last person joined: 5 hours ago
Hotel Wifi design
  • 1.  Hotel Wifi design
    Posted Oct 18, 2013 05:14 PM
    Hello!
    I got this hotel which does not got like the standard design
    In this hotel for example if i put one AP in one room the signal need to cross the bathroom which the ap is  located, and the bathroom of the other room also, so when the signal reach the next room is really weak...
    So what now? i would need to put like 1 AP per room... which would be really really expensive...
    Guys what you would do in this case? is there any other way im not thinking?instead of putting one ap per room?
    Cheers
    Carlos
  • 2.  RE: Hotel Wifi design
    Posted Oct 18, 2013 05:34 PM
    @NightShade1 wrote:
    Hello!
    Cheers
    Carlos
    <outside the box>
    See if you can get any usable coverage from the floor below or above as part of your survey.  If yes, you could possibly try to stagger the access points from floor to floor.  It is worth trying.
    </outside the box>
  • 3.  RE: Hotel Wifi design
    Posted Oct 18, 2013 05:37 PM
    Ill try that...
    Any other ideas?
    Cheers
    Carlos
  • 4.  RE: Hotel Wifi design
    Posted Oct 18, 2013 05:39 PM
    You are limited by where you can mount.  Bathrooms have alot of solid objects that would block RF, so I would say to try not to mount in there...find another place...  Alot of hotels would allow you to mount under the desk.  That might be a better location.
    I do not know much about the hotel, so all I could say is that you need to experiment with your placement to get better coverage, and measure the result.
  • 5.  RE: Hotel Wifi design
    Posted Oct 18, 2013 05:43 PM
    The major issue here is that the bathroom is in the middle of the rooms
    let say i got room 201 and room 203 next to each other
    AP is on 201, the wifi signal has to travel through the Bathroom of 201 and the bathroom of 203 to reach the next room.
    Ill try to see how is the multifloor coverange... luckily i wont loose too much dbs
    Cheers
    Carlos
  • 6.  RE: Hotel Wifi design
    Posted Oct 18, 2013 05:44 PM
    Carlos,
    I am confident you will come up with a solution.
  • 7.  RE: Hotel Wifi design
    Posted Oct 18, 2013 05:45 PM
    right :P
    but still looking for forum help to see if someone had this issue before :)
    Cheers
    Carlos
  • 8.  RE: Hotel Wifi design
    Posted Oct 18, 2013 06:05 PM
    Something you can try which worked very well for us this past summer in buildings with very challenging structures and that bleed through the walls for 5ghz was pretty much unusable is to place the AP ( wall mounted )in between floors for example if you have 3 floors you will place the ap in the second floor and that will provide coverage for 1st and 3rd floor . Of course this was at dorm but we were dealing with brick walls .
    What was the power levels on the AP when you tried in the other room ?
  • 9.  RE: Hotel Wifi design
    Posted Oct 18, 2013 06:22 PM
    Ill try that also. It was an ap 93h 2.4ghz band 21dbm
  • 10.  RE: Hotel Wifi design
    Posted Oct 18, 2013 06:27 PM
    In the other room i was geting on my fluke -75 or -80 was not good... At least i prefer to to.see -65...
  • 11.  RE: Hotel Wifi design
    Posted Oct 18, 2013 06:53 PM
    That's pretty bad with 21 on 2.4
  • 12.  RE: Hotel Wifi design
    Posted Oct 18, 2013 07:05 PM
    I know that...
    But i need to find a way... telling him to buy 1 ap per room would be mean hahahah, is not a 5 star hotel.. is a small hotel :(
    Cheers
    Carlos
  • 13.  RE: Hotel Wifi design
    Posted Oct 18, 2013 07:28 PM
    See if there's any bleed between the floors
  • 14.  RE: Hotel Wifi design
    Posted Oct 18, 2013 08:40 PM
    Have you tried a different AP that has a different propagation pattern?
  • 15.  RE: Hotel Wifi design
    Posted Oct 18, 2013 09:26 PM
    Well i tried with ap 93h and ap 105.
    The bad.thing is that i just got ap 93,93h,105, and rap109
    Im trying to get an ap 135,225 and 115
    But im waiting that the owner aprove thise demos aps
    Cheers
    Carlos
  • 16.  RE: Hotel Wifi design
    Posted Oct 18, 2013 09:31 PM
    Gotcha. Could you tell any difference between the 93h vs the downtilting 105?
    I was hoping the ceiling mounted APs would help. I'd also go with the staggered floor/room approach mentioned if applicable.
  • 17.  RE: Hotel Wifi design
    Posted Oct 18, 2013 09:35 PM
    I will try this next week. Hopefully something will work out. I mean one of your suggestions guys.
    Thank you all if qnyone got another idea they all are welcome
  • 18.  RE: Hotel Wifi design
    Posted Oct 18, 2013 09:37 PM
    Il answer your question next week airheads chief :)
    Cheers
    Carlos
  • 19.  RE: Hotel Wifi design
    Posted Oct 18, 2013 09:40 PM
    Thanks my valuable MVP haha
