Help with why I am seeing wired roaming users
  • 1.  Help with why I am seeing wired roaming users
    Posted Mar 15, 2013 02:49 PM
    I noticed a strange issue this morning after configuration changes on our controllers that I had performed last night. I had upgraded the controllers from 6.1.3.1 to 6.1.3.7 and that had gone well. The controllers are three 3600’s in a master/local/local all in the same location with VRRP, no AP’s on the master but will fail to the master if a local goes down. We use the DNS method for an AP to find the master.
    After the OS upgrade I wanted to move them out of vlan 1 (a project of mine to move away from that vlan). Each controller has an ip in vlan 1 and the vrrp addresses are also in vlan 1. I took these steps, never got far enough to actually change the IP of the controllers:
    • I trunked our management vlan 880 to the controllers, adding it to the trunks from the switch side then building the vlan in the controllers via the gui and adding an IP to the vlan. I was then able to ping each controllers IP in vlan 880 from my pc.
    • I then went into the redundancy section, shut down the VRRP state and changed their IP’s and brought them back up.
    • Then I changed the AP system profiles to use the new VRRP address.
    I was not having a lot of luck, AP’s were rebooting and one of the VRRP sessions were master on both sides. I decided to roll back some of the changes and discovered that I had accidentally made the IP address for the two VRRP’s the same on each local (they were correct on the master side) so I know that was the issue. Once I had rolled back the VRRP and AP system profiles to the old vlan 1 addresses, some of the AP’s would not connect. There were also some AP’s on the wrong controller (because of my mistake) so I rebooted the controllers again as a way to straighten it all out. This helped but I still had some AP’s that were not connecting so I rebooted the affected AP’s individually and that finally got all the AP’s back in order. One concern I had is that I did not have as many clients connected as when I had started, by more than I would have expected.
    The next day I looked at “show user-table” and I found something that I had never seen before, the users I’ve listed below. There was many more but this is just an example.
    Users
        IP                MAC            Name    Role    Age(d:h:m)  Auth    VPN link  AP name    Roaming   Essid/Bssid/Phy  Profile            Forward mode  Type
    10.8.0.9         00:17:59:45:b9:44           logon   00:00:02                      tunnel 8   Wired                      default            tunnel
    10.8.192.25      00:60:16:35:df:dc           logon   00:00:00                      tunnel 8   Wired                      default            tunnel
    10.8.192.30      e4:1f:13:74:ea:b0           logon   00:00:07                      tunnel 8   Wired                      default            tunnel
    These “users” were stuck in the logon role, and I don’t understand what the “tunnel 8” AP name is about, and the Wired under roaming. The last two IP’s are in the new management vlan that I had added, the first one is outside of that vlan and not one that is on the controllers. The MAC addresses and IP’s correspond to servers that we have. I did not understand what that was about, but I quickly removed vlan 880 from the switch trunks and disabled the vlan on the controllers. That fixed this issue. What might have caused this behavior?
    Something that I had noticed while adding an IP to the new VLAN was that there is an option checked for all of the vlans, “enable inter-VLAN routing”. The controllers are not the gateway for any of our networks, just layer 2. They used to be however, for the wireless vlans. I’m wondering if this should not be checked and it is left over from that time? Could that have anything to do with what I saw?
    #3600
  • 2.  RE: Help with why I am seeing wired roaming users
    Posted Mar 15, 2013 03:26 PM
    So I found something interesting to add. The port channel interface looks like this now:
    interface port-channel 7
            add gigabitethernet 1/0
            add gigabitethernet 1/1
            trusted
            trusted vlan 1,100,104,108,132,136,164,168,196,208,212,228
            switchport mode trunk
            switchport access vlan 880
            switchport trunk allowed vlan 1-199,201-4094
    vlan 880 is set as the access vlan on the port channel. In Cisco speak this would be the native vlan, untaged. When I added this last night I used the GUI and did it by going to the configuration tab -> NETWORK -> VLANs, and added vlan 880 and associated it with port-channel 7. I then went to NETWORK ->  IP, edited vlan 880 and added the ip/mask.
    It seems to me that I shouldn’t have used the GUI, and should have used the CLI to add it as a trusted vlan. Could this be another contributor to the problem?
    I wish I had a lab to test this stuff with…
  • 3.  RE: Help with why I am seeing wired roaming users
    Posted Mar 15, 2013 04:41 PM
    Make the port channel interface trusted, and make sure all the VLANs are trusted, too..
