Highest OS upgrade for 7205
  • 1.  Highest OS upgrade for 7205
    Posted Aug 14, 2019 10:52 AM
    Hello.
    I currently have a 7205 controller running OS version 6.5.3.2. I would like to upgrade the OS version to the highest version supported on this controller. I'm confused about the compatible OS versions because most documentation I see is about version 8. Any help would be much appreciated. Thanks. -Tony Harris
  • 2.  RE: Highest OS upgrade for 7205
    Posted Aug 14, 2019 11:54 AM
    The release notes for each version of ArubaOS should have a "supported platforms" section.  Below is a snippet of the supported platforms portion of ArubaOS 8.5.2.:
    In concert, you can also check to see if a SKU has ben end-of-lifed here:  https://www.arubanetworks.com/support-services/end-of-life/
  • 3.  RE: Highest OS upgrade for 7205
    Posted Aug 16, 2019 08:59 AM
    Thanks!!!
