How add an ip route in clearpass ?
This thread has been viewed 42 times
  • 1.  How add an ip route in clearpass ?
    Posted Feb 18, 2014 04:07 AM
    i would like to know how add an ip route in clearpass, because i configure 2 interface IP on my Clearpass
    Mgmt and Data.
    Mgmt is use for magament and check AD
    Data is use for access to Guest Portal
    When i configure an IP address on the DATA interface, i could not access on my internal Active Directory by the Mgmt interface.
    On CLI,  i found this cmd but it doesn't work ...
    "add Add the network ip rule
    Usage:
    network ip add <mgmt|data|greN> [-i <id>] <[-s <SrcAddr>] [-d <DestAddr>]> [-g <ViaAddr>]
    Where
    greN -- Name of the gre tunnel where N corresponds to the gre
    tunnel number ranging from 1,2,3...N
    -i -- Optional parameter. Id of the network ip rule. If unspecified the
    system will auto generate the Id
    -s <SrcAddr> -- Optional parameter. The source interface ip address or netmask from
    where the network ip rule is specified. The allowed values are -
    valid IP Address or Netmask or '0/0'
    -d <DestAddr> -- Optional parameter. The destination interface ip address or netamsk
    -g <ViaAddr> -- Optional parameter. The via or gateway ip address through which the
    network traffic should flow. The allowed value is valid IP Address"
    Could you to help me ?
  • 2.  RE: How add an ip route in clearpass ?
    Posted Feb 18, 2014 06:15 AM
    Try this :
    network ip add mgmt -d <Active Directory IP Address/Subnet Mask> -g <Gateway IP address>
  • 3.  RE: How add an ip route in clearpass ?
    Posted Feb 18, 2014 06:30 AM
    it work now ! thanks victorfabian !
  • 4.  RE: How add an ip route in clearpass ?
    Posted Mar 19, 2014 10:40 AM
    I try this :
    #network ip add data -d 192.168.2.1/24 -g 192.168.10.1
    ERROR - Failed add route for destination=192.168.2.1/24 via=192.168.10.1
    What could be the problem?
    Thanks!
  • 5.  RE: How add an ip route in clearpass ?
    Posted Mar 19, 2014 11:01 AM
    based upon a /24 your IP address and Gateway are in different subnets, but you have used a host address for the destinatation. I'm guessing this is the issue. Also, I guess that the data interface is in the 192.168.10.0 network.
