Hi all please help I need to change the country code from US and an IAP93 ver 6.3....
  • 1.  Hi all please help I need to change the country code from US and an IAP93 ver 6.3....
    Posted Oct 28, 2014 09:25 AM
    Hi all / any I have got a few IAP 93 with the country code set to US which was done in error will particing to wards my CWNA can any 1 help with directions if it is posible to change it from US  to UK or even better have the option window show at boot up.
    Many thank for any help you can provide
  • 2.  RE: Hi all please help I need to change the country code from US and an IAP93 ver 6.3....
    Posted Oct 28, 2014 09:32 AM
    The country code of a -US cannot be changed.  You need a ROW (rest of world) IAP.  The part number is just IAP-93
  • 3.  RE: Hi all please help I need to change the country code from US and an IAP93 ver 6.3....
    Posted Oct 28, 2014 11:03 AM
    Many thanks for that.
    It also got me thinking and now questions:
    Initially when I booted these APs I was given the option to select the country code. On my sec set up while attempting the virtual controller i select US as my country code on the master which was then push down to the other AP since then i have not been able to change the country code I dont even get the window with the option.
    I take it these ap did have ROW option even on the box it says QTY:1 EU
    Many thanks again
  • 4.  RE: Hi all please help I need to change the country code from US and an IAP93 ver 6.3....
    Posted Oct 28, 2014 11:07 AM
    You will know if you physically look at the IAP, it should say IAP-93-US on it.
    If not it is just as Marcus mentioned IAP-93.
    If you factory reset the AP it should ask you for country code again
  • 5.  RE: Hi all please help I need to change the country code from US and an IAP93 ver 6.3....
    Posted Oct 28, 2014 11:24 AM
    Mine says IAP-93 well all of them,
    I have tried hard factory reset, CLI factory reset, url firmware update, CLI clear os, upgrade os, setenv country code: UK also have even tried to push the country code by and other IAP-93 set to UK, but to no avail.
    Have had many attempts.
    Many thanks
  • 6.  RE: Hi all please help I need to change the country code from US and an IAP93 ver 6.3....
    Posted Oct 28, 2014 11:32 AM
    I would open a TAC case to confirm
  • 7.  RE: Hi all please help I need to change the country code from US and an IAP93 ver 6.3....
    Posted Oct 28, 2014 11:46 AM
    Which country code are you attempting to set?
    United Kingdom = GB
    Ukraine = UA
    Also, what version of SW are you running? Ex: 6.4.2.0-4.1.1.0
  • 8.  RE: Hi all please help I need to change the country code from US and an IAP93 ver 6.3....
    Posted Oct 29, 2014 05:12 AM
    I am tring to change it GB,
    AP Boot is  < APBoot 1.2.4.4 (build 26618)>
    ArubaOS Version 6.2.1.0-3.4.0.1 (build 39461 / label #39461)
    I have also change the OS to:
    ArubaOS Version 6.1.2.3-2.0.0.4 (build 32946 / label #32946)
    My thoughts of it is, the AP bios if it has 1 needs to be factory reset from <APBoot 1.2.4.4 (build 26618)>> maybe the ROW is not written in the OS ver or if it when I select US as my country code it altered the AP Boot setting.
    I do not have a TCA agreement with Aruba and it will cost to get 1.
    Any help please
  • 9.  RE: Hi all please help I need to change the country code from US and an IAP93 ver 6.3....
    Posted Oct 29, 2014 08:30 AM
    CLI extract
    d8:c7:c8:cf:37:f1 (config) # no virtual-controller-country
    Error: Cannot clear country code configuration for AP
    d8:c7:c8:cf:37:f1 (config) # no virtual-controller-country US
    % Parse error
    d8:c7:c8:cf:37:f1 (config) # virtual-controller-country GB
    Error: "GB" is not a valid country code for this AP.
    d8:c7:c8:cf:37:f1 (config) # virtual-controller-country ROW
    Error: "ROW" is not a valid country code.
    d8:c7:c8:cf:37:f1 (config) # virtual-controller-country US
    this show that it only accept US
  • 10.  RE: Hi all please help I need to change the country code from US and an IAP93 ver 6.3....
    Posted Oct 29, 2014 11:04 AM
    Hi can any 1 please direct me to a ver of APBoot 1.2.7.4 Build 32721 file?
    Many thanks
  • 11.  RE: Hi all please help I need to change the country code from US and an IAP93 ver 6.3....
    Posted Apr 30, 2018 03:07 PM
    Did you got the solution for this issue....I am also facing the same issue now.
  • 12.  RE: Hi all please help I need to change the country code from US and an IAP93 ver 6.3....
    Posted May 01, 2018 10:42 AM
    Do you have a rest of world (ROW) IAP, or a US model IAP-93?
