High Density APs
  • 1.  High Density APs
    Posted Mar 05, 2013 02:41 PM
    AP105 , 125 & 135 arfe high density APs ... while AP90 is not
    what  deos high density means ?  can have more users associated ?  how much ?
  • 2.  RE: High Density APs
    Posted Mar 05, 2013 02:54 PM
    Good evening,:smileyhappy:
    High Density = Large number of users / Large number of AP'S -usually overlapping each other / Large number of client demands for different QOS over the air  and more...
    The AP-9X isn't for high density mainly because the reason at cannot give access in both spectrums simultaneously (2.4+5) no band sterring | no 2.4GHZ=20mhz+5GHZ=40mhz. = 600Mbps
    Here is an example for High Density environment:
    This is the full article:
    http://www.arubanetworks.com/wp-content/uploads/dg_highdensity_vrd.pdf
    More good info:
    http://www.arubanetworks.com/pdf/technology/TR_HiDensityWiFiBenchmark.pdf
    http://networktest.com/arubaarm/arubaarm1.pdf
    have a lovely night. :smileywink:
    me
  • 3.  RE: High Density APs
    Posted Mar 05, 2013 03:12 PM
    AP-105 is suitable for ceil mounting because it is downtilt antenna . i caanot understand that ?
    it is omni directional @ the end ?
  • 4.  RE: High Density APs
    Posted Mar 05, 2013 03:16 PM
    Here is AP-105 in ACTION :)
    AP-105 antenna pattern plots
  • 5.  RE: High Density APs
    Posted Mar 05, 2013 03:28 PM
    Thx , u got the point ... i know the pattern plot but cannot differentiate/ understand it  ... i know one is vertical & other if horizontal ... what what is difference comparing to AP-93 pattern plots ?
  • 6.  RE: High Density APs
    Posted Mar 05, 2013 03:32 PM
    AP-93 AND AP-105
    BOTH GOT 2X2 Antennas - both of the units using Omni built in antennas.
    The pattern plot of Omni antenna of all unit will look almost the same... Because it's Omni :)
  • 7.  RE: High Density APs
    Posted Mar 05, 2013 03:35 PM
    Hi
    I did some small compare using the datasheets of both products for u. (its not that accurate)
    It will give to the ideas that it's only a small different between two pattern plots.
