High CPU on mesh portal IAP 175
  • 1.  High CPU on mesh portal IAP 175
    Posted Aug 22, 2014 04:10 AM
    Hi!
    I have WLAN which include 1x IAP 135, 2x IAP 175P and 1x IAP 175AC (mesh). All APs works in Instant mode. One of IAP 175P is mesh portal and IAP 175AC is mesh AP. On mesh portal I see high cpu utilization. Average number of clients in rush hours is about 70 clients.
    CPU utilization on mesh portal:mesh_portal.png
    CPU utilization on mesh AP:
    Total clients and usage:
    Do you have any ideas? Thanks in advance for helping me!
  • 2.  RE: High CPU on mesh portal IAP 175
    Posted Jan 21, 2015 04:55 AM
    Anyone can help me with this issue? I still have problem with CPU which (probably) cause stucking mesh point in down state for about half time in every day.
  • 3.  RE: High CPU on mesh portal IAP 175
    Posted Jan 21, 2015 06:03 AM
    Hi friend,
    How many child APs uder this portal ?
    can you share the output of " Show aps", show ap mesh neighbours" and "show log system"
    Please share the required information.
  • 4.  RE: High CPU on mesh portal IAP 175
    Posted Jan 21, 2015 06:07 AM
    There is only one child connected to the portal.
    Unfortunately i don't have access to CLI, only through web GUI.
  • 5.  RE: High CPU on mesh portal IAP 175
    Posted Jan 21, 2015 06:52 AM
    You can send the summary support through support menu( More--Support).
  • 6.  RE: High CPU on mesh portal IAP 175
    Posted Jan 21, 2015 07:23 AM
    show aps
    AP List
    Name               IP Address    Mode    Spectrum  Clients  Type   Mesh Role  2.4 Channel  2.4 Power (dB)  2.4 Utilization (%)  2.4 Noise Floor (dBm)  5.0 Channel  5.0 Power (dB)  5.0 Utilization (%)  5.0 Noise Floor (dBm)  Need Antenna Config  From Port  Config Id  Config Csum  Age
    6c:f3:7f:ce:3f:a4  192.168.1.6*  access  disable   7        135    Portal     6            19              6(good)              -94(good)              60+          22              0(good)              -92(good)              No                   none       7          39754        8d:19h:59m:12s
    24:de:c6:cf:dc:e5  192.168.1.7   access  disable   27       175P   Portal     11           20              9(good)              -96(good)              116+         24              0(good)              -93(good)              No                   none       7          39754        8d:19h:58m:55s
    24:de:c6:c7:29:7a  192.168.1.4   access  disable   2        135    Portal     11           19              2(good)              -90(good)              44+          22              0(good)              -93(good)              No                   none       7          39754        8d:19h:57m:34s
    24:de:c6:cf:dc:5f  192.168.1.5   access  disable   15       175P   Portal     1            20              13(good)             -96(good)              108+         24              20(good)             -93(good)              No                   none       7          39754        2h:42m:40s
    d8:c7:c8:c8:04:b5  192.168.1.10  access  disable   11       175AC  Point      11           20              13(good)             -96(good)              108+         24              22(good)             -93(good)              No                   none       7          39754        42m:28s
    Neighbor list
    MAC                Portal             Channel  Age  Hops  Cost  Relation   Flags  RSSI  Rate Tx/Rx  A-Req  A-Resp  A-Fail  HT-Details       Cluster ID
    d8:c7:c8:00:4b:59  24:de:c6:7d:c5:f8  108+     0    1     7.00  C 42m:56s  HLK    45    6/6         4      4       0       HT-40MHzsgi-2ss  42b09b0d6e45167b6e1f0483915d056
    d8:c7:c8:00:4b:58  24:de:c6:7d:c5:f8  108+     0    1     7.00  N 42m:54s  HLK    45    -           0      0       0       HT-40MHzsgi-2ss  42b09b0d6e45167b6e1f0483915d056
    Total count: 2, Children: 1
    Relation: P = Parent; C = Child; N = Neighbor; B = Blacklisted-neighbor
    Flags: R = Recovery-mode; S = Sub-threshold link; D = Reselection backoff; F = Auth-failure; H = High Throughput; L = Legacy allowed
    	K = Connected; U = Upgrading; G = Descendant-upgrading; Z = Config pending; Y = Assoc-resp/Auth pending
    	a = SAE Accepted; b = SAE Blacklisted-neighbour; e = SAE Enabled; u = portal-unreachable; o = opensystem
    show log system
    Jan 21 12:21:07  stm[1682]: <399801>  |AP 6c:f3:7f:ce:3f:a4@192.168.1.6 stm|  An internal system error has occurred at file rc_acct_instant.c function rc_interim_acct_req line 650.
