Hi Team, we are facing Hand held devices disconnection while scanning the luggages
  • 1.  Hi Team, we are facing Hand held devices disconnection while scanning the luggages
    Posted Aug 14, 2015 07:32 PM
    The Hand held device for scannging Luggages Hangs and works after restart  or there will be no signal at all . Could you please let me know, what may be the problem?
    (ADAC-MWLC-7220) #show ap association client-mac 00:10:20:59:38:73
    The phy column shows client's operational capabilities for current association
    Flags: A: Active, B: Band Steerable, H: Hotspot(802.11u) client, K: 802.11K client, R: 802.11R client, W: WMM client, w: 802.11w client V: 802.11v BSS trans capable
    PHY Details: HT   : High throughput;      20: 20MHz;  40: 40MHz
                 VHT  : Very High throughput; 80: 80MHz; 160: 160MHz; 80p80: 80MHz + 80MHz
                 <n>ss: <n> spatial streams
    Association Table
    Name                   bssid              mac                auth  assoc  aid  l-int  essid   vlan-id  tunnel-id  phy          assoc. time  num assoc  Flags  Band steer moves (T/S)
    AUH-CBP-BHF12-BHF-AP4  d8:c7:c8:04:00:44  00:10:20:59:38:73  y     y      1    3      BRS349  349      0x10e73    g-HT-20-1ss  48s          1          WA     0/0
    00:10:20:59:38:73-d8:c7:c8:04:00:44 Stats
    Parameter                            Value
    Channel                              11
    Channel Frame Retry Rate(%)          0
    Channel Frame Low Speed Rate(%)      0
    Channel Frame Non Unicast Rate(%)    0
    Channel Frame Fragmentation Rate(%)  0
    Channel Frame Error Rate(%)          13
    Channel Bandwidth Rate(kbps)         0
    Channel Noise                        96
    Client Frame Retry Rate(%)           0
    Client Frame Low Speed Rate(%)       0
    Client Frame Non Unicast Rate(%)     0
    Client Frame Fragmentation Rate(%)   0
    Client Frame Receive Error Rate(%)   0
    Client Bandwidth Rate(kbps)          0
    Client Tx Packets                    101
    Client Rx Packets                    33
    Client Tx Bytes                      7018
    Client Rx Bytes                      3822
    Client SNR                           27
    A2c_SM SeqNum, Old SeqNums           41600 0
    (ADAC-MWLC-7220) #show auth-tracebuf mac 00:10:20:59:38:73
    Warning: user-debug is enabled on one or more specific MAC addresses;
             only those MAC addresses appear in the trace buffer.
    Auth Trace Buffer
    Aug 15 02:29:05  wpa2-key2             ->  00:10:20:59:38:73  6c:f3:7f:7e:78:96  -  117
    Aug 15 02:29:05  wpa2-key3             <-  00:10:20:59:38:73  6c:f3:7f:7e:78:96  -  151
    Aug 15 02:29:05  wpa2-key4             ->  00:10:20:59:38:73  6c:f3:7f:7e:78:96  -  95
    Aug 15 02:30:29  station-down           *  00:10:20:59:38:73  6c:f3:7f:7e:78:96  -  -
    Aug 15 02:33:00  station-up             *  00:10:20:59:38:73  6c:f3:7f:7e:78:96  -  -    wpa2 psk aes
    Aug 15 02:33:00  wpa2-key1             <-  00:10:20:59:38:73  6c:f3:7f:7e:78:96  -  117
    Aug 15 02:33:00  wpa2-key2             ->  00:10:20:59:38:73  6c:f3:7f:7e:78:96  -  117
    Aug 15 02:33:00  wpa2-key3             <-  00:10:20:59:38:73  6c:f3:7f:7e:78:96  -  151
    Aug 15 02:33:00  wpa2-key4             ->  00:10:20:59:38:73  6c:f3:7f:7e:78:96  -  95
    Aug 15 02:33:12  station-down           *  00:10:20:59:38:73  6c:f3:7f:7e:78:96  -  -
