Helpful CLI Commands
  • 1.  Helpful CLI Commands
    Posted Oct 14, 2015 12:26 PM
    to build upon this article here are a few more commands I find myself using quite a bit . There is some drilling with some of the commands just to show specific you can get.
    Everyone has their own method and with all you brilliant folks there has to be some more that you prefer. So you experts, please add to the list if you have some other "go-to" commands.
    _________________________________________________________________________________
    --(Controller5) #show ap port status ap-name "AP 275"
    AP "AP 275" Port Status (updated every 60 seconds)
    Port  MAC                Type  Forward Mode  Admin    Oper  Speed   Duplex  802.3az   PoE  STP  TX-Packets  TX-Bytes    RX-Packets  RX-Bytes
    0     94:b4:0f:cb:03:06  GE    N/A           enabled  up    1 Gb/s  full    disabled  N/A  N/A  154633588   3727293658  317742748   3306051752
    1     94:b4:0f:cb:03:07  GE    tunnel        enabled  down  N/A     N/A     N/A       N/A  N/A  0           0           0           0
    ___________________________________________________________________________________
    (Controller5) #show arp
    Protocol Address Hardware Address Interface
    Internet 192.168.1.106 60:BE:B5:03:22:63 vlan6
    Internet 192.168.1.124 FC:C2:DE:28:39:26 vlan6
    Internet 192.168.25.2 00:1A:1E:14:FA:40 vlan25
    Internet 192.168.11.96 00:0B:86:EF:1C:30 vlan7
    --(Controller5) #show arp vlan 7
    Internet        192.168.11.94   00:0B:86:F5:21:22       vlan7
    Internet        192.168.11.97   00:0B:86:F5:21:1A       vlan7
    --(Controller5) #show arp vlan 7 | include 192.168.11.206
    Internet        192.168.11.206  E0:B9:A5:F5:CD:9C       vlan7
    (Controller5) #show switches
    All Switches
    IP Address  Name         Location          Type    Model      Version        Status  Configuration State  Config Sync Time (sec)  Config ID
    10.1.1.1    Controller5  Building1.floor1  master  Aruba3200  6.4.3.3_50954  up      UPDATE SUCCESSFUL    0                       39
    (Controller5) #show auth-tracebuf
    Auth Trace Buffer
    Oct  7 08:37:09  eap-tlv-rslt-success  <-  e0:b9:a5:f5:cd:9c  94:b4:0f:30:30:60/dot1x_prof-ylc11  -  43
    Oct  7 08:37:09  eap-tlv-rslt-success  ->  e0:b9:a5:f5:cd:9c  94:b4:0f:30:30:60                   -  2
    Oct  7 08:37:09  eap-success           <-  e0:b9:a5:f5:cd:9c  94:b4:0f:30:30:60/dot1x_prof-ylc11  -  4
    Oct  7 08:37:09  wpa2-key1             <-  e0:b9:a5:f5:cd:9c  94:b4:0f:30:30:60                   -  117
    Oct  7 08:37:09  wpa2-key2             ->  e0:b9:a5:f5:cd:9c  94:b4:0f:30:30:60                   -  117
    Oct  7 08:37:09  wpa2-key3             <-  e0:b9:a5:f5:cd:9c  94:b4:0f:30:30:60                   -  151
    Oct  7 08:37:09  wpa2-key4             ->  e0:b9:a5:f5:cd:9c  94:b4:0f:30:30:60                   -  95
    Oct  7 08:37:23  station-down           *  78:fd:94:29:61:9e  94:b4:0f:30:30:63                   -  -
    Oct  7 08:37:23  station-up             *  78:fd:94:29:61:9e  94:b4:0f:30:30:75                   -  -    wpa2 psk aes
    (Controller5) #show auth-tracebuf | include e0:b9:a5:f5:cd:9c count 10
    Auth Trace Buffer
    Oct  8 23:38:48  mschap-response       <-  e0:b9:a5:f5:cd:9c  94:b4:0f:30:30:60/Internal          -  -    jamie.easley
    Oct  8 23:38:48  eap-mschap-success    <-  e0:b9:a5:f5:cd:9c  94:b4:0f:30:30:60/dot1x_prof-ylc11  -  83
    Oct  8 23:38:48  eap-mschap-success-ack->  e0:b9:a5:f5:cd:9c  94:b4:0f:30:30:60/dot1x_prof-ylc11  -  -
    Oct  8 23:38:48  eap-tlv-rslt-success  <-  e0:b9:a5:f5:cd:9c  94:b4:0f:30:30:60/dot1x_prof-ylc11  -  43
    Oct  8 23:38:48  eap-tlv-rslt-success  ->  e0:b9:a5:f5:cd:9c  94:b4:0f:30:30:60                   -  2
    Oct  8 23:38:48  eap-success           <-  e0:b9:a5:f5:cd:9c  94:b4:0f:30:30:60/dot1x_prof-ylc11  -  4
    Oct  8 23:38:48  wpa2-key1             <-  e0:b9:a5:f5:cd:9c  94:b4:0f:30:30:60                   -  117
    Oct  8 23:38:48  wpa2-key2             ->  e0:b9:a5:f5:cd:9c  94:b4:0f:30:30:60                   -  117
    Oct  8 23:38:48  wpa2-key3             <-  e0:b9:a5:f5:cd:9c  94:b4:0f:30:30:60                   -  151
    Oct  8 23:38:48  wpa2-key4             ->  e0:b9:a5:f5:cd:9c  94:b4:0f:30:30:60                   -  95
    (Controller5) #show vrrp
    Virtual Router 50:
        Description primary-master
        Admin State UP, VR State INIT
        IP Address 10.11.50.110, MAC Address 00:00:5e:00:01:32, vlan 50
        Priority 110, Advertisement 1 sec, Preemption Enable Delay 0
        Auth type PASSWORD, Auth data&colon; ********
        tracking type is master-up-time, duration 30 minutes, value 20
        tracked priority 130
     (I like ALL of these)
    (Controller5) (config) #logging level debugging user subcat ?
