High capacity VLAN setup
  • 1.  High capacity VLAN setup
    Posted Mar 15, 2012 03:39 PM
    We trying to create a wireless setup for 3,000 + guest users , and our concern was around what type of VLAN setup we should do to provide IP address for all those users:
    First option:
    - configure the controller as a dhcp server and create several IP segments / VLANS and do VLAN pooling on the guest VAP ( I think this the best option) but somebody suggested that this could potentially take a lot of resources from the controller
    Second option:
    - configure the controller as a dhcp server and create just one IP segment /VLAN that would allow me to support 3000+ users (one big broadcast domain)
    I was wondering if anybody has implemented a configuration for a scenario like this and what type of VLAN setup worked.
  • 2.  RE: High capacity VLAN setup
    Posted Mar 15, 2012 03:43 PM
    First option:
    Second option:
    - Never use the internal DHCP server for more than 256 clients.  Use an external one in this case
    - Break up the Subnets into /23s if you can
    - Use the high density VRD here: http://www.arubanetworks.com/pdf/technology/DG_HighDensity_VRD.pdf to get more details about what to look out for.
  • 3.  RE: High capacity VLAN setup
    Posted Mar 19, 2012 12:03 AM
    What is the basis for this statement?
    Are their limitations we should be aware of?
    We currently service several  /23 networks on a controller without any .apparent issues.
  • 4.  RE: High capacity VLAN setup