    Aug 15 02:33:12  station-up             *  00:10:20:59:38:73  6c:f3:7f:7e:78:86  -  -    wpa2 psk aes
    Aug 15 02:33:12  wpa2-key1             <-  00:10:20:59:38:73  6c:f3:7f:7e:78:86  -  117
    Aug 15 02:33:12  wpa2-key2             ->  00:10:20:59:38:73  6c:f3:7f:7e:78:86  -  117
    Aug 15 02:33:12  wpa2-key3             <-  00:10:20:59:38:73  6c:f3:7f:7e:78:86  -  151
    Aug 15 02:33:12  wpa2-key4             ->  00:10:20:59:38:73  6c:f3:7f:7e:78:86  -  95
    Aug 15 02:33:49  station-down           *  00:10:20:59:38:73  6c:f3:7f:7e:78:86  -  -
    Aug 15 02:33:49  station-up             *  00:10:20:59:38:73  6c:f3:7f:7e:78:96  -  -    wpa2 psk aes
    Aug 15 02:33:49  wpa2-key1             <-  00:10:20:59:38:73  6c:f3:7f:7e:78:96  -  117
    Aug 15 02:33:49  wpa2-key2             ->  00:10:20:59:38:73  6c:f3:7f:7e:78:96  -  117
    Aug 15 02:33:49  wpa2-key3             <-  00:10:20:59:38:73  6c:f3:7f:7e:78:96  -  151
    Aug 15 02:33:49  wpa2-key4             ->  00:10:20:59:38:73  6c:f3:7f:7e:78:96  -  95
    Aug 15 02:34:01  station-down           *  00:10:20:59:38:73  6c:f3:7f:7e:78:96  -  -
    Aug 15 02:34:01  station-up             *  00:10:20:59:38:73  6c:f3:7f:7e:78:86  -  -    wpa2 psk aes
    Aug 15 02:34:01  wpa2-key1             <-  00:10:20:59:38:73  6c:f3:7f:7e:78:86  -  117
    Aug 15 02:34:01  wpa2-key2             ->  00:10:20:59:38:73  6c:f3:7f:7e:78:86  -  117
    Aug 15 02:34:01  wpa2-key3             <-  00:10:20:59:38:73  6c:f3:7f:7e:78:86  -  151
    Aug 15 02:34:01  wpa2-key4             ->  00:10:20:59:38:73  6c:f3:7f:7e:78:86  -  95
    Aug 15 02:35:06  station-down           *  00:10:20:59:38:73  6c:f3:7f:7e:78:86  -  -
    Aug 15 02:35:06  station-up             *  00:10:20:59:38:73  d8:c7:c8:00:c7:d6  -  -    wpa2 psk aes
    Aug 15 02:35:06  wpa2-key1             <-  00:10:20:59:38:73  d8:c7:c8:00:c7:d6  -  117
    Aug 15 02:35:06  wpa2-key2             ->  00:10:20:59:38:73  d8:c7:c8:00:c7:d6  -  117
    Aug 15 02:35:06  wpa2-key3             <-  00:10:20:59:38:73  d8:c7:c8:00:c7:d6  -  151
    Aug 15 02:35:06  wpa2-key4             ->  00:10:20:59:38:73  d8:c7:c8:00:c7:d6  -  95
    Aug 15 02:35:18  station-down           *  00:10:20:59:38:73  d8:c7:c8:00:c7:d6  -  -
    Aug 15 02:35:18  station-up             *  00:10:20:59:38:73  ac:a3:1e:83:1b:62  -  -    wpa2 psk aes
    Aug 15 02:35:18  wpa2-key1             <-  00:10:20:59:38:73  ac:a3:1e:83:1b:62  -  117
    Aug 15 02:35:18  wpa2-key2             ->  00:10:20:59:38:73  ac:a3:1e:83:1b:62  -  117
    Aug 15 02:35:18  wpa2-key3             <-  00:10:20:59:38:73  ac:a3:1e:83:1b:62  -  151
    Aug 15 02:35:18  wpa2-key4             ->  00:10:20:59:38:73  ac:a3:1e:83:1b:62  -  95
    Aug 15 02:35:27  station-down           *  00:10:20:59:38:73  ac:a3:1e:83:1b:62  -  -
    Aug 15 02:35:27  station-up             *  00:10:20:59:38:73  d8:c7:c8:03:f1:f4  -  -    wpa2 psk aes
    Aug 15 02:35:27  wpa2-key1             <-  00:10:20:59:38:73  d8:c7:c8:03:f1:f4  -  117
    Aug 15 02:35:27  wpa2-key2             ->  00:10:20:59:38:73  d8:c7:c8:03:f1:f4  -  117
    Aug 15 02:35:27  wpa2-key3             <-  00:10:20:59:38:73  d8:c7:c8:03:f1:f4  -  151
    Aug 15 02:35:27  wpa2-key4             ->  00:10:20:59:38:73  d8:c7:c8:03:f1:f4  -  95
    Aug 15 02:35:39  station-down           *  00:10:20:59:38:73  d8:c7:c8:03:f1:f4  -  -
    Aug 15 02:35:39  station-up             *  00:10:20:59:38:73  d8:c7:c8:00:bf:e4  -  -    wpa2 psk aes
    Aug 15 02:35:39  wpa2-key1             <-  00:10:20:59:38:73  d8:c7:c8:00:bf:e4  -  117
    Aug 15 02:35:39  wpa2-key2             ->  00:10:20:59:38:73  d8:c7:c8:00:bf:e4  -  117
    Aug 15 02:35:39  wpa2-key3             <-  00:10:20:59:38:73  d8:c7:c8:00:bf:e4  -  151
    Aug 15 02:35:39  wpa2-key4             ->  00:10:20:59:38:73  d8:c7:c8:00:bf:e4  -  95
    Aug 15 02:35:50  station-down           *  00:10:20:59:38:73  d8:c7:c8:00:bf:e4  -  -
    Aug 15 02:35:50  station-up             *  00:10:20:59:38:73  d8:c7:c8:03:ee:b4  -  -    wpa2 psk aes
    Aug 15 02:35:50  wpa2-key1             <-  00:10:20:59:38:73  d8:c7:c8:03:ee:b4  -  117
    Aug 15 02:35:50  wpa2-key2             ->  00:10:20:59:38:73  d8:c7:c8:03:ee:b4  -  117
    Aug 15 02:35:50  wpa2-key3             <-  00:10:20:59:38:73  d8:c7:c8:03:ee:b4  -  151
    Aug 15 02:35:50  wpa2-key4             ->  00:10:20:59:38:73  d8:c7:c8:03:ee:b4  -  95
    Aug 15 02:38:12  station-down           *  00:10:20:59:38:73  d8:c7:c8:03:ee:b4  -  -
    Aug 15 02:38:12  station-up             *  00:10:20:59:38:73  d8:c7:c8:04:00:44  -  -    wpa2 psk aes
    Aug 15 02:38:12  wpa2-key1             <-  00:10:20:59:38:73  d8:c7:c8:04:00:44  -  117
    Aug 15 02:38:12  wpa2-key2             ->  00:10:20:59:38:73  d8:c7:c8:04:00:44  -  117
    Aug 15 02:38:12  wpa2-key3             <-  00:10:20:59:38:73  d8:c7:c8:04:00:44  -  151
    Aug 15 02:38:12  wpa2-key4             ->  00:10:20:59:38:73  d8:c7:c8:04:00:44  -  95
    Aug 15 02:40:08  station-down           *  00:10:20:59:38:73  d8:c7:c8:04:00:44  -  -
    Aug 15 02:40:08  station-up             *  00:10:20:59:38:73  d8:c7:c8:03:f7:94  -  -    wpa2 psk aes
    Aug 15 02:40:08  wpa2-key1             <-  00:10:20:59:38:73  d8:c7:c8:03:f7:94  -  117
    Aug 15 02:40:08  wpa2-key2             ->  00:10:20:59:38:73  d8:c7:c8:03:f7:94  -  117
    Aug 15 02:40:08  wpa2-key3             <-  00:10:20:59:38:73  d8:c7:c8:03:f7:94  -  151
    Aug 15 02:40:08  wpa2-key4             ->  00:10:20:59:38:73  d8:c7:c8:03:f7:94  -  95
    Aug 15 02:40:19  station-down           *  00:10:20:59:38:73  d8:c7:c8:03:f7:94  -  -
    Aug 15 02:40:19  station-up             *  00:10:20:59:38:73  d8:c7:c8:03:ee:b4  -  -    wpa2 psk aes
    Aug 15 02:40:19  wpa2-key1             <-  00:10:20:59:38:73  d8:c7:c8:03:ee:b4  -  117
    Aug 15 02:40:19  wpa2-key2             ->  00:10:20:59:38:73  d8:c7:c8:03:ee:b4  -  117
    Aug 15 02:40:19  wpa2-key3             <-  00:10:20:59:38:73  d8:c7:c8:03:ee:b4  -  151
    Aug 15 02:40:19  wpa2-key4             ->  00:10:20:59:38:73  d8:c7:c8:03:ee:b4  -  95
    Aug 15 02:40:32  station-down           *  00:10:20:59:38:73  d8:c7:c8:03:ee:b4  -  -
    Aug 15 02:40:32  station-up             *  00:10:20:59:38:73  ac:a3:1e:82:f3:44  -  -    wpa2 psk aes
    Aug 15 02:40:32  wpa2-key1             <-  00:10:20:59:38:73  ac:a3:1e:82:f3:44  -  117
    Aug 15 02:40:32  wpa2-key2             ->  00:10:20:59:38:73  ac:a3:1e:82:f3:44  -  117
    Aug 15 02:40:32  wpa2-key3             <-  00:10:20:59:38:73  ac:a3:1e:82:f3:44  -  151
    Aug 15 02:40:32  wpa2-key4             ->  00:10:20:59:38:73  ac:a3:1e:82:f3:44  -  95
    Aug 15 02:52:22  station-down           *  00:10:20:59:38:73  ac:a3:1e:82:f3:44  -  -
