How add AP on Backupt Controller
  • 1.  How add AP on Backupt Controller
    Posted Sep 16, 2016 06:21 AM
    I have 2 WLAN ctrl 7005. In the master I can see all my AP provisioned via DHCP, however in my backup ctrl I' m not able to provision the same AP. I'm new in ARUBA and I'm trying to set-up master and backup ctrl. Can you please aslo indicate a guide guide/best practice?
    Thans
  • 2.  RE: How add AP on Backupt Controller
    Posted Sep 16, 2016 06:57 AM
    On the current master, do you see the backup as "backup master"?
    The backup master has no function until it is a master. You cannot configure anything on it and you cannot view statistics. It just synchronized it's configuration with the master and waits until the master is no longer reachable to take over.
  • 3.  RE: How add AP on Backupt Controller
    Posted Sep 16, 2016 09:43 AM
    So, following thi guide
    https://community.arubanetworks.com/aruba/attachments/aruba/unified-wired-wireless-access/13066/1/Redundancy_Design_Guide.pdf
    this is ehat I have done so far
    (SMPWAP1) #show vrrp
    Virtual Router 1:
        Description
        Admin State UP, VR State BACKUP
        IP Address 10.222.123.254, MAC Address 00:00:5e:00:01:01, vlan 1230
        Priority 100, Advertisement 1 sec, Preemption Enable Delay 0
        Auth type NONE ********
        tracking is not enabled
    (SMPWC2) #show vrrp
    Virtual Router 1:
        Description
        Priority 10, Advertisement 1 sec, Preemption Enable Delay 0
    The only thing that I haven't done is the lms-ip because I don't have the command in my OS. So, Can you please tell me if something is missing from the conf? How can I see if the 2 AP are in sync?
  • 4.  RE: How add AP on Backupt Controller
    MVP EXPERT
    Posted Sep 17, 2016 06:58 AM
    Have you configured the master redudancy as well? See below for an example :
    master-redundancy
    master-vrrp 2
    peer-ip-address 192.168.68.221 ipsec password123
    This is explained further in the User Guide
  • 5.  RE: How add AP on Backupt Controller
    Posted Sep 18, 2016 04:11 AM
    What 192.168.68.221 stays for? Management IP interface of my controller? VRRP IP?
  • 6.  RE: How add AP on Backupt Controller
    Posted Sep 18, 2016 09:18 AM
    Virtual Router 1:
        Description
    (SMPWC2) #show vrrp
    Virtual Router 1:
        Description
    It seems that both controllers are in state backup, which could mean that a third device has control of the VRRP on that VLAN.  Do you have a separate router on that same subnet that is doing HSRP?  That router might have taken control of the VRRP on that VLAN.  I would configure your VRRP with the same password on both controllers, so that your router does not participate in the VRRP conversation.
  • 7.  RE: How add AP on Backupt Controller
    Posted Sep 19, 2016 04:57 AM
    this is the actual status. Was a my copy/paste error
    (SMPWC2) #show vrrp
    Virtual Router 1:
    Description
    Virtual Router 1:
    Description
    Admin State UP, VR State MASTER
    So..looking to my configration, wha remains to do?
    (SMPWAP1) #show configuration | begin vrrp
    vrrp 1
      ip address 10.222.123.254
      vlan 1230
      preempt delay 0
      no shutdown
    vrrp 1
      priority 10
      vlan 1230
      preempt delay 0
      no shutdown
    Someone suggested to configure the master controlelr with an IP, but which IP should I put under master controller? IP manafement interface? Virtual VRRP IP?
