Wired Intelligent Edge
Hmmm, what transceiver to use? Helping with ArubaOS-Switch and ArubaOS-CX Transceiver Choices.
  • 1.  Hmmm, what transceiver to use? Helping with ArubaOS-Switch and ArubaOS-CX Transceiver Choices.
    Posted Apr 12, 2018 04:23 PM
    The transceiver question is typically on them mind during every deployment.  Below is the link to our current combined ArubaOS-Switch and ArubaOS-CX Supported Transceiver Guide and I have attached important information about the use of 3rd party transceivers.
    https://support.hpe.com/hpsc/doc/public/display?docId=a00028947en_us
  • 2.  RE: Hmmm, what transceiver to use? Helping with ArubaOS-Switch and ArubaOS-CX Transceiver Choices.
    Posted Jul 07, 2020 01:29 PM
    Hi Rob.
    Do Aruba AOS-CX (6300M) switches support HPE FlexNetwork Transceivers?
    Carlos Villanueva
  • 3.  RE: Hmmm, what transceiver to use? Helping with ArubaOS-Switch and ArubaOS-CX Transceiver Choices.
    Posted Jul 16, 2020 01:09 AM
    Good day!
    HPE FlexNetwork Transceivers are not supported, but from CX 10.5 release we support allow-third party transceivers.
    AOS-CX(config)# allow-unsupported-transceiver
      confirm       Automatically acknowledge warning and skip confirmation prompt
      log-interval  Configure unsupported transceiver logging
      <cr>
    AOS-CX(config)# allow-unsupported-transceiver confirm
    AOS-CX(config)# allow-unsupported-transceiver log-interval
      <1440-10080>  The logging interval (Default: 1440 minutes)
      none          Disable unsupported transceiver logging
    AOS-CX# sh int 1/1/24 transceiver detail
    Transceiver in 1/1/24
     Interface Name      : 1/1/24
     Type                : SFP+10G (unsupported)
     Connector Type      : ??
     Wavelength          : ??
     Transfer Distance   : ?? Diagnostic Support  : ??
     Product Number      : ??
     Serial Number       : ??
     Part Number         : ??
    AOS-CX(config)# sh int 1/1/23 transceiver detail
    Transceiver in 1/1/23
     Interface Name      : 1/1/23
     Connector Type      : Copper Pigtail
     Wavelength          : 0nm
     Transfer Distance   : 0.00km (SMF), 0m (OM1), 0m (OM2), 0m (OM3)
     Diagnostic Support  : None
     Vendor name         : Molex Inc.
     Vendor Part Number  : 74752-9056
     Vendor Part Revision: C
     Vendor Serial number: 918830075
    Thank you,
    Yash
  • 4.  RE: Hmmm, what transceiver to use? Helping with ArubaOS-Switch and ArubaOS-CX Transceiver Choices.
    Posted Jul 28, 2020 08:58 AM
    I can't find that in the release notes, is that only for 6300/6400 or also on the 8400?
  • 5.  RE: Hmmm, what transceiver to use? Helping with ArubaOS-Switch and ArubaOS-CX Transceiver Choices.
    Posted Jul 28, 2020 09:18 AM
    Good day!
    From 10.5 allow-unsupported-transceiver supported on all cx platforms.
    BLDG01-F1(config)# allow-unsup
    allow-unsupported-transceiver Allow unsupported transceivers
    BLDG01-F1(config)# sh version
    ArubaOS-CX
    (c) Copyright 2017-2020 Hewlett Packard Enterprise Development LP
    Version : FL.10.05.0001
    Build Date : 2020-07-09 17:48:12 PDT
    Build ID : ArubaOS-CX:FL.10.05.0001:53cb98af4936:202007092351
    Build SHA : 53cb98af4936ce4b2e61fb4bb9dde7e7925c5e29
    Active Image : secondary
    Service OS Version : FL.01.05.0003-internal
    BIOS Version : FL.01.0002
    BLDG01-F1(config)#
    Thank you,
    Yash
  • 6.  RE: Hmmm, what transceiver to use? Helping with ArubaOS-Switch and ArubaOS-CX Transceiver Choices.
    Posted Jul 29, 2020 01:34 AM
    Good day!
    Missed to add AOS-CX 10.5 release notes, which you asked!
    1. ArubaOS-CX 10.05.0001 Release Notes for the Aruba 6300 and 6400 Switch Series https://support.hpe.com/hpsc/doc/public/display?docId=a00102041en_us
    2. ArubaOS-CX 10.05.0001 Release Notes for the Aruba 8325 Switch Series
    https://support.hpe.com/hpsc/doc/public/display?docId=a00102042en_us
    3. ArubaOS-CX 10.05.0001 Release Notes for the Aruba 6200 Switch Series
    https://support.hpe.com/hpsc/doc/public/display?docId=a00102043en_us
    4. ArubaOS-CX 10.05.0001 Release Notes for the Aruba 8320 Switch Series
    https://support.hpe.com/hpsc/doc/public/display?docId=a00102044en_us
    5. ArubaOS-CX 10.05.0001 Release Notes for the Aruba 8400 Switch Series
    https://support.hpe.com/hpsc/doc/public/display?docId=a00102045en_us
    Thank you,
    Yash
  • 7.  RE: Hmmm, what transceiver to use? Helping with ArubaOS-Switch and ArubaOS-CX Transceiver Choices.
    Posted Aug 18, 2020 03:07 PM
    Is 10.05.001 a stable version?
  • 8.  RE: Hmmm, what transceiver to use? Helping with ArubaOS-Switch and ArubaOS-CX Transceiver Choices.
    MVP GURU
    Posted Aug 28, 2020 07:23 AM
    Yes, it is.
    Currently (28 August 2020) ArubaOS-CX 10.05.0010 superseded the ArubaOS-CX 10.05.0001. So go with the latest if possible.
