Hitless Failover
  • 1.  Hitless Failover
    Posted Sep 19, 2018 08:57 AM
    Hi All,
    AirWave is reporting that hitless failover is not possible on our cluster. Unfortunately it doesn't seem to offer any detail as to why it's not possible. I believe I have everything configured correctly and redundancy is enabled. Controllers are running 8.3.0.2 and AirWave is running 8.2.7.
    Anyone have any insights as to why AirWave is reporting this?
    Cluster Membership:
    (bmh-kp02-wlc-01) [MDC] *#show lc-cluster group-membership
    Cluster Enabled, Profile Name = "BNH-Cluster-01"
    Redundancy Mode On
    Active Client Rebalance Threshold = 50%
    Standby Client Rebalance Threshold = 75%
    Unbalance Threshold = 5%
    AP Load Balancing: Enabled
    Active AP Rebalance Threshold = 50%
    Active AP Unbalance Threshold = 5%
    Active AP Rebalance AP Count = 30
    Active AP Rebalance Timer = 1 minutes
    Cluster Info Table
    Type IPv4 Address Priority Connection-Type STATUS
    self 10.134.127.21 128 N/A CONNECTED (Leader)
    peer 10.134.127.22 128 L3-Connected CONNECTED (Member, last HBT_RSP 56ms ago, RTD = 0.000 ms)
  • 2.  RE: Hitless Failover
    Posted Sep 19, 2018 09:28 AM
    On one of the mobility controllers you can run the following command :
    Show lc-cluster vlan-probe status
    This will show if there’s a particular VLAN that might be causing the issue
    Make sure you exclude VLAN 1 if is not in use or any other VLANs that are not trunked or are local to the controller
    Thank you
    Victor Fabian
    Pardon typos sent from Mobile
  • 3.  RE: Hitless Failover
    Posted Sep 19, 2018 09:48 AM
    So the goal is to get a layer 2 cluster instead of layer 3 by excluding the vlans as Victor posted.
  • 4.  RE: Hitless Failover
    Posted Sep 19, 2018 11:27 AM
    Thank you both for the reply!
    I found and exluded the offending VLAN. The connection type is now L2 and AirWave is reporting hitless failover as possible.
    Before:
    (bmh-ep01-wlc-02) [MDC] #show lc-cluster vlan-probe status
    Cluster VLAN Probe Status
    Type IPv4 Address REQ-SENT REQ-FAIL ACK-SENT ACK-FAIL REQ-RCVD ACK-RCVD VLAN_FAIL CONN-TYPE START/STOP
    peer 10.134.127.21 157 0 91 0 91 79 1108 L3 Conn 8/ 19
    After:
    peer 10.134.127.21 193 0 129 0 129 115 0 L2 Conn 18/ 18