    Jan 21 12:21:07  stm[1682]: <399801>  |AP 6c:f3:7f:ce:3f:a4@192.168.1.6 stm|  An internal system error has occurred at file rc_acct_instant.c function rc_acct_common_vplist line 107.
    Jan 21 12:23:09  stm[1682]: <399801>  |AP 6c:f3:7f:ce:3f:a4@192.168.1.6 stm|  An internal system error has occurred at file rc_acct_instant.c function rc_acct_common_vplist line 107.
    Jan 21 12:23:09  stm[1682]: <399801>  |AP 6c:f3:7f:ce:3f:a4@192.168.1.6 stm|  An internal system error has occurred at file rc_acct_instant.c function rc_interim_acct_req line 650.
    Jan 21 12:23:38  stm[1682]: <304001>  |AP 6c:f3:7f:ce:3f:a4@192.168.1.6 stm|  Unexpected stm (Station management) runtime error at update_sta_flag, 2069, Doesn't send rc_stop_acct_req when captive portal + auth mode
    Jan 21 12:25:07  stm[1682]: <304001>  |AP 6c:f3:7f:ce:3f:a4@192.168.1.6 stm|  Unexpected stm (Station management) runtime error at update_sta_flag, 2069, Doesn't send rc_stop_acct_req when captive portal + auth mode
    Jan 21 12:25:12  stm[1682]: <399801>  |AP 6c:f3:7f:ce:3f:a4@192.168.1.6 stm|  An internal system error has occurred at file rc_acct_instant.c function rc_acct_common_vplist line 107.
    Jan 21 12:25:12  stm[1682]: <399801>  |AP 6c:f3:7f:ce:3f:a4@192.168.1.6 stm|  An internal system error has occurred at file rc_acct_instant.c function rc_interim_acct_req line 650.
    Jan 21 12:26:43  stm[1682]: <304001>  |AP 6c:f3:7f:ce:3f:a4@192.168.1.6 stm|  Unexpected stm (Station management) runtime error at update_sta_flag, 2069, Doesn't send rc_stop_acct_req when captive portal + auth mode
    Jan 21 12:27:14  stm[1682]: <399801>  |AP 6c:f3:7f:ce:3f:a4@192.168.1.6 stm|  An internal system error has occurred at file rc_acct_instant.c function rc_acct_common_vplist line 107.
    Jan 21 12:27:14  stm[1682]: <399801>  |AP 6c:f3:7f:ce:3f:a4@192.168.1.6 stm|  An internal system error has occurred at file rc_acct_instant.c function rc_interim_acct_req line 650.
    Jan 21 12:27:56  stm[1682]: <304001>  |AP 6c:f3:7f:ce:3f:a4@192.168.1.6 stm|  Unexpected stm (Station management) runtime error at update_sta_flag, 2069, Doesn't send rc_stop_acct_req when captive portal + auth mode
    Jan 21 12:28:38  stm[1682]: <304001>  |AP 6c:f3:7f:ce:3f:a4@192.168.1.6 stm|  Unexpected stm (Station management) runtime error at update_sta_flag, 2069, Doesn't send rc_stop_acct_req when captive portal + auth mode
    Jan 21 12:29:16  stm[1682]: <399801>  |AP 6c:f3:7f:ce:3f:a4@192.168.1.6 stm|  An internal system error has occurred at file rc_acct_instant.c function rc_acct_common_vplist line 107.
    Jan 21 12:29:16  stm[1682]: <399801>  |AP 6c:f3:7f:ce:3f:a4@192.168.1.6 stm|  An internal system error has occurred at file rc_acct_instant.c function rc_interim_acct_req line 650.
    Jan 21 12:29:44  stm[1682]: <304055>  |AP 6c:f3:7f:ce:3f:a4@192.168.1.6 stm| |ap| Unexpected stm (Station management) runtime error at rap_bridge_user_handler, 11755, couldn't find sap fnct:rap_bridge_user_handler, bss:00:00:00:00:00:00
    Jan 21 12:30:53  cli[1676]: <341004>  |AP 6c:f3:7f:ce:3f:a4@192.168.1.6 cli|  AP 192.168.1.5: Client e4:2d:02:45:9f:45 connect fail because DHCP request timed out
    Jan 21 12:31:19  stm[1682]: <399801>  |AP 6c:f3:7f:ce:3f:a4@192.168.1.6 stm|  An internal system error has occurred at file rc_acct_instant.c function rc_acct_common_vplist line 107.
    Jan 21 12:31:19  stm[1682]: <399801>  |AP 6c:f3:7f:ce:3f:a4@192.168.1.6 stm|  An internal system error has occurred at file rc_acct_instant.c function rc_interim_acct_req line 650.
