How can be compatibility with 802.1b or 802.1g disable in a WLC with 225 APs?.
  • 1.  How can be compatibility with 802.1b or 802.1g disable in a WLC with 225 APs?.
    Posted Feb 18, 2015 10:37 PM
    How can be compatibility with 802.1b or 802.1g disable in a WLC with 225 APs?. I have a WLC 7030.
    I want all my costumers to be just 802.11n radios. I want to use badn steering and balance within radios for 802.11n. I want to improve my performance. Is air fairness enable by default?
    #AP225
  • 2.  RE: How can be compatibility with 802.1b or 802.1g disable in a WLC with 225 APs?.
    Posted Feb 18, 2015 10:43 PM
    You cannot completely disable 802.11g and 802.11a (greenfield) because of neighboring networks.
    What you can do is eliminate lower data rates to force users to associate at a higher data rate.
    Band steering and SLB are enabled automatically with ClientMatch.
    https://ase.arubanetworks.com/solutions/id/75
  • 3.  RE: How can be compatibility with 802.1b or 802.1g disable in a WLC with 225 APs?.
    Posted Feb 18, 2015 10:46 PM
    Hi. Thanks for your answer. I can disable this lower data rates like 1 and 2 Mbps in SSID profile under the Virtual AP, is that correct?
  • 4.  RE: How can be compatibility with 802.1b or 802.1g disable in a WLC with 225 APs?.
    Posted Feb 18, 2015 10:47 PM
    Yes. To completely disable 802.11b, disable all transmit rates below 12 and
    set your basic rates to 12 and 24.
  • 5.  RE: How can be compatibility with 802.1b or 802.1g disable in a WLC with 225 APs?.
    Posted Feb 18, 2015 10:50 PM
    Thanks very much for your help!!!
