Network Management
Hostname in Airwave incorrect?
  • 1.  Hostname in Airwave incorrect?
    Posted Aug 22, 2019 02:41 PM
    Hi
    Can anyone tell me why although my two controllers hostnames are different that Airwave picks them up and gives them the same hostname?
    (BFS-AH-WLAN-1) #show hostname
    Hostname is BFS-AH-WLAN-1
    (BFS-AH-WLAN-2) #show hostname
    Hostname is BFS-AH-WLAN-2
    When you click into each one the serial info is unique and correct but the display name shows duplicate hostname:
    This has happened on another site as well.
  • 2.  RE: Hostname in Airwave incorrect?
    Posted Aug 22, 2019 04:07 PM
    Does the hostnames show as same in Device list page? Does it show proper names in individual controller monitor pages? I am sure you have done manul poll to the controllers. One thing you could try is to change the hostname of Hostname is BFS-AH-WLAN-2 in controller manage page and poll the controlelr to see if the name reverts back to Hostname is BFS-AH-WLAN-1. If so, then the SNMP response from controller some how responding with wrong name.
  • 3.  RE: Hostname in Airwave incorrect?
    Posted Aug 23, 2019 03:41 AM
    OK so I am not sure how I fixed this.
     I checked the port and SNMP information and amended it as it was incorrect.
    Also I then added the Mobility Master 1 and 2 to Omnivista.
    The names are displaying correctly this morning.  Not sure which fixed it but I don't mind as all is how it should be :)
    Thanks for your help!
