Hi, I have a problem with MacOS devices, they are not connecting to the Network, and I have 105 IAPs
  • 1.  Hi, I have a problem with MacOS devices, they are not connecting to the Network, and I have 105 IAPs
    Posted Apr 02, 2014 10:36 AM
    Hi, I have a problem with MacOS devices, they are not connecting to the Network, and I have 105 IAPs platform, any ideas?
  • 2.  RE: Hi, I have a problem with MacOS devices, they are not connecting to the Network, and I have 105 IAPs
    Posted Apr 02, 2014 10:40 AM
    What authentication method and encryption type are you using? Open / WPA2-PSK / WPA2-Enterprise?
    Is this a new network or new issue with existing network?
    What code are the IAPs running?
  • 3.  RE: Hi, I have a problem with MacOS devices, they are not connecting to the Network, and I have 105 IAPs
    Posted Apr 02, 2014 10:47 AM
    WPA2-PSK, This is a new network, but some of the MAC OS devices were working others not, now none is working, they are not even assosiating
  • 4.  RE: Hi, I have a problem with MacOS devices, they are not connecting to the Network, and I have 105 IAPs
    Posted Apr 02, 2014 11:54 AM
    - Are you using network assigned or virtual controller assigned ?
    - Check the VLAN configure for that network
    - Make sure that there's no issues with your DHCP server or the device providing IPs .
  • 5.  RE: Hi, I have a problem with MacOS devices, they are not connecting to the Network, and I have 105 IAPs
    Posted Apr 02, 2014 12:30 PM
    Hello, Im using Virtual Controller Assignned, The DHCP seems to be working fine since I have no issues with Windows devices, Android devices or even iOS devices. The issue it's only with MacOS devices, with a variety of versions.
  • 6.  RE: Hi, I have a problem with MacOS devices, they are not connecting to the Network, and I have 105 IAPs
    Posted Apr 02, 2014 02:55 PM
    Can you share the output of ?show tech-support??