    Jan 21 12:32:49  stm[1682]: <304001>  |AP 6c:f3:7f:ce:3f:a4@192.168.1.6 stm|  Unexpected stm (Station management) runtime error at update_sta_flag, 2069, Doesn't send rc_stop_acct_req when captive portal + auth mode
    Jan 21 12:33:21  stm[1682]: <399801>  |AP 6c:f3:7f:ce:3f:a4@192.168.1.6 stm|  An internal system error has occurred at file rc_acct_instant.c function rc_acct_common_vplist line 107.
    Jan 21 12:33:21  stm[1682]: <399801>  |AP 6c:f3:7f:ce:3f:a4@192.168.1.6 stm|  An internal system error has occurred at file rc_acct_instant.c function rc_interim_acct_req line 650.
    Jan 21 12:34:06  stm[1682]: <304001>  |AP 6c:f3:7f:ce:3f:a4@192.168.1.6 stm|  Unexpected stm (Station management) runtime error at update_sta_flag, 2069, Doesn't send rc_stop_acct_req when captive portal + auth mode
    Jan 21 12:35:04  stm[1682]: <304001>  |AP 6c:f3:7f:ce:3f:a4@192.168.1.6 stm|  Unexpected stm (Station management) runtime error at update_sta_flag, 2069, Doesn't send rc_stop_acct_req when captive portal + auth mode
    Jan 21 12:35:22  cli[1676]: <341004>  |AP 6c:f3:7f:ce:3f:a4@192.168.1.6 cli|  AP 192.168.1.10: Client cc:3a:61:37:a8:78 connect fail because DHCP request timed out
    Jan 21 12:35:23  stm[1682]: <304001>  |AP 6c:f3:7f:ce:3f:a4@192.168.1.6 stm|  Unexpected stm (Station management) runtime error at update_sta_flag, 2069, Doesn't send rc_stop_acct_req when captive portal + auth mode
    Jan 21 12:37:10  stm[1682]: <304001>  |AP 6c:f3:7f:ce:3f:a4@192.168.1.6 stm|  Unexpected stm (Station management) runtime error at update_sta_flag, 2069, Doesn't send rc_stop_acct_req when captive portal + auth mode
    Jan 21 12:38:18  stm[1682]: <304001>  |AP 6c:f3:7f:ce:3f:a4@192.168.1.6 stm|  Unexpected stm (Station management) runtime error at update_sta_flag, 2069, Doesn't send rc_stop_acct_req when captive portal + auth mode
    Jan 21 12:39:19  stm[1682]: <304001>  |AP 6c:f3:7f:ce:3f:a4@192.168.1.6 stm|  Unexpected stm (Station management) runtime error at update_sta_flag, 2069, Doesn't send rc_stop_acct_req when captive portal + auth mode
    Jan 21 12:45:53  stm[1682]: <304001>  |AP 6c:f3:7f:ce:3f:a4@192.168.1.6 stm|  Unexpected stm (Station management) runtime error at update_sta_flag, 2069, Doesn't send rc_stop_acct_req when captive portal + auth mode
    Jan 21 12:48:31  cli[1676]: <341004>  |AP 6c:f3:7f:ce:3f:a4@192.168.1.6 cli|  AP 192.168.1.5: Client 30:75:12:ab:37:b3 connect fail because DHCP request timed out
    Jan 21 12:48:41  stm[1682]: <304001>  |AP 6c:f3:7f:ce:3f:a4@192.168.1.6 stm|  Unexpected stm (Station management) runtime error at update_sta_flag, 2069, Doesn't send rc_stop_acct_req when captive portal + auth mode
    Jan 21 12:50:04  cli[1676]: <341004>  |AP 6c:f3:7f:ce:3f:a4@192.168.1.6 cli|  AP 192.168.1.7: Client 00:18:60:64:31:1b connect fail because DHCP request timed out
    Jan 21 12:50:23  stm[1682]: <304001>  |AP 6c:f3:7f:ce:3f:a4@192.168.1.6 stm|  Unexpected stm (Station management) runtime error at update_sta_flag, 2069, Doesn't send rc_stop_acct_req when captive portal + auth mode
    Jan 21 12:57:08  stm[1682]: <304001>  |AP 6c:f3:7f:ce:3f:a4@192.168.1.6 stm|  Unexpected stm (Station management) runtime error at update_sta_flag, 2069, Doesn't send rc_stop_acct_req when captive portal + auth mode
    Jan 21 12:58:31  cli[1676]: <341004>  |AP 6c:f3:7f:ce:3f:a4@192.168.1.6 cli|  AP 192.168.1.10: Client 20:54:76:e0:65:e3 connect fail because DHCP request timed out
    Jan 21 12:58:38  stm[1682]: <304001>  |AP 6c:f3:7f:ce:3f:a4@192.168.1.6 stm|  Unexpected stm (Station management) runtime error at update_sta_flag, 2069, Doesn't send rc_stop_acct_req when captive portal + auth mode
    Jan 21 12:59:45  stm[1682]: <304055>  |AP 6c:f3:7f:ce:3f:a4@192.168.1.6 stm| |ap| Unexpected stm (Station management) runtime error at rap_bridge_user_handler, 11755, couldn't find sap fnct:rap_bridge_user_handler, bss:00:00:00:00:00:00
