Wired Intelligent Edge
  • 1.  Help with switch config for NetApp / VMWare config
    Posted Aug 13, 2014 12:02 PM
    Hi, I'm atfer some help if anyone can assist I'd be hugely grateful. In fact I'm willing to pay for the assistance / knowledge sharing!
    We have a small development environment consisting of:
    1 x NetApp FAS2220
    1 x HP2920
    1 x HP5406
    1 x HP C7000 enclosure with 8x ProLiant BL460c Gen8 blades (for ESXi 5.5 hosts)
    2 x Flex-10 modules
    I need to work through the configuration to see where I'm going wrong:
    On the NetApp I have one interface (e0d) serving CIFs file share on the production network.
    The three other interfaces (e0a-e0c) are to be trunked/aggregated to serve the VMWare NFS datastores - I can't get this working.
    There is a separate management VLAN to manage the NetApp which is working.
    The NetApp VIF/trunk is configured as a VLAN and connects to the 2920 (config attached)
    This is then connected to the 5406 via 10Gb twinax.
    The 5406 is connected by ports E1 & E2 (trunk1 LACP) and F1 & F2 (trunk2 LACP) in Virtual Connect. (config attached)
    I have configured Virtual Connect 10GbE Flex-10 with the various VLANs.
    I'm not sure how to export Virtual Connect Config, so I've attached various screenshots.
    Cheers!
    #VMware
    #VLAN
    #esx
    #netapp
    #Trunk
  • 2.  RE: Help with switch config for NetApp / VMWare config
    Posted Aug 13, 2014 09:06 PM
    You will need to provide a diagram that shows switchport IDs, or, alternatively you should configure a "name" on every switchport you are using so that we can match your config to your physical topology.
    You also should configure rapid spanning-tree on your two switches.
  • 3.  RE: Help with switch config for NetApp / VMWare config
    Posted Aug 14, 2014 09:00 AM
    Hi... here's a diagram and updated configs with named ports
    thanks
    ennorab
    Attachment(s)
  • 4.  RE: Help with switch config for NetApp / VMWare config
    Posted Aug 14, 2014 07:16 PM
    An update on this. I've made some progress and managed to get it working, however, I'm not 100% sure it's correct.
    Changes made:
    - Removed VLAN interface from NetApp, and left it simply as a 3-port trunked VIF
    - Removed trunk from interfaces on switch connecting to the NetApp controller
    - Added IP address to VLAN for storage on switches
    - Removed the VLAN ID from the storage vmk interface in vSphere
    The last point is  what confuses me I would have thought I'd need to have the vlan ID on there as the Flex-10 uses vlan information for the various ethernet connections configured in Virtual Connect.
    So the configuration now looks something like this:
    NetApp VIF (3 port trunk) -> HP 2920 Switch (untagged ports 25-27) -> HP 5406 (tagged)-> Flex-10 ports on modules in bay 1 & 2 -> ESXi host
    Any help or clarification/corrections/suggestions on this would be much appreciated
    cheers.
    ennorab
  • 5.  RE: Help with switch config for NetApp / VMWare config
    Posted Aug 14, 2014 07:57 PM
    I notice your default VLAN is tagged on the 5406 uplink to the other switch(F7), but it is not tagged on the port on the other switch (A1).
