in the dropdown, you can configure it on the commandline in the server group using "set role..."  https://www.arubanetworks.com/techdocs/ArubaOS_6_5_4_X_Web_Help/Web_Help_Index.htm#ArubaFrameStyles/1CommandList/aaa_server_group.htm?Highlight=server%20derivation
  • 3.  RE: Help with LDAP AD account to login into the 3400 Controller
    Posted Apr 13, 2020 09:04 AM
    here is the query and yes the user is part of that grp. ill try it via cli and see if that works.
  • 4.  RE: Help with LDAP AD account to login into the 3400 Controller
    Posted Apr 13, 2020 09:09 AM
  • 5.  RE: Help with LDAP AD account to login into the 3400 Controller
    Posted Apr 13, 2020 09:43 AM
    ran these commands and same result in CLI
  • 6.  RE: Help with LDAP AD account to login into the 3400 Controller
    Posted Apr 13, 2020 09:46 AM
    Did you turn on debugging and look at the log after the user attempt to login?
  • 7.  RE: Help with LDAP AD account to login into the 3400 Controller
    Posted Apr 13, 2020 09:55 AM
    yes
  • 8.  RE: Help with LDAP AD account to login into the 3400 Controller
    Posted Apr 13, 2020 11:14 AM
    so after all the research and attempts at this, using the attribute User-Name works. im not sure why i cannot user memberOf, but since User-Name is working im going to user that. thanks for the information you provided.
  • 9.  RE: Help with LDAP AD account to login into the 3400 Controller
    MVP GURU
    Posted Apr 13, 2020 12:25 PM
    Have you tried MemerOf with a capital M?
  • 10.  RE: Help with LDAP AD account to login into the 3400 Controller
    Posted Apr 13, 2020 12:47 PM
    no, ill try that and see if that works.
