"High Capacity Guest mode" , can be enabled on cp-5000?
  • 1.  "High Capacity Guest mode" , can be enabled on cp-5000?
    Posted May 18, 2015 10:51 AM
    Can I enable"High Capacity Guest mode" on cp-5000 or only on the 500 version?
    Please advise.
    Me
  • 2.  RE: "High Capacity Guest mode" , can be enabled on cp-5000?
    Posted May 18, 2015 10:52 AM
    Yes. All versions support HPG
    Tim
  • 3.  RE: "High Capacity Guest mode" , can be enabled on cp-5000?
    Posted May 18, 2015 12:21 PM
    Follow up to Tim's post..........
    Ye, we support the enabling of HCG on all hardware and VM models. Note that when you enable the HCG we will disable certian feature to allow us to better balance the resources wihtin the CPPM node..... if you like were robbing Peter to pay Paul....
    So what do we disable... bascially we disabled..... OnBoarding, OnGuard and a bunch of EAP methods........
    EAP-FAST
    EAP-GTC
    EAP-MSCHAPv2
    EAP-PEAP
    EAP-TLS
    EAP-TTLS
    The exception is EAP-PEAP-PUBIC......