    Aug 15 02:52:22  station-up             *  00:10:20:59:38:73  ac:a3:1e:82:f1:64  -  -    wpa2 psk aes
    Aug 15 02:52:22  wpa2-key1             <-  00:10:20:59:38:73  ac:a3:1e:82:f1:64  -  117
    Aug 15 02:52:22  wpa2-key2             ->  00:10:20:59:38:73  ac:a3:1e:82:f1:64  -  117
    Aug 15 02:52:22  wpa2-key3             <-  00:10:20:59:38:73  ac:a3:1e:82:f1:64  -  151
    Aug 15 02:52:22  wpa2-key4             ->  00:10:20:59:38:73  ac:a3:1e:82:f1:64  -  95
    Aug 15 02:55:26  station-down           *  00:10:20:59:38:73  ac:a3:1e:82:f1:64  -  -
    Aug 15 02:55:26  station-up             *  00:10:20:59:38:73  ac:a3:1e:82:f1:74  -  -    wpa2 psk aes
    Aug 15 02:55:26  wpa2-key1             <-  00:10:20:59:38:73  ac:a3:1e:82:f1:74  -  117
    Aug 15 02:55:26  wpa2-key2             ->  00:10:20:59:38:73  ac:a3:1e:82:f1:74  -  117
    Aug 15 02:55:26  wpa2-key3             <-  00:10:20:59:38:73  ac:a3:1e:82:f1:74  -  151
    Aug 15 02:55:26  wpa2-key4             ->  00:10:20:59:38:73  ac:a3:1e:82:f1:74  -  95
    Aug 15 02:56:59  station-down           *  00:10:20:59:38:73  ac:a3:1e:82:f1:74  -  -
    Aug 15 02:56:59  station-up             *  00:10:20:59:38:73  ac:a3:1e:82:f1:64  -  -    wpa2 psk aes
    Aug 15 02:56:59  wpa2-key1             <-  00:10:20:59:38:73  ac:a3:1e:82:f1:64  -  117
    Aug 15 02:56:59  wpa2-key2             ->  00:10:20:59:38:73  ac:a3:1e:82:f1:64  -  117
    Aug 15 02:56:59  wpa2-key3             <-  00:10:20:59:38:73  ac:a3:1e:82:f1:64  -  151
    Aug 15 02:56:59  wpa2-key4             ->  00:10:20:59:38:73  ac:a3:1e:82:f1:64  -  95
    Aug 15 03:07:10  station-down           *  00:10:20:59:38:73  ac:a3:1e:82:f1:64  -  -
    Aug 15 03:07:10  station-up             *  00:10:20:59:38:73  ac:a3:1e:82:f3:44  -  -    wpa2 psk aes
    Aug 15 03:07:10  wpa2-key1             <-  00:10:20:59:38:73  ac:a3:1e:82:f3:44  -  117
    Aug 15 03:07:10  wpa2-key2             ->  00:10:20:59:38:73  ac:a3:1e:82:f3:44  -  117
    Aug 15 03:07:10  wpa2-key3             <-  00:10:20:59:38:73  ac:a3:1e:82:f3:44  -  151
    Aug 15 03:07:10  wpa2-key4             ->  00:10:20:59:38:73  ac:a3:1e:82:f3:44  -  95
    Aug 15 03:08:42  station-down           *  00:10:20:59:38:73  ac:a3:1e:82:f3:44  -  -
    Aug 15 03:08:42  station-up             *  00:10:20:59:38:73  ac:a3:1e:82:f1:64  -  -    wpa2 psk aes
    Aug 15 03:08:42  wpa2-key1             <-  00:10:20:59:38:73  ac:a3:1e:82:f1:64  -  117
    Aug 15 03:08:42  wpa2-key2             ->  00:10:20:59:38:73  ac:a3:1e:82:f1:64  -  117
    Aug 15 03:08:42  wpa2-key3             <-  00:10:20:59:38:73  ac:a3:1e:82:f1:64  -  151
    Aug 15 03:08:42  wpa2-key4             ->  00:10:20:59:38:73  ac:a3:1e:82:f1:64  -  95
    Aug 15 03:10:59  station-down           *  00:10:20:59:38:73  ac:a3:1e:82:f1:64  -  -
    Aug 15 03:10:59  station-up             *  00:10:20:59:38:73  ac:a3:1e:82:f3:44  -  -    wpa2 psk aes
    Aug 15 03:10:59  wpa2-key1             <-  00:10:20:59:38:73  ac:a3:1e:82:f3:44  -  117
    Aug 15 03:10:59  wpa2-key2             ->  00:10:20:59:38:73  ac:a3:1e:82:f3:44  -  117
    Aug 15 03:10:59  wpa2-key3             <-  00:10:20:59:38:73  ac:a3:1e:82:f3:44  -  151
    Aug 15 03:10:59  wpa2-key4             ->  00:10:20:59:38:73  ac:a3:1e:82:f3:44  -  95
    Aug 15 03:12:24  station-down           *  00:10:20:59:38:73  ac:a3:1e:82:f3:44  -  -
