Cloud Managed Networks
Help with new Central setup
  • 1.  Help with new Central setup
    Posted Aug 20, 2018 06:20 AM
    Hello, I am having some issues setting up a new wireless network managed by Central. All APs seem to have lost contact with the VC and also show as down in Central. They are still broadcasting the SSID I created, however I can’t connect to them using either the web interface or CLI as the standard admin username and password are not accepted (I have read in a previous topic here that this is normal).
    Do the APs look for the VC by IP address?
    All of the APs have been rebooted since losing the VC, but it seems they have not elected a new VC, which was my understanding of what should happen.
    Also a few of the APs never came online in Central. They have been subscribed and are powered on (PoE) and connected to the LAN, showing two green LEDs. In the Device Inventory screen in Central they have a grey dot rather than a green one. What does that indicate? Two of the three switches I added also have the grey dot.
    I am not onsite today to check anything but would appreciate any help.
    Thanks.
  • 2.  RE: Help with new Central setup
    Posted Aug 20, 2018 10:10 AM
    And then it magically started working again - almost exactly 5 days since the issue started. Five days of stress for nothing! I'm wondering if the customer has a DHCP issue.
    Jas
  • 3.  RE: Help with new Central setup
    Posted Sep 13, 2018 03:41 AM
    Hi!
    Were the IAPs online before? If I am understanding this correctly, they lost contact after they were provisioned in central?
    Daniel
  • 4.  RE: Help with new Central setup
    Posted Sep 13, 2018 06:07 PM
    Hi Daniel
    Thanks for replying. Yes, they did all show up in Central as online before that. They have all stayed online in the web interface since, but the logs show multiple "down" and "up" entries for the APs some days. I don't think the customer has power issues to that extent. Not sure I trust the web interface of Central. What's your experience been like?
    J
  • 5.  RE: Help with new Central setup
    Posted Sep 17, 2018 11:07 AM
    Hello!
    These can be caused by multiple problem. I will try to brake it down.
    All APs seem to have lost contact with the VC and also show as down in Central. They are still broadcasting the SSID I created, however I can’t connect to them using either the web interface or CLI as the standard admin username and password are not accepted First of all, don't think of central as a mobility controller, but rather like Airwave. So its a management interface, which pushes configs to IAPs and switches and etc. So if your IAPs are offline in central, they can still be operational. It just means it lost contact. Second of all, if the IAPs contact central, and they are put into a group, they download that group config. If you want to access the vc or any other iap through console, you have to use the password that is configured for the IAP group under Wireless management->System->administrator.
    Do the APs look for the VC by IP address? Have you configured a virtual IP for the VC? Have you statically set a Master? If not, then they will form the cluster and elect a master on their own.
    All of the APs have been rebooted since losing the VC, but it seems they have not elected a new VC, which was my understanding of what should happen. If the IAPs are online, then you could go to monitoring->Online APs, and the IAP name that is in BOLD is the VC.
    Also a few of the APs never came online in Central. They have been subscribed and are powered on (PoE) and connected to the LAN, showing two green LEDs. The two green leds indicate, that the AP is operational, and is broadcasting an SSID. It dosen't nescessarily mean the right SSID (SetMeUp perhaps?) In my experience, it is best to also register for an activate account, and sync that with aruba central. Its good for troubleshooting, since you can see if the device checks in to activate, and weather it gets the right provisioning rule. If the device dosen't even check into Activate, then there is a network or dhcp or dns problem. You could try console to IAP and the following:
    34:fc:b9:cb:89:0e# show activate status
    IAP MAC Address :XX:XX:XX:XX:XX
    IAP Serial Number :CNCWJXXXXX
    Cloud Activation Key :EQWEXXX
    Activate Server :device.arubanetworks.com
    Activate Status :success
    Aruba Central Server :app1.central.arubanetworks.com
    Last provision time :2018-09-17 11:41:33
    Provision interval :10080 minutes
    If activate provision dosen't succeed then its a network problem, or you haven't subscrived the equipment in central subscription assignment.
    Speaking of dns, if you provision your IAPs with dhcp, and then give them a static IP, then don't forget to go to wireless management->system->general and set the dns. Because otherwise in case of a power outage, the IAPs try to reconnect to central using the Activate provisioniing rule, and they will try to resolve the fqdn of the activate server, but since the dns is not set for them, they will fail to reconnect.
    In the Device Inventory screen in Central they have a grey dot rather than a green one. What does that indicate? Two of the three switches I added also have the grey dot. They are not online. If the name and IP is also not populated then they have never contacted Central. Otherwise it would be populated with the last accessed value.
    Not sure I trust the web interface of Central. What's your experience been like? Don't trust the web interface :D It works with a pretty huge delay (5-10 minutes if its really bad). You can check if the device is online if you go to monitoring, click on the device name, then go to actions->console and if you can access your device, then its online. I experienced that the monitoring sometimes says that its offline, but I can console to it :) Also I experienced, that sometimes my equipment just goes offline all at onece, sometimes just segmets/clusters (had alerts configured) but they come back after 10 minutes. I check the monitoring->data usage, and if the data drops to 0 for some time, then you had service outage. If it is stable, then only the equipments had problem contacting central, but were functioning.
    Daniel
  • 6.  RE: Help with new Central setup
    Posted Sep 19, 2018 04:23 AM
    Make sure all your IAP's have subscription and is added to the group. We've seen issues where a few of the IAP's wasn't subscribed, and after an unfortunate VC-Master reboot the unsubscribed IAP took the master role and the entire cluster showed as offline in Central.