    all                     Enable logging of all the sub-categories
    captive-portal          Captive portal user logging
    client-match            ARM Client match user logging
    dot1x                   Dot1x logging
    mapc                    IF-MAP Client logging
    pan                     Palo Alto Networks Interface logging
    radius                  Radius user logging
    voice                   Voice user logging
    vpn                     VPN logging
    (Controller5) (config) #logging level debugging ap-debug "AP 275"
    (Controller5) #show log ap-debug all
    Oct 9 09:49:29 :311009:  <DBUG> |AP AP 275@192.168.11.2 sapd|  sapd_send_log_config: sending log 1005 config msg 1 to 8370
    Oct 9 09:49:29 :311009:  <DBUG> |AP AP 275@192.168.11.2 sapd|  sapd_send_log_config: sending log 1005 config msg 1 to 8451
    Oct 9 09:49:29 :311009:  <DBUG> |AP AP 275@192.168.11.2 sapd|  sapd_send_log_config: sending log 1005 config msg 1 to 8410
    Oct 9 09:49:29 :311009:  <DBUG> |AP AP 275@192.168.11.2 sapd|  sapd_send_log_config: sending log 1005 config msg 1 to 8433
    Oct 9 09:49:30 :311009:  <DBUG> |AP AP 275@192.168.11.2 sapd|  sapd_check_lacp: Counter 0
    Oct 9 09:49:30 :311009:  <DBUG> |AP AP 275@192.168.11.2 sapd|  power profile: POE-AT
    Oct 9 09:49:30 :326001:  <DBUG> |AP AP 275@192.168.11.2 sapd|  AM: spec_construct_amp_msg - MM: No spec devices to send to controller
    Oct 9 09:49:30 :326001:  <DBUG> |AP AP 275@192.168.11.2 sapd|  AM: process_eif_packet: Untagged Frame Received 806 806
    (config) #no logging level debugging ap-debug "AP 275"
    (Controller5) #aaa test-server pap internal jamie.easley password
    Authentication Successful
    (Controller5) #aaa test-server pap internal jamie.easley password1
    Authentication failed
    (Controller5) #apboot ?
    all                     Reboot all APs
    ap-group                Reboot APs in this group
    ap-name                 Reboot AP with this name
    ip-addr                 Reboot AP at this IP address
    ip6-addr                Reboot AP at this IPv6 address
    wired-mac               Reboot AP at this MAC address
    (Controller5) #show rf arm-profile "default"
    Adaptive Radio Management (ARM) profile "default"
    Parameter        Value
    Assignment        single-band
    Allowed bands for 40MHz channels                                             a-only
    80MHz support        Enabled
    Client Aware        Enabled
    Max Tx EIRP        127 dBm
    Min Tx EIRP        3 dBm
    Rogue AP Aware                                                               Disabled
    Scan Interval        10 sec
    Aggressive scanning                                                          true
    Active Scan        Disabled
    ARM Over the Air Updates                                                     Enabled
    Scanning        Enabled
    Multi Band Scan                                                              Enabled
    VoIP Aware Scan                                                              Enabled
    Power Save Aware Scan                                                        Disabled
    Video Aware Scan                                                             Enabled
    Ideal Coverage Index                                                         10
    Acceptable Coverage Index                                                    4
    Free Channel Index                                                           25
    Backoff Time        240 sec
    Error Rate Threshold                                                         50 %
    Error Rate Wait Time                                                         30 sec
    Channel Quality Aware Arm                                                    Disabled
    Channel Quality Threshold                                                    70 %
    Channel Quality Wait Time                                                    120 sec
    Minimum Scan Time                                                            8
    Load aware Scan Threshold                                                    1250000 Bps
    Mode Aware Arm                                                               Disabled
    Scan Mode        all-reg-domain
    Cellular handoff assist                                                      Disabled
    Client Match        Enabled
    Client Match report interval (sec)                                           30
    Allows Client Match to automatically clear unsteerable clients after ageout  Enabled
    Client Match Unsteerable Client Ageout Interval                              2 Days 0 Hours
    Client Match Band Steer G Band Max Signal (-dBm)                             45
    Client Match Band Steer A Band Min Signal (-dBm)                             75
    Client Match Sticky Client Check Interval (sec)                              3
    Client Match Sticky client check SNR (dB)                                    18
    Client Match SNR threshold(dB)                                               10
    Client Match Sticky Min Signal                                               65
    Client Match Restriction timeout (sec)                                       10
    Client Match Load Balancing threshold (%)                                    20
    Client Match IOS Steer Backoff interval (sec)                                300
    Client Match VBR Stale Entry Age (sec)                                       120
    Client Match Max steer failures                                              2
    Client Match Load Balancing client threshold                                 30
    Client Match Load Balancing SNR threshold (dB)                               30
    Client Match Load Balancing signal delta bound (dB)                          5
    Client Match 11v BSS Transition Management                                   Enabled
    (Controller5) #show rf arm-profile "default" | include client