    Aug 15 03:12:24  station-up             *  00:10:20:59:38:73  d8:c7:c8:00:b2:06  -  -    wpa2 psk aes
    Aug 15 03:12:24  wpa2-key1             <-  00:10:20:59:38:73  d8:c7:c8:00:b2:06  -  117
    Aug 15 03:12:24  wpa2-key2             ->  00:10:20:59:38:73  d8:c7:c8:00:b2:06  -  117
    Aug 15 03:12:24  wpa2-key3             <-  00:10:20:59:38:73  d8:c7:c8:00:b2:06  -  151
    Aug 15 03:12:24  wpa2-key4             ->  00:10:20:59:38:73  d8:c7:c8:00:b2:06  -  95
    Aug 15 03:12:36  station-down           *  00:10:20:59:38:73  d8:c7:c8:00:b2:06  -  -
    Aug 15 03:12:36  station-up             *  00:10:20:59:38:73  9c:1c:12:d2:0d:84  -  -    wpa2 psk aes
    Aug 15 03:12:36  wpa2-key1             <-  00:10:20:59:38:73  9c:1c:12:d2:0d:84  -  117
    Aug 15 03:12:36  wpa2-key2             ->  00:10:20:59:38:73  9c:1c:12:d2:0d:84  -  117
    Aug 15 03:12:36  wpa2-key3             <-  00:10:20:59:38:73  9c:1c:12:d2:0d:84  -  151
    Aug 15 03:12:36  wpa2-key4             ->  00:10:20:59:38:73  9c:1c:12:d2:0d:84  -  95
    Aug 15 03:12:47  station-down           *  00:10:20:59:38:73  9c:1c:12:d2:0d:84  -  -
    Aug 15 03:12:47  station-up             *  00:10:20:59:38:73  9c:1c:12:d2:10:14  -  -    wpa2 psk aes
    Aug 15 03:12:47  wpa2-key1             <-  00:10:20:59:38:73  9c:1c:12:d2:10:14  -  117
    Aug 15 03:12:47  wpa2-key2             ->  00:10:20:59:38:73  9c:1c:12:d2:10:14  -  117
    Aug 15 03:12:47  wpa2-key3             <-  00:10:20:59:38:73  9c:1c:12:d2:10:14  -  151
    Aug 15 03:12:47  wpa2-key4             ->  00:10:20:59:38:73  9c:1c:12:d2:10:14  -  95
    Aug 15 03:14:16  station-down           *  00:10:20:59:38:73  9c:1c:12:d2:10:14  -  -
    Aug 15 03:14:16  station-up             *  00:10:20:59:38:73  9c:1c:12:d2:0d:84  -  -    wpa2 psk aes
    Aug 15 03:14:16  wpa2-key1             <-  00:10:20:59:38:73  9c:1c:12:d2:0d:84  -  117
    Aug 15 03:14:16  wpa2-key2             ->  00:10:20:59:38:73  9c:1c:12:d2:0d:84  -  117
    Aug 15 03:14:16  wpa2-key3             <-  00:10:20:59:38:73  9c:1c:12:d2:0d:84  -  151
    Aug 15 03:14:16  wpa2-key4             ->  00:10:20:59:38:73  9c:1c:12:d2:0d:84  -  95
    Aug 15 03:14:28  station-down           *  00:10:20:59:38:73  9c:1c:12:d2:0d:84  -  -
    Aug 15 03:14:28  station-up             *  00:10:20:59:38:73  d8:c7:c8:00:b2:06  -  -    wpa2 psk aes
    Aug 15 03:14:28  wpa2-key1             <-  00:10:20:59:38:73  d8:c7:c8:00:b2:06  -  117
    Aug 15 03:14:28  wpa2-key2             ->  00:10:20:59:38:73  d8:c7:c8:00:b2:06  -  117
    Aug 15 03:14:28  wpa2-key3             <-  00:10:20:59:38:73  d8:c7:c8:00:b2:06  -  151
    Aug 15 03:14:28  wpa2-key4             ->  00:10:20:59:38:73  d8:c7:c8:00:b2:06  -  95
    Aug 15 03:14:39  station-down           *  00:10:20:59:38:73  d8:c7:c8:00:b2:06  -  -
    Aug 15 03:14:39  station-up             *  00:10:20:59:38:73  ac:a3:1e:82:f1:64  -  -    wpa2 psk aes
    Aug 15 03:14:39  wpa2-key1             <-  00:10:20:59:38:73  ac:a3:1e:82:f1:64  -  117
    Aug 15 03:14:39  wpa2-key2             ->  00:10:20:59:38:73  ac:a3:1e:82:f1:64  -  117
    Aug 15 03:14:39  wpa2-key3             <-  00:10:20:59:38:73  ac:a3:1e:82:f1:64  -  151
    Aug 15 03:14:39  wpa2-key4             ->  00:10:20:59:38:73  ac:a3:1e:82:f1:64  -  95
    Aug 15 03:15:00  station-down           *  00:10:20:59:38:73  ac:a3:1e:82:f1:64  -  -
