How add more "Disk space" into ClearPass
This thread has been viewed 54 times
  • 1.  How add more "Disk space" into ClearPass
    Posted Sep 18, 2018 01:50 AM
    Hi Everyone,
    I facing issue about ClearPass running on low disk space.
    On my vm about 8 vCPU, RAM8GB, HDD1: 1TB, HDD2: 100GB.
    Why cppm show only total space hdd 7.63 GB.
    How to make disk space relate vm HDD sizing.
    Thank you.
  • 2.  RE: How add more "Disk space" into ClearPass
    Posted Sep 18, 2018 04:06 AM
    Unsure how you got to this disk configuration (1TB + 100GB), but that is not how it is supposed to be. During installation, a 30GB or 40GB disk should come with the VM image import. Then you add the second disk depending on the appliance size, for the C2000V that should be 1000GB. So for the C2000V you should have a 30GB or 40GB disk as first HDD and a 1000GB as second HDD.
    As you disk setup is quite different, I would either work with Aruba TAC to get this setup right or the faster alternative is to create a backup, spin up a new appliance with the correct disk setup and specs and restore the backup (then rejoin AD, reinstall certificates).
  • 3.  RE: How add more "Disk space" into ClearPass
    Posted Sep 18, 2018 05:00 AM
    Great!!!!
    That worked.
    I try to deploy VM with HDD1:30GB and HDD2:1000GB
    Thank you.