    Jan 21 13:00:08  stm[1682]: <304001>  |AP 6c:f3:7f:ce:3f:a4@192.168.1.6 stm|  Unexpected stm (Station management) runtime error at update_sta_flag, 2069, Doesn't send rc_stop_acct_req when captive portal + auth mode
    Jan 21 13:02:23  stm[1682]: <304001>  |AP 6c:f3:7f:ce:3f:a4@192.168.1.6 stm|  Unexpected stm (Station management) runtime error at update_sta_flag, 2069, Doesn't send rc_stop_acct_req when captive portal + auth mode
    Jan 21 13:03:38  stm[1682]: <304001>  |AP 6c:f3:7f:ce:3f:a4@192.168.1.6 stm|  Unexpected stm (Station management) runtime error at update_sta_flag, 2069, Doesn't send rc_stop_acct_req when captive portal + auth mode
    Jan 21 13:03:52  cli[1676]: <341004>  |AP 6c:f3:7f:ce:3f:a4@192.168.1.6 cli|  AP 192.168.1.5: Client 88:c9:d0:d7:b7:86 connect fail because DHCP request timed out
    Jan 21 13:04:08  stm[1682]: <304001>  |AP 6c:f3:7f:ce:3f:a4@192.168.1.6 stm|  Unexpected stm (Station management) runtime error at update_sta_flag, 2069, Doesn't send rc_stop_acct_req when captive portal + auth mode
    All logs originate from virtual controller (except mesh neighbours which include log from mesh portal)
  • 7.  RE: High CPU on mesh portal IAP 175
    Posted Jan 21, 2015 07:48 AM
    All logs are originating from VC except mesh neighbours which include logs from mesh portal.
    Attachment(s)
    txt
    logs.txt   14 KB 1 version
  • 8.  RE: High CPU on mesh portal IAP 175
    Posted Jan 22, 2015 01:15 PM
    As far as the mesh portal dropping it appears it's on channel 108 which is a DFS channel. It's entirely possible it's detecting radar on the channel and having to go off channel. If you do a show log wireless all do you see any radar events happening?
  • 9.  RE: High CPU on mesh portal IAP 175
    Posted Jan 22, 2015 01:55 PM
    Yes, "radar detected" appears on mesh portal.
    In fact near the site (about 300m) there is transmitting station like this:
    http://pliki.radiopolska.pl/galeria/getpict.php?country=1&filename=mainthumb&id_loc=40
    Attachment(s)
    txt
    radar_events.txt   11 KB 1 version
  • 10.  RE: High CPU on mesh portal IAP 175
    Posted Jan 28, 2015 11:10 AM
    I would disable DFS channels for your APs in a situation like this, and in most other situations as well unless you're very strapped for channels. Some clients still don't support DFS channels and will fail to connect if an AP is on DFS creating a coverage hole. In this case as well it obviously causes your mesh to drop when the radar comes onto the channel.
  • 11.  RE: High CPU on mesh portal IAP 175
    Posted Jan 28, 2015 01:46 PM
    It is possible to disable DFS in instant mode?
  • 12.  RE: High CPU on mesh portal IAP 175
    Posted Jan 28, 2015 03:13 PM
    You can change the allowed channels arm can use by do the following in the CLI:
    (Instant AP)(config)# arm
    (Instant AP)(ARM)# a-channels <channel-list>
    (Instant AP)(ARM)# end
    (Instant AP)# commit apply
    http://community.arubanetworks.com/aruba/attachments/aruba/IAP/6226/1/Aruba%20Instant%206.4.0.2-4.1%20CLI%20Reference%20Guide.pdf
  • 13.  RE: High CPU on mesh portal IAP 175
    Posted Jan 30, 2015 10:34 AM
    You can also do it in the GUI (had to get into my instant demo to take a look). If you go to RF -> Show Advanced Options and select Customize Valid Channels under Access Point control then you can edit the allowed channels. See attached image.
  • 14.  RE: High CPU on mesh portal IAP 175
    Posted Feb 07, 2015 10:33 AM
    Thanks a lot! In logs there was problem with channel 100+. I changed allowed channel from 36-64. Unfortunately this is global settings (in fact I could set it only on particular AP) - I will monitor behaviour the whole WLAN from radio point and I hope it will be work.