    Aug 15 03:15:00  station-up             *  00:10:20:59:38:73  ac:a3:1e:82:f1:74  -  -    wpa2 psk aes
    Aug 15 03:15:00  wpa2-key1             <-  00:10:20:59:38:73  ac:a3:1e:82:f1:74  -  117
    Aug 15 03:15:00  wpa2-key2             ->  00:10:20:59:38:73  ac:a3:1e:82:f1:74  -  117
    Aug 15 03:15:00  wpa2-key3             <-  00:10:20:59:38:73  ac:a3:1e:82:f1:74  -  151
    Aug 15 03:15:00  wpa2-key4             ->  00:10:20:59:38:73  ac:a3:1e:82:f1:74  -  95
    Aug 15 03:15:10  station-down           *  00:10:20:59:38:73  ac:a3:1e:82:f1:74  -  -
    Aug 15 03:15:10  station-up             *  00:10:20:59:38:73  ac:a3:1e:82:f1:64  -  -    wpa2 psk aes
    Aug 15 03:15:10  wpa2-key1             <-  00:10:20:59:38:73  ac:a3:1e:82:f1:64  -  117
    Aug 15 03:15:11  wpa2-key2             ->  00:10:20:59:38:73  ac:a3:1e:82:f1:64  -  117
    Aug 15 03:15:11  wpa2-key3             <-  00:10:20:59:38:73  ac:a3:1e:82:f1:64  -  151
    Aug 15 03:15:11  wpa2-key4             ->  00:10:20:59:38:73  ac:a3:1e:82:f1:64  -  95
    Aug 15 03:15:21  station-down           *  00:10:20:59:38:73  ac:a3:1e:82:f1:64  -  -
    Aug 15 03:15:21  station-up             *  00:10:20:59:38:73  ac:a3:1e:83:15:26  -  -    wpa2 psk aes
    Aug 15 03:15:21  wpa2-key1             <-  00:10:20:59:38:73  ac:a3:1e:83:15:26  -  117
    Aug 15 03:15:21  wpa2-key2             ->  00:10:20:59:38:73  ac:a3:1e:83:15:26  -  117
    Aug 15 03:15:21  wpa2-key3             <-  00:10:20:59:38:73  ac:a3:1e:83:15:26  -  151
    Aug 15 03:15:21  wpa2-key4             ->  00:10:20:59:38:73  ac:a3:1e:83:15:26  -  95
    Aug 15 03:15:33  station-down           *  00:10:20:59:38:73  ac:a3:1e:83:15:26  -  -
    Aug 15 03:15:33  station-up             *  00:10:20:59:38:73  d8:c7:c8:00:b2:06  -  -    wpa2 psk aes
    Aug 15 03:15:33  wpa2-key1             <-  00:10:20:59:38:73  d8:c7:c8:00:b2:06  -  117
    Aug 15 03:15:33  wpa2-key2             ->  00:10:20:59:38:73  d8:c7:c8:00:b2:06  -  117
    Aug 15 03:15:33  wpa2-key3             <-  00:10:20:59:38:73  d8:c7:c8:00:b2:06  -  151
    Aug 15 03:15:33  wpa2-key4             ->  00:10:20:59:38:73  d8:c7:c8:00:b2:06  -  95
    Aug 15 03:15:45  station-down           *  00:10:20:59:38:73  d8:c7:c8:00:b2:06  -  -
    Aug 15 03:15:45  station-up             *  00:10:20:59:38:73  ac:a3:1e:82:f1:64  -  -    wpa2 psk aes
    Aug 15 03:15:45  wpa2-key1             <-  00:10:20:59:38:73  ac:a3:1e:82:f1:64  -  117
    Aug 15 03:15:45  wpa2-key2             ->  00:10:20:59:38:73  ac:a3:1e:82:f1:64  -  117
    Aug 15 03:15:45  wpa2-key3             <-  00:10:20:59:38:73  ac:a3:1e:82:f1:64  -  151
    Aug 15 03:15:45  wpa2-key4             ->  00:10:20:59:38:73  ac:a3:1e:82:f1:64  -  95
    Aug 15 03:16:07  station-down           *  00:10:20:59:38:73  ac:a3:1e:82:f1:64  -  -
    Aug 15 03:16:07  station-up             *  00:10:20:59:38:73  ac:a3:1e:82:f1:74  -  -    wpa2 psk aes
    Aug 15 03:16:07  wpa2-key1             <-  00:10:20:59:38:73  ac:a3:1e:82:f1:74  -  117
    Aug 15 03:16:07  wpa2-key2             ->  00:10:20:59:38:73  ac:a3:1e:82:f1:74  -  117
    Aug 15 03:16:07  wpa2-key3             <-  00:10:20:59:38:73  ac:a3:1e:82:f1:74  -  151
    Aug 15 03:16:07  wpa2-key4             ->  00:10:20:59:38:73  ac:a3:1e:82:f1:74  -  95
    Aug 15 03:16:49  station-down           *  00:10:20:59:38:73  ac:a3:1e:82:f1:74  -  -
