Wired Intelligent Edge
How can I config dot1x with wire authentication on Aruba Switch S1500-48P
  • 1.  How can I config dot1x with wire authentication on Aruba Switch S1500-48P
    Posted Feb 21, 2018 11:19 PM
    I have problem on Switch Aruba S1500-48P
    Firmware 7.4.1.5
    Can't config dot1x with wire to authentication
  • 2.  RE: How can I config dot1x with wire authentication on Aruba Switch S1500-48P
  • 3.  RE: How can I config dot1x with wire authentication on Aruba Switch S1500-48P
    Posted Feb 23, 2018 04:44 AM
    Thanks!  Herman Robers
    I read it on ArubaOS 7.2 User guide document told me to generate certification CSR.
    I generate some code so I need to copy that code on
    -----BEGIN CERTIFICATE REQUEST-----
    My code
    -----END CERTIFICATE REQUEST-----
    I need to copy this code and send some email to CA?
    That all I want to do if I want to configuration dot1x?
    Thanks :D
  • 4.  RE: How can I config dot1x with wire authentication on Aruba Switch S1500-48P
    Posted Feb 26, 2018 07:29 AM
    If you are using an external RADIUS server for the 802.1X and no captive portal redirects on the switch, you don't need a certificate on the switch.
    For 802.1X you only need a certificate on the switch if you do EAP Termination. Recommended is to use an external RADIUS server for that.