  • 8.  RE: How add AP on Backupt Controller
    Posted Sep 19, 2016 05:40 AM
    The .254 address is the VRRP or the virtual address that your access points will terminate on.  A controller that has priority will answer to that virtual address and handle access points.  That is the master.  The backup will answer at .254 when the master is unreachable.  You would set your aruba-master ip address to .254 so that when access points come up, they can terminate on the virtual ip address.  The VRRP only sets up ip address redundancy.  To setup redundancy where controller configurations are synchronized, you need to setup master redundancy.  To setup master redundancy, you need to configure the current master first, and the backup device second.  When you configure master redundancy, the global configuration on the backup will be replaced and synchronized with the configuration of the master, so configure the master controller first like this:
    SWPWAP1:
    config t
    master-redundancy
    master-vrrp 1
    peer-ip-address <management ip address of swpwap2 on vlan 1230> ipsec password123
    SWPWAP2:
    config t
    master-redundancy
    master-vrrp 1
    peer-ip-address <management ip address of swpwap1 on vlan 1230> ipsec password123
    After you do that, you should be able to type "show switches" on WAP1 and see wap2 as a "backup master"
  • 9.  RE: How add AP on Backupt Controller
    Posted Sep 20, 2016 04:50 AM
    First of all, thank you very much for your detailed answer.
    So, following you indication, I still have problem to make the redudancy work
    First controller (master)
    (SMPWAP1) #show ip interface brief
    Interface IP Address / IP Netmask Admin Protocol
    vlan 1230 10.222.123.2 / 255.255.255.0 up up
    (SMPWAP1) #ping 10.222.123.3
    Press 'q' to abort.
    Sending 5, 92-byte ICMP Echos to 10.222.123.3, timeout is 2 seconds:
    Success rate is 100 percent (5/5), round-trip min/avg/max = 0.275/0.34/0.508 ms
    (SMPWAP1) #show switches
    All Switches
    IP Address Name Location Type Model Version Status Configuration State Config Sync Time (sec) Config ID
    10.222.123.2 SMPWAP1 Building1.floor1 master Aruba7005 6.4.4.5_54063 up UPDATE SUCCESSFUL 0 1
    10.222.123.3 SMPWC2 Building1.floor1 standby Aruba7005 6.4.4.5_54063 up UPDATE SUCCESSFUL 8 1
    Total Switches:2
    Virtual Router 1:
        Description
    Configuration
    controller-ip vlan 1230
    interface vlan 1230
    	ip address 10.222.123.2 255.255.255.0
    master-redundancy
      master-vrrp 1
      peer-ip-address 10.222.123.3 ipsec 8c50d77a6ed8e2d36d1463fb2baa06a8c1d8202c54afa07e
    vrrp 1
      vlan 1230
      preempt delay 0
      no shutdown
    Second controller (backup)
    (SMPWC2) #show ip  interface brief
    vlan 1230                 10.222.123.3 / 255.255.255.0     up      up
    (SMPWC2) #ping 10.222.123.2
    Press 'q' to abort.
    Sending 5, 92-byte ICMP Echos to 10.222.123.2, timeout is 2 seconds:
    Success
    (SMPWC2) #show switches
    All Switches
    10.222.123.3  SMPWC2  Building1.floor1  standby  Aruba7005  6.4.4.5_54063  up      UPDATE SUCCESSFUL    0                       1
    Total Switches:1
    Virtual Router 1:
    Description
    Configuration
    interface vlan 1230
    	ip address 10.222.123.3 255.255.255.0
    master-redundancy
      master-vrrp 1
      peer-ip-address 10.222.123.2 ipsec 20ba409b68f513af9b2c32c7c88c71b7da2e6bd2acd3644b
    vrrp 1
      priority 10
      vlan 1230
      preempt delay 0
      no shutdown
    Thanks!
  • 10.  RE: How add AP on Backupt Controller
    Posted Sep 20, 2016 06:55 AM
    That looks correct!  If you are using DNS-Based discovery, make sure that aruba-master.<domain.com> points to
    10.222.123.254
  • 11.  RE: How add AP on Backupt Controller
    Posted Sep 20, 2016 08:33 AM
    Great! I don't use DNS-base discover,so I can skip it.
    Coming back to my originale questiom, despite the conf seems ok, the backup still is not able to add access poit! What I'm missing again?
  • 12.  RE: How add AP on Backupt Controller
    Posted Sep 20, 2016 11:07 AM
    The backup cannot do anything at all unless the master fails....
  • 13.  RE: How add AP on Backupt Controller
    Posted Sep 20, 2016 11:12 AM
    Ok,
    So, if I want add APs to the backup I need to shutdown the master, do my configuration and then resume my master controller. Is it correct?