    Aug 15 03:16:49  station-up             *  00:10:20:59:38:73  ac:a3:1e:82:f3:44  -  -    wpa2 psk aes
    Aug 15 03:16:49  wpa2-key1             <-  00:10:20:59:38:73  ac:a3:1e:82:f3:44  -  117
    Aug 15 03:16:49  wpa2-key2             ->  00:10:20:59:38:73  ac:a3:1e:82:f3:44  -  117
    Aug 15 03:16:49  wpa2-key3             <-  00:10:20:59:38:73  ac:a3:1e:82:f3:44  -  151
    Aug 15 03:16:49  wpa2-key4             ->  00:10:20:59:38:73  ac:a3:1e:82:f3:44  -  95
    Aug 15 03:17:05  station-down           *  00:10:20:59:38:73  ac:a3:1e:82:f3:44  -  -
    Aug 15 03:17:05  station-up             *  00:10:20:59:38:73  ac:a3:1e:82:f1:64  -  -    wpa2 psk aes
    Aug 15 03:17:05  wpa2-key1             <-  00:10:20:59:38:73  ac:a3:1e:82:f1:64  -  117
    Aug 15 03:17:05  wpa2-key2             ->  00:10:20:59:38:73  ac:a3:1e:82:f1:64  -  117
    Aug 15 03:17:05  wpa2-key3             <-  00:10:20:59:38:73  ac:a3:1e:82:f1:64  -  151
    Aug 15 03:17:05  wpa2-key4             ->  00:10:20:59:38:73  ac:a3:1e:82:f1:64  -  95
    Aug 15 03:17:21  station-down           *  00:10:20:59:38:73  ac:a3:1e:82:f1:64  -  -
    Aug 15 03:17:21  station-up             *  00:10:20:59:38:73  ac:a3:1e:82:f3:44  -  -    wpa2 psk aes
    Aug 15 03:17:21  wpa2-key1             <-  00:10:20:59:38:73  ac:a3:1e:82:f3:44  -  117
    Aug 15 03:17:21  wpa2-key2             ->  00:10:20:59:38:73  ac:a3:1e:82:f3:44  -  117
    Aug 15 03:17:21  wpa2-key3             <-  00:10:20:59:38:73  ac:a3:1e:82:f3:44  -  151
    Aug 15 03:17:21  wpa2-key4             ->  00:10:20:59:38:73  ac:a3:1e:82:f3:44  -  95
    Aug 15 03:17:37  station-down           *  00:10:20:59:38:73  ac:a3:1e:82:f3:44  -  -
    Aug 15 03:17:37  station-up             *  00:10:20:59:38:73  ac:a3:1e:82:f1:64  -  -    wpa2 psk aes
    Aug 15 03:17:37  wpa2-key1             <-  00:10:20:59:38:73  ac:a3:1e:82:f1:64  -  117
    Aug 15 03:17:37  wpa2-key2             ->  00:10:20:59:38:73  ac:a3:1e:82:f1:64  -  117
    Aug 15 03:17:37  wpa2-key3             <-  00:10:20:59:38:73  ac:a3:1e:82:f1:64  -  151
    Aug 15 03:17:37  wpa2-key4             ->  00:10:20:59:38:73  ac:a3:1e:82:f1:64  -  95
    Aug 15 03:19:10  station-down           *  00:10:20:59:38:73  ac:a3:1e:82:f1:64  -  -
    Aug 15 03:19:10  station-up             *  00:10:20:59:38:73  ac:a3:1e:82:f3:44  -  -    wpa2 psk aes
    Aug 15 03:19:10  wpa2-key1             <-  00:10:20:59:38:73  ac:a3:1e:82:f3:44  -  117
    Aug 15 03:19:10  wpa2-key2             ->  00:10:20:59:38:73  ac:a3:1e:82:f3:44  -  117
    Aug 15 03:19:10  wpa2-key3             <-  00:10:20:59:38:73  ac:a3:1e:82:f3:44  -  151
    Aug 15 03:19:10  wpa2-key4             ->  00:10:20:59:38:73  ac:a3:1e:82:f3:44  -  95
    Aug 15 03:19:34  station-down           *  00:10:20:59:38:73  ac:a3:1e:82:f3:44  -  -
    Aug 15 03:19:34  station-up             *  00:10:20:59:38:73  d8:c7:c8:03:ee:b4  -  -    wpa2 psk aes
    Aug 15 03:19:34  wpa2-key1             <-  00:10:20:59:38:73  d8:c7:c8:03:ee:b4  -  117
    Aug 15 03:19:34  wpa2-key2             ->  00:10:20:59:38:73  d8:c7:c8:03:ee:b4  -  117
    Aug 15 03:19:34  wpa2-key3             <-  00:10:20:59:38:73  d8:c7:c8:03:ee:b4  -  151
    Aug 15 03:19:34  wpa2-key4             ->  00:10:20:59:38:73  d8:c7:c8:03:ee:b4  -  95
    Aug 15 03:20:19  station-down           *  00:10:20:59:38:73  d8:c7:c8:03:ee:b4  -  -
