hidden SSID issue with android
  • 1.  hidden SSID issue with android
    Posted Jun 23, 2013 02:01 AM
    hii guyzz..........
    I have controller 7210 with AOS 6.2.1.1,
    I have two hidden SSIDs one with  802.1x authentication and one with wpa2-psk.
    On android devices i am facing a issue, even after manually configuring the ssid device says "not in range" for both SSID,
    sometimes it conects but most of the time just says "not in range".
    I have checked with android 2.3.5, 4.0.2, 4.1.1.
    With rukus AP with same configuration it works well, i checked that.
    pls commnt............................
    #7210
  • 2.  RE: hidden SSID issue with android
    Posted Jun 23, 2013 07:44 AM
    Is this only happening to the android devices ?
    Is the android able to connect with same SSID while being broadcast ?
    Do you have the local probe threshold set to a certain value?
  • 3.  RE: hidden SSID issue with android
    Posted Jun 24, 2013 04:58 AM
    thnx for reply..
    issue is with android only and local probe threshold is 0db by default.
  • 4.  RE: hidden SSID issue with android
    Posted Jun 24, 2013 04:59 AM
    and it doesnt face issue when ssid being broadcasted..
  • 5.  RE: hidden SSID issue with android
    Posted Jun 23, 2013 08:09 AM
    Are you using RFProtect?
    Do you have AirWave? Check to see if those devices are being reported as a DoS attack.
    Also, if you have a device to test with, try the following:
    In the dialer type: *#0011#
    Choose the Wi-Fi option in the service menu.
    Turn the Wi-Fi power saving option to off.
    See if you are able to connect.
  • 6.  RE: hidden SSID issue with android
    Posted Jun 23, 2013 08:14 AM
    not sure if it will help u:
