Wireless Water Cooler
last person joined: 24 days ago
Hang out and socialize with other community members in this off topic forum. Everything from industry trends to hobbies and interests are welcomed!
Hi, any known issues with iphone users (iphone4 and up) constantly dropping wpa connection
  • 1.  Hi, any known issues with iphone users (iphone4 and up) constantly dropping wpa connection
    Posted May 29, 2014 01:51 PM
    Are there any known issues/bug fixes  with iphone users (iphone4 and up) constantly dropping   wpa/authenticated connection
    this is on a 3200 controller ver 3.4.3.2   with  AP 125s
    --just iphones.  other smartphones/brands are fine.  laptops/desktops are fine.
    --problem occurs when moving and when stationary.
    --iphone users need to reset their wifi settings to get back to wifi/wpa/authenticated
    --just in this bldg.  iphones are fine when out to other bldgs, sites.
    --iphones drop wpa/wifi connection and goes to 4G
    --i do have an Aruba TAC case open.
    --could not find anything in KB
    thanks so much
    Ariel
    #3200
  • 2.  RE: Hi, any known issues with iphone users (iphone4 and up) constantly dropping wpa connection
    Posted May 29, 2014 01:56 PM
    Not sure if this enabled under that version but do you have band steering enabled or spectrum load balancing ?
    And under the 802.1x aaa profile do you have enabled PMKID Caching?
  • 3.  RE: Hi, any known issues with iphone users (iphone4 and up) constantly dropping wpa connection
    Posted May 29, 2014 03:13 PM
    thanks Victor,
    I will find out.  are these the features that can possibly improve their connections.?
    ariel
  • 4.  RE: Hi, any known issues with iphone users (iphone4 and up) constantly dropping wpa connection
    Posted Jun 20, 2014 04:54 PM
    Hi Victor,
    After monitoring for over 2 weeks,  it appears the  problem has been fixed.
    Resolution:  Aruba TAC  disabled OKC  and  enabled PMK
    So, kudos to you Victor for your comment on PMK
    I am thinking we might be able to apply this on all the  other  bldg  controllers across the University.
    Thanks all!
    Ariel
  • 5.  RE: Hi, any known issues with iphone users (iphone4 and up) constantly dropping wpa connection
    Posted May 29, 2014 03:53 PM
    thanks so much
    Ariel
    3.4.3.2 came out almost 3 years ago.  As devices get added, Aruba patches the code to improve interoperability.  You are doing the right thing working with TAC.