    Aug 15 03:20:19  station-up             *  00:10:20:59:38:73  d8:c7:c8:04:00:4c  -  -    wpa2 psk aes
    Aug 15 03:20:19  wpa2-key1             <-  00:10:20:59:38:73  d8:c7:c8:04:00:4c  -  117
    Aug 15 03:20:19  wpa2-key2             ->  00:10:20:59:38:73  d8:c7:c8:04:00:4c  -  117
    Aug 15 03:20:19  wpa2-key3             <-  00:10:20:59:38:73  d8:c7:c8:04:00:4c  -  151
    Aug 15 03:20:19  wpa2-key4             ->  00:10:20:59:38:73  d8:c7:c8:04:00:4c  -  95
    Aug 15 03:21:20  station-down           *  00:10:20:59:38:73  d8:c7:c8:04:00:4c  -  -
    Aug 15 03:26:09  station-up             *  00:10:20:59:38:73  d8:c7:c8:04:00:44  -  -    wpa2 psk aes
    Aug 15 03:26:09  wpa2-key1             <-  00:10:20:59:38:73  d8:c7:c8:04:00:44  -  117
    Aug 15 03:26:09  wpa2-key2             ->  00:10:20:59:38:73  d8:c7:c8:04:00:44  -  117
    Aug 15 03:26:09  wpa2-key3             <-  00:10:20:59:38:73  d8:c7:c8:04:00:44  -  151
    Aug 15 03:26:09  wpa2-key4             ->  00:10:20:59:38:73  d8:c7:c8:04:00:44  -  95
    Aug 15 03:27:07  station-down           *  00:10:20:59:38:73  d8:c7:c8:04:00:44  -  -
    Aug 15 03:27:07  station-up             *  00:10:20:59:38:73  d8:c7:c8:03:f5:b4  -  -    wpa2 psk aes
    Aug 15 03:27:07  wpa2-key1             <-  00:10:20:59:38:73  d8:c7:c8:03:f5:b4  -  117
    Aug 15 03:27:07  wpa2-key2             ->  00:10:20:59:38:73  d8:c7:c8:03:f5:b4  -  117
    Aug 15 03:27:07  wpa2-key3             <-  00:10:20:59:38:73  d8:c7:c8:03:f5:b4  -  151
    Aug 15 03:27:07  wpa2-key4             ->  00:10:20:59:38:73  d8:c7:c8:03:f5:b4  -  95
    Aug 15 02:29:05  wpa2-key1             <-  00:10:20:59:38:73  6c:f3:7f:7e:78:96  -  117
    (ADAC-MWLC-7220) #
  • 2.  RE: Hi Team, we are facing Hand held devices disconnection while scanning the luggages
    Posted Aug 15, 2015 06:04 AM
    What kind of device is this?
  • 3.  RE: Hi Team, we are facing Hand held devices disconnection while scanning the luggages
    Posted Aug 15, 2015 10:06 AM
    It's Used in Aviation Industry to scan the bar code of the Luggages, We have Motorolla and Honey well models
    https://www.zebra.com/us/en/products/mobile-computers/handheld/mc9190-g.html
    Attachment(s)
    txt
    Debug.txt   735 KB 1 version
  • 4.  RE: Hi Team, we are facing Hand held devices disconnection while scanning the luggages
    Posted Aug 15, 2015 01:35 PM
    All the devices at the same time, or individual devices at different times?
    Do you have "drop broadcast and multicast" enabled on the virtual AP profile?
  • 5.  RE: Hi Team, we are facing Hand held devices disconnection while scanning the luggages
    Posted Aug 15, 2015 10:35 AM
    Jai,
    It is not clear from the auth-tracebuf what your issue is.  If this worked at one time, we can look to see what has changed and walk those changes back.  If this never worked, you should open up a TAC case ASAP to that they can leverage all the information to get this working because it could be a large number of things.
  • 6.  RE: Hi Team, we are facing Hand held devices disconnection while scanning the luggages
    Posted Aug 15, 2015 01:33 PM
    Thanks Collin for your response
    It's working fine but once or twice in a day, face this problem. Suddenly there will be no signal on the device, once the device restarts it works fine. Outage will be max 5 Mins
