help with OU in Clearpass...
  • 1.  help with OU in Clearpass...
    Posted Aug 14, 2022 01:19 AM
    I need help with OU I add the:
    (&(objectClass=user)(sAMAccountName=%{Authentication:Username}))
    for username and work great, now I want add ou for department name any help?
    thank you
  • 2.  RE: help with OU in Clearpass...
    Posted Aug 15, 2022 10:01 AM
    What are you trying to do?  Do you want to authenticate users via AD group or department name?  If yes, please see the thread here  https://community.arubanetworks.com/community-home/digestviewer/viewthread?MID=15923
  • 3.  RE: help with OU in Clearpass...
    Posted Aug 15, 2022 08:21 PM
    I want to authenticate users via AD department name but not working with department option, in AD the department = ou, so I want use ou to authenticate users with there department name.
  • 4.  RE: help with OU in Clearpass...
    Posted Aug 16, 2022 02:15 AM
    You can either change the Search DN in the authentication source, to only search in a specific OU, or if you have multiple OUs that you want to use for role mapping or enforcement, use a mapping/enforcement role like:
    Authentication:YourAD  UserDN  CONTAINS  OU=MyDepartment,  => Assign role or enforcement
    Where you can check an existing authentication in Access Tracker, and if that is for example:
    UserDN CN=Herman MBP. Robers,OU=Airheads,CN=Users,DC=nl,DC=arubalab,DC=com
    ... take from there the OU= up to and including the comma (,) to match on.
    That should work.
  • 5.  RE: help with OU in Clearpass...
    Posted Aug 16, 2022 02:50 AM
    Hello Herman,
    I need to add OU in Authentication Sources in the active directory before I add Authentication for sAMAccountName for the username with
    I see in your video, now I need the same for OU but I can't make it work.
    Thank you
  • 6.  RE: help with OU in Clearpass...
    Posted Aug 17, 2022 05:30 AM
    Not sure what you are trying to achieve. The filter limits the search for users, it does not do anything else with the OU information; and for that reason you probably don't want to change the filter query in this case.
    If you ONLY want to authenticate users that are in ONE specific OU, create/duplicate your Authentication Source and set the Base DN to that OU, example: Base DN = OU=Airheads,CN=Users,DC=nl,DC=arubalab,DC=com. With that, users that authenticate and are NOT in the specific OU, will not be able to authenticate.
    If you want ALL users to authenticate, but make an authorization decision based on which OU they are in, follow the Role Mapping/Enforcement strategy that I mentioned above. You could even use that to achieve that only users in a specific OU get access, others will be rejected.
    In case it is still unclear to you, it may be good to open a TAC support cases and go with them through your desired scenario. Or if you can provide like 5 examples of users in different OUs and what policy you want for them, we may be able to provide you more guidance.
  • 7.  RE: help with OU in Clearpass...
    Posted Aug 25, 2022 03:19 AM
    Hello Herman,
    sorry for the late replay I was sick,
    I want to see the option in the list so in value write the department name.
    now use distinguishedName with CONTAINS and in value write the department name.
    it work with me now.
    Thank you
